Gen 4 Prime (2020) not fully charging anymore
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by hans1, Mar 28, 2024.
  1. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Couldn’t find any threads with the problem I’m seeing.
    My 2020 Prime at under 40k miles now only charges from empty 4.9 kWh (when at home, or at public chargers) and then stops. Car won’t allow charging any more than that. Up until the past few weeks, it used to charge 5.9 kWh from empty.
    In all the years, have never seen this before, for any temperature or weather.
    The estimated range is also down to 18-19 miles, from 21-22 miles.
    Any ideas?
    #1 hans1, Mar 28, 2024
  2. Mr.Vanvandenburg
    1,362
    667
    2020 Prius Prime
    How do you measure the kwh? The estimated range does fluctuate on previous driving conditions. Maybe battery temp is a factor.
  3. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Oh, it was how many kWh that the ChargePoint app showed were added. And this was from battery being empty. This has happening every time, and only started over the past month.
    And at home, I’m seeing the same reduced range to go, after “fully charged”.
    Really a step change from everything previous over the past several years.
    Is there any way to reset the battery and charging? Almost seems like the car is confused?!
    p.s.- the thing I’m worried about is not really the range to go, but unable to accept a “full” kWh charge from empty
    #3 hans1, Mar 28, 2024
  4. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    What is your climate like? It sounds like it may be a battery state of charge capacity problem. Are you cycling frequently or leaving it fully charged for long periods of time?
  5. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Climate is mild, and no temperature extremes. Charge every day, and don’t leave fully charged more than a day or two at most. Drive most days.
  6. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Do you use an app to monitor anything besides kW s into the hybrid battery
  7. sylvaing
    sylvaing Senior Member
    1,221
    517
    I'll sound like a broken record but Hybrid Assistant is great for that.
    vvillovv and hans1 like this.
  8. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Good thoughts all, thanks. Will have to look for that. I checked the miles/kWh from the display, and it looks like it has also slowly degraded over time, with the worst drop over the past month.
  9. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Found other threads about battery degradation, and that does look like what I’m getting.
    It seems like maybe all my driving in EV mode at high speed (75-85 mph on highways) does make a difference in more quickly degrading battery ability to fully charge?! Even with under 40k miles on my 2020 Prime.
    vvillovv likes this.
  10. Mr.Vanvandenburg
    1,362
    667
    2020 Prius Prime
    There an eco diary which shows the daily and monthly miles/ kwh. That would show the efficiency changes. Maybe if you drive only ev around town for awhile and see if anything changes in the capacity. I don’t know why it would, because full ev’s drive highway not losing capacity. Or maybe they do. You do use the battery intensively for long periods going those speeds
    #10 Mr.Vanvandenburg, Mar 30, 2024
  11. vvillovv
    4,337
    1,519
    NY
    I didn't want to ask it, but I'm glad you said it. Those speeds in EV mode is gonna do in the tiny EV battery. It gets even worse when driving those speeds and running out of EV range and having the engine switch on cold. Even 100 F is cold for the engine at those speeds. A lot of owners have posted that is how they drive their Primes. :eek:
    It wouldn't be AS noticeable in the Gen 5 Prime as it will be in the Gen 4 Prime, and even more noticeable in the Gen 3 Plugin even though it's top EV speed was 64 mph if I'm remembering right.
    DrPrius and CarScanner are also useful apps.
    #11 vvillovv, Mar 30, 2024
  12. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Whoops. I drive right up to the about 85 mph limit just before the ICE comes up, whenever I can avoid it turning on. But do let up on the accelerator whenever transitioning out of EV mode, and try to keep it gentle then. Will see what the apps say.
  13. sylvaing
    1,221
    517
    If I know I'll be needing the engine later on in my drive, I'll warm up the engine before going by turning the defrost on and off. It doesn't take long for the engine to warm up, if you still have your exhaust heat exchanger that is lol.
  14. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Looked at my monthly miles/kWh, and it has dropped from 4.2 kWh a year ago, and continued a steady decline to about 3.6 kWh now. And yes, I guess my high speed EV driving and acceleration has taken its toll.
    Spent a day of driving very conservatively mostly in the city, below the speed limit, and when no one was around at half the speed limit (!), and got it up to 4.5 kWh. But no way I’ll be driving like that long term, haha.
  15. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    I don't think Prime is meant to drive extensively on EV mode (especially at high speeds). Yes, it has an advertised 25-mile EV range, but it is still primarily a hybrid vehicle with much smaller battery compared to full EVs. My understanding is that you are driving your vehicle on EV whenever possible and charging it every day. This type of extensive use will cause battery degradation no doubt.
    Every time you power of your vehicle, it gives you an EV driving score based on 4 parameters. May I ask what score you typically see on your screen?
  16. hans1
    hans1 Member
    53
    29
    2020 Prius PHV
    Too ashamed to say, and actually I don’t remember, maybe I might be putting it out of my mind
  17. iskoos
    415
    254
    Orlando, FL
    I think I got my answer :)
  18. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Some code reader can tell the battery capacity percentage, like BlueDriver. I got 86.3% on my 2018 PP when I tested in June 2023.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Can we assume that the charger is stopping at 100% indicated? You never said. If it stops short of 100% that's a different matter.
    High speed EV driving will increase the wear on the battery for a couple reasons. One, the higher current is hard on it. Also, since you're using it up more quickly, you're probably increasing the cycle count and that's another wear factor.
    However, battery degradation is neither an indicator nor a cause of low mi/kWh except if it leads to more frequent charge/discharge cycles.
    Dr. Prius should tell you what's going on inside the mysterious aluminum box back there.
  20. sylvaing
    1,221
    517
    I wouldn't rely on Dr. Prius for a Prime. Email I got from them:
    I don’t think Dr. Prius App is fully calibrated for the 2017 Prime yet, we only have a chance to work on the Gen1 plug-in Prius, we need to find a test car and calibrate it, FYI.
    jerrymildred likes this.
