Toyota prius gen4 plug in 2016-2022 heat exchanger bypass?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Tony1988, May 17, 2024.
  1. Tony1988
    Tony1988 Junior Member
    27
    Sweden
    2020 Prius PHV
    Will all the heat exchanger brake after some time? Should u do the bypass before it brakes?
    If i still got waranty of the car, should toyota service change the heat exchanger for free even if it not have broken already? Some TBA thing i read.
    Cant fint the parts that he shows in the video on autozone for bypass.
    Cant linc youtube video , get error so:
    Youtube:
    Gasket masters
    How to prevent prius head gasket failure
    Thanks
    51,732
    1) i don't think so
    2) warranty is different in every country. you need to contact the dealers and/or toyota
    3) search for parts on ebay and etc.
  3. Mr.Vanvandenburg
    1,349
    568
    2020 Prius Prime
    I don’t know if anyone has addressed the issue of exhaust gas leaking out of the damaged converter, if the bypass is done?
  4. sylvaing
    sylvaing Senior Member
    1,210
    514
    First time hearing about this.
  5. Mendel Leisk
    41,157
    Coolant can leak from the radiator inside the Exhaust Heat Recovery System, but that doesn't mean exhaust flowing through the shell around the radiator can escape, anywhere other than the tail pipe.
  6. BiomedO1
    3,368
    1,755
    SacTown, Ca
    DO NOT bypass a good exhaust gas heat exchanger. The coolant on the other side of the exchanger will keep the seals/soldered portions from melting within the hot exhaust gas stream. Removing the coolant from the exchanger will ensure break-down and eventual failure of that part. In Sweden, I would think you'd want your passenger cabin as warm as you can get it in the winter months.
    Just my 2 cents..
  7. Mr.Vanvandenburg
    1,349
    568
    2020 Prius Prime
    I phrased it wrong. Addressed the possibility of exhaust coming back through the emptied bypass lines. I saw the comments but don’t know why suddenly the hole that leaked coolant is not there. So exhaust would be leaking out under the car.
  8. Mendel Leisk
    41,157
    I don’t see why a hole in a radiator (likely a tiny crack), enclosed within an exhaust pipe cylinder, would cause an exhaust leak.
  9. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    If the exhaust Heat Recirc system was bypassed AND the heat exchanger coolant inlet and outlets were not capped, an exhaust leak could happen.
    If the Recirc valve is not permanently forced into its warmed up position after a bypass, exhaust gas will be partially restricted as it flows past the exchanger.
    #9 PTS, May 19, 2024
  10. Tony1988
    27
    Sweden
    2020 Prius PHV
    Yes You should plug them to i understand, with Hose.
  11. black_jmyntrn
    black_jmyntrn Senior Member
    1,721
    404
    2013 Prius Plug-in
  12. Tony1988
    27
    Sweden
    2020 Prius PHV
    but I think that you need a bypass on pipes / hoses that go through the exhaust thing too, otherwise it will leak out exhaust gases and you will get a fail dote on the annual inspection?
  13. Tony1988
    27
    Sweden
    2020 Prius PHV
    Can a normal bypass hose handle the heat of exhaust gases or do you have to weld them together with steel pipes?
  14. bisco
    51,732
  15. black_jmyntrn
    1,721
    404
    2013 Prius Plug-in
  16. Tony1988
    27
    Sweden
    2020 Prius PHV
    Yes i read your stuff , cant se u bypass the steel pipes to?
  17. black_jmyntrn
    1,721
    404
    2013 Prius Plug-in
    lost me there...
  18. Tony1988
    27
    Sweden
    2020 Prius PHV
    So The smog dont leak out
  19. rjparker
    10,001
    6,187
    Just cap the steel pipes or connect them with a radiator quality hose.
    #19 rjparker, Jun 7, 2024
  20. Tony1988
    27
    Sweden
    2020 Prius PHV
    do we know what dimension it is on the outer dimensions of the pipes?
