EMERGENCY - son stranded - all lights, RTOD, flaky
Discussion in 'Gen 2 Prius Main Forum' started by ironandsteel, Jun 15, 2024.
  1. Tombukt2
    8,842
    1,542
    That's all the possibility maybe it's broken down and causing an electrical problem inside the tranny or it's been replaced with the wrong fluid and it's now just starting to rear it's ugly head I don't know. I would check to see if there's a subcode for the 3102 looking in the freeze frame data or whatever If there is get it and then we need to see what all that business is about usually is three digits you know like 325 or 697 or 611 some kind of stuff like that and that leads you at least somewhat out of the darkness I guess but yeah generally transmission problems are not too good I don't know if that's transmission that's just transmission ECU or something so maybe it's just miscommunication because of faulty 12 volt or Mary ads of other things We do know we have very good 12 volt on this vehicle they're no issues there It can stand 5 or 10 minutes being on without plummeting into the toilet voltage wise?
  2. Leadfoot J. McCoalroller
    7,120
    6,669
    Pennsylvania
    2018 Prius c
    AFAIK Dr. Prius is blind to all Cxxxx codes (and a bunch of others too).
    Chances are those chassis codes are not all simultaneously active.
    There isn't a code for an exhaust leak, but depending on where it is it could create circumstances that would cause you could pick up emissions-related errors like the P0420.
  3. ironandsteel
    ironandsteel Junior Member
    26
    Yesterday I installed a new DieHard battery in the car. Today, I am seeing several icons (that I don't recall seeing yesterday).' I have ABS, the car with swervy lines, ((!)), CEL, maint req'd.
    I got techstream running and hooked up. I did a health check- and I have not yet gotten it to tell me any codes. It shows a table of results in red, but I click on one and it doesn't show codes. I clicked the clear all codes button, and it confirmed that I wanted to clear and I did- but I still have the icons. I need to learn this thing.
  4. ironandsteel
    26
    Since the previous post, I let the car sit for a few days. This morning, I plugged in my Nexas ODB2 dongle and ran Torque pro. It reported no codes. AND- the various icons on the dash are off! It healed itself, I guess.
    Bear in mind that it has a brand new 12v DieHard battery. I drove it around a bit this morning and it seems fine. I do need to fix the exhaust- muffler totally broken off from the mid pipe. But other than that, I wonder if I can trust this car for a while?
    I plan to hook up TechStream again and see what it reports.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,415
    1,475
    NJ-USA
    FYI, Torque is very limited in what it can do (just "generic" ECM functions and some stuff from hybrid control and battery ecu's). I would recommend using Techstream to scan all systems for codes.
    You can also look at other scantools - here is a review of several apps and devices. Some are "all system" capable.
    https://priuschat.com/index.php?posts/3290690
  6. ironandsteel
    26
    Point taken, but what I find interesting/annoying is the dash trouble icons (mostly ABS related) suddenly being gone, without be doing anything. They seem like a chimera.
