Owners manual oil consumption
Discussion in 'Gen 3 Prius Technical Discussion' started by changingtime, Apr 15, 2024.
Tags:
  1. changingtime
    changingtime New Member
    Columbus, OH
    Has it ever been discussed…as to why Toyota put in the owners manual not to be concerned if oil consumption is less than 1.1qt for 600 miles?
    What is the rational there? Hoping for a technical explanation.
    mine was about a half quart (maybe less) down at ~1000 Miles of driving.
    2010 recently purchased at 175000 from a friend - who knew about all quirks
    Original Head Gasket - Toyota dealer (master mechanic) put on compression test / held compression
    EGR and manifold cleaned recently (egr fan? Replaced)
    Once in a while minor rough start on engine
    Original batteries passed test
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    I have a 2011 Gen 3 with ~200k on it, and a 2017 Prime with ~90k on it. I change the oil every six months on both vehicles. Once beyond the first 5k miles, I have never seen any loss of oil.
  3. Mendel Leisk
    41,860
    Isn’t that a mind blower? I’ve proposed here a few times, that gem should be prominent in the sales brochures.
    Specifically with Gen 3, model year 2010 till partway through 2014, Toyota used what’s commonly referred to as “low tension” piston rings, rings with less outward spring, presumably to reduce friction, gain a tenth or two of a mpg.
    There are a couple of service bulletins (test and fix, attached), for excessive oil consumption. In the test the criteria for excessive (bad enough to warrant a free fix) is (slightly more reasonable) one US quart per 1100~1300 miles. There’s another criteria, basically Toyotas ace in the hole: has to be under 60k miles on the odometer.
    “Recently purchased with 175k” and “minor rough start” does not bode good. Yes you’ve cleaned EGR, hopefully completely, but 175k is long overdue. It may have a stop-leak product masking symptoms.
