Poor ev milage on 24 prime
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Jaxryde, Mar 25, 2024.
  1. Jaxryde
    Jaxryde Junior Member
    Oregon
    1 Now that i have had my 2024 Prime for 1600 miles. I love it, just about everything but the mileage using ev. I have yet to get more than 30 miles. I was expecting 39 - 44. Also when watching the % of battery usage remaining. At 44 miles woud be about 1% usuage per mile. Mine is no where close. Gas milage is as expected at around 440 miles .
  2. Zyrian
    Zyrian Member
    ATL
    2023 Prius Prime
    SE
    What does "fuel economy" section in the gauge cluster say? You can see both trip (if set to trip vs. total) and real time. To get 44 you need to see at least 4mi/kWh average.
    Consider:
    • speed (highway 70mph+ you'll be lucky with 3mi/kWh),
    • lead foot (I can get 1mi/kWh having fun),
    • climate control (10% cut easy),
    • tire pressure,
    • wheel weight
  3. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    It's probably the way you're driving it. Have you made any changes to the car since your purchase? Wheels, tires, roof rack etc?
  4. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    I'm at 1300+ miles with 40 miles of range estimated at full state of charge.
    I was at 800+ miles with 38 miles of range estimated at full state of charge.
    The number does recalculate based on how you drive and what conditions you drive in.
    I generally run low (Eco) heat climate control in cold weather, with heated seats instead of blowing a lot of air. If I really need high heat or defogging, the gas engine should do it more efficiently than the EV alone so I let it run in HV if it needs to.
    If you accelerate really hard in EV mode, consider letting the engine do some of the work in Auto or HV mode, since it will accelerate much faster and with less hard wear on the battery. The car seems better designed to do this, and will accelerate fairly effortlessly if you let the gas engine run rather than forcing it to stay in EV. I find that Auto or HV mode performs better than EV coasting/maintaining at 60-80 miles per hour, both by the numbers and in terms of not overworking the battery needlessly. If you floor it in EV mode, expect that the car will only accelerate moderately but have extremely inefficient power delivery. This is mostly outweighed by how efficient the EV mode is at low loads and lower speeds, but not entirely. If you are using a lot of throttle, let the engine warm up for a few minutes and then feel free to use that in addition to the electric motor.
    This is in Colorado Front Range winter conditions, so somewhat cold with big variations and very sunny, so I expect to get slightly better numbers in the spring/fall, and about the same in the summer.
  5. Jaxryde
    Oregon
    Thanks, Helpful
  6. JimLudden
    JimLudden Member
    88
    35
    Taos, NM
    2024 Prius Prime
    Shut off the heat pump/AC compressor. Mine was 'on' when I first got the car. I could not determine why the car was so noisy. Turned out that the "AUTO" was on, meaning the compressor was always running, draining the traction battery.
  7. Jaxryde
    Oregon
    After taking recommendations from posts I have reached 3.5 miles per kw hours. This is not normal driving conditions. I have a difficult time reaching 40 mph while barely stepping on the gas. I have cone to the realization that my regular conservative driving will get around 3.1 miles per kw hours or 31 miles of ev range.
    douglasjre, Bill Norton and vvillovv like this.
  8. Zeromus
    Zeromus Active Member
    537
    297
    Ottawa Canada
    2024 Prius Prime
    SE
    When it's below freezing, with winter tires I get around 3.5
    When it's 10C with winter tires I jumped up to 4.6
    Lots of factors impact the variability. You don't notice it as much on an ICE because gas tanks are big and they go far. So if you fill up 35L and go 500km, then in winter for 440km because of the conditions, you don't *really* notice the 10% cut in range because the range is so long to begin with.
    Losing 10-15-20% of your range due to driving conditions is significantly more obvious when the range is a fifth of what you're traditionally used to having in between "fill ups" as it were also.
    Trollbait likes this.
  9. Gokhan
    Gokhan Senior Member
    5,988
    2,375
    Paramount CA
    You are not going to get the EPA range estimate with any BEV if you drive very fast, as the aerodynamic drag force increases with the square of the speed. Heavy acceleration and deceleration will also contribute to the range loss.
  10. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    The history data the car keeps about how it was driven is calculated into the estimates of EV range.
    It's true that to get better EV range and more miles per kWh the driver has to learn how to get them.
    There is an engine in the car and if you haven't yet or don't want to learn how to get better EV stats than it's to your advantage to use the engine more, while figuring out how the EV stuff works in your favor and / or against it.
    Another member posted nearly the same issue a couple days ago.
    Gen 4 Prime (2020) not fully charging anymore | PriusChat
    #10 vvillovv, Apr 4, 2024
  11. Bill Norton
    Bill Norton Senior Member
    2,138
    732
    MONW, Ks.
    Which is basically:
    Drive slower and slower each day in EV mode, until you see the numbers you like.
    Slower. It's the only thing that works.
    Why would you ever encourage burning gas to save EV miles?(n)
    iRun26.2 and Doug McC like this.
  12. Trollbait
    12,454
    Burning gas during higher speed segments will mean more total EV miles for lower speed ones.
    It's the entire theory for a blended PHEV.
    mountaineer and dolphinsil like this.
  13. UmpireRips
    UmpireRips Junior Member
    Colorado
    2024 Prius Prime
  14. bisco
    51,624
    everyones mileage differs based on driving parameters
    Bill Norton and KPB33132 like this.
  15. Bill Norton
    2,138
    732
    MONW, Ks.
    not mine
  16. KH111
    KH111 Member
    65
    37
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    Just checked ours yesterday on a round trip to Greenville SC from our house near the North Carolina state line, 55 deg OAT. A 50/50 mix of highway and city driving, A/C set at a comfortable 68 deg. 42 miles EV only range before the car switched over to HV mode. Better than advertised.
    KH
    tovli and bisco like this.
  17. Bill Norton
    2,138
    732
    MONW, Ks.
    Did that 25 mph tail wind have anything to do with it? Of course wind matters.(y)
  18. JimLudden
    JimLudden Member
    88
    35
    Taos, NM
    2024 Prius Prime
    My miles on full battery ('24 Prime SE) gradually increased from about 44 to 57, except two days ago it jumped to 62!
    In measured tests I got 48 miles and 52 miles on a full battery -- under different driving conditions. Surprise to me the 52 miles was up and over a 1600' mountain pass.
    douglasjre likes this.
  19. Gokhan
    5,988
    2,375
    Paramount CA
    That could be better. I get up to over 40 miles of BEV range in my 2021 Prius Prime Limited, with the EPA range being 25 miles. That would correspond to over 70 miles in your case, with the EPA range being 44 miles. Try driving more gently and eliminating friction braking entirely.
  20. Zeromus
    537
    297
    Ottawa Canada
    2024 Prius Prime
    SE
    I believe the electric motor in the new gen is more powerful, so it will of course, use more energy as well. With a big enough battery, the EV motor in the car could, realistically, drive the car without an ICE at all (from a propulsion perspective alone, not counting other tech changes). I think the efficiency looks like its in line with the other entry level BEVs like the Bolt for example.
    tovli likes this.
