P3020 after battery work- Mod 10 service plug disconnect?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gumbercules, Aug 3, 2019.
  1. Prius RT
    Prius RT Member
    114
    I wanted to verify if my hybrid battery was replaced with NEW. Believe in "Trust but verify".
    This is the next project. Hopefully I can tackle this in 2 weeks. Will be getting a new part likely from olathetoyota. Have to figure where to do the labor. Absolutely need person with gen 2 Prius ABS pump replacement experience
    #41 Prius RT, Jun 21, 2024
  2. rjparker
    7,957
    4,709
    A hate to be a master of the obvious but if you need alternative shops tell us where you are…
    Also it’s bad form to post your comment inside someone else’s quote. Most won’t even realize it’s there.
  3. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    No sorry. This is the newest label, and I haven't found any information to decode it if it even contains the manufacture date.
    The Toyota label has 240118 printed on it. This may be 24 Jan 2018 but it also be 18 Jan 2024. Do either of these make more sense than the other?
    The 24 you see is likely not a year code. The 47031 that forms the '4' you are looking at is the first number of the second half of the part number - G9510-47031
    It is possible that the first 7 digits (0F2PA42) may contain date information but I don't know the decode at present.
    He is in Las Vegas, NV according to his location in his bio.
    #43 dolj, Jun 22, 2024
    Prius RT likes this.
  4. Prius RT
    Prius RT Member
    114
    It's a toyota dealership. Highly likely it's a NEW battery. I have had some bad incidents at local mechanic shops here which is the reason I like to verify.
    I went in with a quote to replace hybrid battery.
    On the flip side, I probably may not have needed a replacement..it probably could have been just some wires going bad...overheating and possibly dirt. I only got p3000 p3020(i did not get p0A80). In searching this forum, one guy who had this had to just replace the wires.
    This is probably what happened
    Cabin air filter was super dirty. Caused the blower motor to run sometimes and sometimes not. The day before I got red triangle, I remember I had turned on AC for several mins (partly when i was parked) and it was not coming on because of dirt in blower motor. This may have overheated H battery and then the H battery fan almost started continuously blowing.
    The times when AC won't start for several mins, I stop the car remove the cabin air filter and manually give that blower a few rotations. Then I start the car, magically the AC starts immediately .
    Have replaced the filter. Will be replacing blower assembly next week.
  5. Prius RT
    Prius RT Member
    114
    So replaced the ABS pump at the Toyota dealership for a hefty price.
    Pump no longer buzzes every 10 secs .
    However , when I brake , most of the times, I hear the pump buzz (much fainter than before). Is this normal ?
    It's been only a week. They did the brake bleeding as well.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,502
    NJ-USA
    On my car, the pump will run about every 2-3 stops (brake pedal depressions). Depends on how hard I press on it.
    #46 mr_guy_mann, Jul 4, 2024
  7. Prius RT
    Prius RT Member
    114
    AFTER with NEW Part:
    I noticed if I press brakes partially( deceleration), I don't hear the chirping.
    But if I press it completely, I almost always hear it. And if I have pressed the brakes for say 30 secs and am waiting in an intersection , I hear it twice. And sometimes I also hear it soon after I release brakes.
    The chirping is much fainter than before with the old part.
    BEFORE with OLD part:
    Before it was every 10 secs continuous irrespective of pressing brakes or not. And would chirp when I open the driver door even without car started.
    Chirping was much louder then
  8. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    brake "chirping" is due to air bubbles in the small fluid passages in the ABS system. It can sometimes be fixed by a well done brake bleed. That worked for me in my 2004 Prius.
    JeffD
  9. Prius RT
    Prius RT Member
    114
    Thank you. Is there any issue if I just ignore this chirping when braking ? Can this (air bubble in brake fluid) cause any problem in future ?
  10. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your brakes are a critical safety item. Have the brakes bled as it is not an expensive procedure. If the chip remains, you have to look at the ABS manifold for leaks. I would not let the "chirp" remain in my car/
    JeffD
