I have a 2018 PriusV High coolant temperature warning light flash a few times and then disappeared
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tong PriusV, Dec 1, 2019.
  1. Tong PriusV
    Tong PriusV New Member
    Lancaster CA
    2013 Prius v wagon
    When I was driving on the freeway, I saw the High coolant temperature warning light flash a few times and then disappeared. Then I refilling the coolant. But it happened again.If it is a cooling system problem, why does it always happen after driving all day. And it disappeared after a few flashes. Everything works fine after that. Has anyone else had the same problem?
  2. Dharma1212
    Dharma1212 New Member
    Lakewood
    2018 Prius
    Hi Tony, I have the same issue currently. Did you ever find out what the issue was?
  3. Mendel Leisk
    41,012
    A 2018 Prius v is mechanically more-or-less the same as a 3rd gen Prius. What's your "2018 Prius", a regular, hatchback-style 4th gen Priu?
  4. rjparker
    9,898
    6,104
    No 2018 v’s were sold in the US. The title came from a 2019 post. By chance yesterday @Darma’s is asking the question about his 2018 Prius.
    In most cases high temps are caused by failing water pumps which still push enough coolant at low loads. If you have to refill the coolant as the original member stated, there is a leak somewhere or the system got so hot the reservoir pressure relief cap opened..
