Project Lithium Soother Test
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Mar 16, 2024.
  1. ChapmanF
    15,402
    Hmm, I started writing this before #180 was posted ... guess I'll still ask. @mudder?
    It seems two different risks have been mentioned here:
    1. TMR's don't-try-this test mentions the risk of contacting the battery output terminals with the service plug removed.
    2. mudder's #180 warning mentions voltage existing across the service disconnect terminals.
    In a way, these aren't completely unfamiliar risks; they can also exist in any battery for which a P0AA6 is being reported. That's part of why Toyota officially says to always glove up to plug/unplug the service disconnect, even though people often don't bother. I hope people do bother if they are working on a P0AA6 code, even if they are more relaxed about it at other times.
    And, of course, if the car could try to go READY with the service plug out (which P0A0D ought to prevent), then full battery voltage could appear across the service plug terminals (concern 2), because the + and − ends would be effectively joined then through the not-yet-charged inverter capacitors. And I suppose the soother does effectively connect even the far ends at all times, just through the Thévenin-equivalent impedance of a bunch of overlapping dividers.
    I haven't calculated that effective impedance. I also haven't calculated the effective impedance of the path around the service plug, if you expose yourself to the voltage across the battery + and − ends (concern 1).
    What I'm trying to get at is a rough idea of the current to which you could be exposed. This seems a little tricky to calculate (Thévenin-equivalents of some overlapping voltage dividers as well as whatever is contributed by the circuits surrounding and powering the opamps) and might be quicker to just measure.
    Would it take long to just pull the service plug on a battery with a soother installed, then apply a few different resistances across the battery + and − ends, in series with an ammeter, and measure what current flows?
    One might start with a resistance around the 100 kΩ of dry unbroken skin, and work down to lower resistances closer to 500 Ω like a wet or broken-skin path across the body. (What's the lowest resistance you'd say could be put across the battery + and − with the service plug out, without smoking the soother as in your video?)
    Then we could see where those measured currents line up on a scale like this one:
    Fred_H and mudder like this.
  2. mudder
    mudder Member
    78
    134
    Chattanooga, TN
    I agree with your test method. If someone wants to safely perform it, I'll comment on their findings.
    With the service disconnect plug removed, the Signal Soother's Thevenin-equivalent is essentially a 500 ohm resistor in series with a ~35 volt source (i.e. QTY10 cells in series; specifically those cells in blades 4 & 5).
    For completion, there are also a couple non-linear components that I'm ignoring (i.e. the opamp's power input and the zener diode, which is essentially 0 ohms once it breaks down). These are both in parallel with a 100 nF capacitor. You can essentially ignore all three components due to how the zener diode would behave once it avalanches (at ~36 volts).
    So then worst case we're looking at ~400 mA current @ 250 Vpack, which is certainly 'yikes' territory.
    #182 mudder, Jun 25, 2024 at 8:46 PM
  3. AzusaPrius
    AzusaPrius Senior Member
    1,819
    809
    @mudder
    I find it funny that you are the one talking about your lab tests and findings without actually testing on a prius vehicle.
    Maybe pay me to fill in where you are lacking an actual real life test on a prius?
    How am I the one to prove your theory of danger with a soother installed?
    I have time this week and I may entertain
    But for now everyone should know the soother is working with no danger and no fires or smoke at this time.
    Time is money though and it is time to pay the piper, so either you figure out a way to get a loaner prius and prove to everyone what you are claiming or well you know what to do...put that bounty out buddy.
  4. fuzzy1
    10,138
    There comes a time when you are in a hole, it is best to quit digging deeper.
    Grit and mudder like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,191
    5,885
    Columbia, SC
    Everyone else finds it funny that that you think "lab" testing performed in a logical, repeatable manner is not valid, but all your "butt-meter testing" is irrefutable evidence.................
    Of all the gizmos and "upgrades" you have on your car, how many do you think were actually developed without "lab testing"? Were they ALL actually tested on a Prius? Do you think the TB company actually installs every model of their throttle bodies on a car and dynos it or does long term testing to validate their claims? Do you think every aftermarket part is actually installed and tested on a vehicle?
    Grit, Xeico, mudder and 1 other person like this.
  6. mudder
    mudder Member
    78
    134
    Chattanooga, TN
    Not sure what happened to my previous post. Did it get deleted on purpose, or was it a forum issue?
    Regardless, I'll summarize it again below:
    OK.
    I've been quite clear why I tested on the bench, rather than in the car.
    State your terms.
    Because you have 1) a Gen3 Prius, and; 2) a Signal Soother.
    Imagine all the points you'll get when you perform the test and nothing happens.
    Sweet, let us know how it goes.
    That's great. I haven't made any claims that would preclude that from happening when the pack is in good health.
    You do understand what the Signal Soother does, right? If so, why have you left it installed?
    State your terms.
    Reminders:
    My primary focus here is customer safety. I think we probably both agree that we want safe aftermarket lithium in our cars. I believe I have overwhelmingly shown (on the bench) that the existing NexCell products I've reviewed are unsafe, hence why I've shared that knowledge here.
    As I've mentioned numerous times now, if the V3 NexCell product overcomes the numerous safety issues I've outlined, I will state that in my review. I'm not out to get Jack, per se, but I can't sit by idly as long as he continues selling unsafe products.
    Grit likes this.
  7. Brian1954
    Brian1954 Active Member
    786
    297
    South Central PA, USA
    I am assuming that the moderator deleted the 3 or 4 posts that I had read earlier and are now "missing". I also assume that someone requested that they be deleted.
  8. AzusaPrius
    1,819
    809
    Probably mudder or tmr-jwap, it seems as though they say whatever they want and then when I comment back and it hits home and somehow hurts their feelings, they report it and it gets removed.
  9. mudder
    mudder Member
    78
    134
    Chattanooga, TN
    Not me. Note that it was only tmr's and my posts that were removed... so your theory doesn't make sense.
    Nothing you've written 'hits home'.
    Grit likes this.
  10. dolj
    dolj Senior Member
    7,627
    3,848
    Wellington, New Zealand
    ^^^^ That's what I was thinking too - at least it wouldn't make sense for mudder to report his own post and have it deleted.
    However, the last post I saw penned by AzusaPrius (that is now gone) was just a multi-paragraph ad hominem rant, so could understand if a moderator deleted it without needing a report. The post is no loss and there certainly wouldn't be any 'hitting home' or 'hurt feelings' involved.
    #190 dolj, Jun 29, 2024 at 1:33 AM
    Grit likes this.
  11. AzusaPrius
    1,819
    809
    Yea mudder wouldnt report his own post, that makes sense for sure, he would however report comments to him that he doesnt like.
    So would tmr-jwap.
    I believe there was 3 comments removed.
    Anyway carry on and pound that hateraid.
  12. ASRDogman
    ASRDogman Senior Member
    6,041
    3,243
    blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah
    Grit likes this.
  13. TMR-JWAP
    6,191
    5,885
    Columbia, SC
    This is some funny stuff. I'm not even aware of any of my posts being removed? How the heck would one even notice? I don't memorize how many posts I have and rarely look back through threads unless I'm searching for something specific. I couldn't care less what you post about me or to me, as they typically just make you look more foolish than anything else. I have no reason to report any posts...why bother. I have yet to see any post you've made that has been of any significance.
    If there's an admin available, please feel free to post how many "report posts" requests I've ever made since becoming a member. Maybe throw a number up there for Azusa also, if he's ok with it. Let's see some facts.
    Grit likes this.
  14. rjparker
    7,913
    4,676
    It is true a complaint of hurt feelings may cause a moderator to delete
    Grit likes this.
  15. Grit
    Grit Senior Member
    6,138
    4,053
    Wilkes Land
    Feelings over facts. That’s how people and politicians are guided now.
  16. ChapmanF
    15,402
    One from me and one from ASRDogman also went away, though I see ASR has reposted his, carefully edited to convey the same wisdom in under half the original words.
    #196 ChapmanF, Jun 29, 2024 at 11:08 AM
  17. TMR-JWAP
    6,191
    5,885
    Columbia, SC
    I read this and decided to scroll up to see what ASR post you were talking about. This is actually pretty darn funny!
    Explain to me how you guys know that posts has been deleted. Does everyone just remember every single post they make and then notice it's gone? or is there an email notification or something similar given to the poster?
    #197 TMR-JWAP, Jun 29, 2024 at 6:22 PM
  18. ASRDogman
    6,041
    3,243
    If you follow the thread, you'll notice missing post.
    Except I didn't notice mine missing! :eek:
    I guess "blah blah blah blah..." is offesive!
    Usually a post is deleted because it has nothing to do with the subject of the thread.
    Or one person is starting to write nasty things about someone because they are easily offended....
    And someone reports it....
    I've blocked most of the know it all's so I don't see them. :whistle:(y)
  19. ChapmanF
    15,402
    Nah, I don't remember every single post I've made, but if it was recent, I can certainly think "gee, sure feels like I remember writing something here, like I even kinda remember what I wrote, did I forget to post it? Did the system hiccup? Did I imagine the whole thing?" And sometimes I'll remember a post by somebody else if there was something interesting about it.
    For the record, I don't know who requested deletion here (or if nobody did, and the mod just didn't like the posts). Any request didn't come from me.
    Back in March on page 2 of this thread, when black_jmyntrn faked a [quote]...[/quote] from me and claimed it was something I'd edited out of an earlier post, I reported that, but I didn't ask for the post to be deleted, just for a mod to weigh in on whether that level of dishonesty is ok here. (I'm a little sorry it did get deleted, as a later reader who got curious what that fuss was about would have to try something like the wayback machine to piece it together.) In general, I'm not a huge fan of posts going away, just because it can end up leaving little mysteries like that.
  20. mudder
    mudder Member
    78
    134
    Chattanooga, TN
    OK, so then we've verified there were several posts removed. I trust that our moderators are neutral and their actions were valid.
    Let's get back on topic:
    @AzusaPrius, please state your terms for testing SS in your Prius. I don't mind paying a reasonable bounty, particularly since this test will likely destroy your Signal Soother. Based on my bench results, replacing R41 & R51 with new 1k0 0603 parts should get it working again. I will offer to repair your SS (if required) after you perform the test; you'd need to send me your SS, and then I'd send it back. However, I don't recommend leaving the SS installed, but that is ultimately your choice.
