Understanding the Included charger
Discussion in 'Gen 5 Prime Charging' started by Jake Armitage, Jul 30, 2023.
  1. Jake Armitage
    Jake Armitage New Member
    2023 Prius Prime
    SE
    Currently, I'm using the included charger to charge my Gen 5 in a standard 120v outdoor outlet. It usually charges in about nine hours. I would like to shorten that time. What is level two charging; Is that just a matter of plugging the included charger into a 240v outlet, or do I need an actual level 2 charger?
  2. Tideland Prius
    16,623
    Level 2 AC charging is charging at 208-240V. Power ranges from 3.3kW to 19kW. I believe the new Prime is still limited to 3.3kW?
    I don’t think the Toyota supplied charger (technically called Electric Vehicle Supply Equipment or EVSE) has the plug type of a 240V outlet.
    You’ll need both the outlet and the EVSE/charger unless you hardwire a Level 2 EVSE.
    If you go the plug route, the typical outlet is a NEMA 14-30 or 14-50. The second number (30 or 50) is the rated amperage of the outlet. 14 is the design type. The other typical outlet is NEMA 6-50 - this one is 208V 3-phase.
  3. Mr.Vanvandenburg
    1,358
    596
    2020 Prius Prime
    The fairly inexpensive evse’s for sale online, many can use a 6-20 240 volt outlet. That’s all is needed to charge a Prime. Any 20 amp outlet can be converted to a 6-20 receptacle and by installing a 20 amp 240 circuit breaker. Done by a licensed electrician of course.
    #3 Mr.Vanvandenburg, Jul 30, 2023
    RandyPete likes this.
  4. bisco
    52,417
    Yeah, just get an adapter for yours
  5. douglasjre
    douglasjre Senior Member
    2,206
    737
    Null, NL
    I'm confused. Wouldn't a 3 phase be 480V?
  6. Tideland Prius
    16,623
    I guess 208V can be both single and 3-phase. 208V 3-phase probably goes to commercial? 480V to industrial?
    fuzzy1 likes this.
  7. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I wired a short adapter to convert the standard Nema 5-15 (15A @ 120V) to a L6-15 (15A @ 240V) and plugged it into a 240V outlet wired to a 20A breaker.
    Obviously, this adapter does not meet code and I put lots of warning labels to deter anyone from plugging something else into the end. The end result is the car charges much quicker and it only takes about 11kWh to fill the car rather than around 14kWh.
    As an additional warning, do not cut off the plug on the OEM adapter as it has thermal sensors inside.
    #7 NullDev, Jun 30, 2024
    PrimeDan, RandyPete and mountaineer like this.
  8. douglasjre
    2,206
    737
    Null, NL
    I'm even more confused now
  9. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    Yeah... AC is not the easiest to grasp sometimes. Perhaps this drawing can help?
    It's a 120V (phase to neutral) 3-phase system. You get 208V by connecting between any 2 phases. Most 240V appliances will function at this lower voltage, but they may pull more current to make up for it.
  10. douglasjre
    2,206
    737
    Null, NL
    I've never seen a 208 volt single phase AC supply. My question was about the 208 vault single phase. Does that exist somewhere?
  11. fuzzy1
    10,603
    All 208s I've ever heard of, were between two 'hots' of 120V 3-phase. A.k.a. 120/208V. When someone calls this 'single phase', they probably usually mean the particular branch circuit has only just two hot lines from 120V 3-phase, without the third phase or a neutral. So such individual branches don't have 3-phase on them, even though the overall site service is 3-phase. Remember that 208V = 120V * sqrt(3).
    I haven't heard of a split-phase 104/208. Our common 120/240V residential service is technically split-phase, a special form of single phase. On a true 2-phase system (now obsolete, though one of my old college profs worked one in his youth before they mostly vanished), the difference between two 120V legs would be just 170V = 120V * sqrt(2). This gives the same smooth continuous power flow as 3-phase (or any balanced multi-phase), but without the wire savings of 3-phase.
    I believe the 480V systems are referring to the voltage between two 'hots' of 277 / 480V 3-phase. I.e. 277V hot to neutral, if a neutral is present.
    #11 fuzzy1, Jul 4, 2024
  12. fuzzy1
    10,603
    'Pirate' 240V to 120V adapters are now readily available on Amazon. Look for NEMA 6-15 / 6-20 / 5-15 / 5-20 on the output / socket side. Though buyer / user beware, these cannot be made code-compliant or pass any safety inspection, because they cannot be made idiot-resistant.
    I use a proper code-compliant 240V outlet and L2 EVSE at home, and started with some 'pirate' adapters for travel with the Toyota 120V EVSE, which seems to handle 240V just fine, though is still limited to 12 amps. But have now upgraded to a portable true-L2/L1 EVSE, to allow travel charging at my RAV4's full 7kW rate from 50-amp RV outlets, such as was available at the base camp of a recent multi-day event I was supporting (but not where I was lodging overnights).
    Old brochures listed this RAV4 at 6.6 kW, newer ones 7 kW, but this campground's voltage was slightly on the high side, giving me 7.3 kW. Worked great.
  13. Teez
    Teez Junior Member
    37
    Toronto
    2025 Prius Plug-in
    SE
    Can someone post a link to what they bought to make their OEM charger a level 2?
    douglasjre likes this.
  14. F-Elon
    F-Elon New Member
    NorCal
    2025 Prius Plug-in
    I can't post links yet, but this is what I got:
    You'll still need to wire up 240v NEMA 14-50 receptacle at your house. If you hire an electrician to do this, just specify that the receptacle should be NEMA 14-50 running off a dedicated 50 amp breaker. You won't need that many amps, but I am guessing this won't the last charging vehicle you'll ever own, so build in some future flexibility.
    If you already have a 240v receptacle at your place, then get the adapter for the proper receptacle. Just look up "EV Adapter" on Amazon. Should take you to the below from the resulting listings:
    #14 F-Elon, Jun 22, 2025
  15. Teez
    Teez Junior Member
    37
    Toronto
    2025 Prius Plug-in
    SE
    I have a Nema 10-30 (3 prong dryer outlet) that was installed in my garage by an electrician. I just bought this adapter from amazon in order to plug my oem level 1 charger into that outlet. Will this work to speed up charging time and more importantly will it damage the charger or car?
    https://a.co/d/4DJD1be
  16. bisco
    52,417
    It won’t speed up charging. It may damage the evse, but some say it will not.
    There are threads here on how to convert the oem evse to 240v level 2.
    If the dryer outlet has a big enough breaker, it will supply enough juice to a level two evse to halve your charge time
  17. rjparker
    10,579
    6,635
    These are not "chargers" which is why the correct name is Electric Vehicle Supply Equipment or EVSE.
    The charger is in the car. What a EVSE has is a way to tell the car how many amps are available from this particular installation. Some have timers.
    208 vac single phase is typically available from light commercial 3 phase systems. There are many voltage levels of three phase which goes from thousands of volts in high voltage lines to 240 vac for light commercial.
    Even typical 240 vac residential comes from one leg of a higher voltage three phase provided through the utility transformer.
    These are the typical utility company secondary transformer to residential and light commercial panels as used in the US.
    However some older, slightly upscale residential neighborhoods came with three phase 4 wire 240/120 vac utility feeds and panels. One neighbor with a 2000 sqft house has three phase and only recently replaced their original GE 3 phase ac system which required no run capacitors and operated more efficiently than single phase units from that era.
    #17 rjparker, Jul 15, 2025
  18. BiomedO1
    4,221
    2,204
    SacTown, Ca
    That'll work, but it's not going to speed up charging. It's a 220 to 110 AC adapter plug. The description states that it's 125VAC output; so it's only pulling current from one of the 'hot' wires in that 10-30 outlet. You need to pull the full 220VAC out of that outlet to get it to a level 2 charger.
    Hope this clarify things......
    Teez likes this.
  19. Teez
    Teez Junior Member
    37
    Toronto
    2025 Prius Plug-in
    SE
    Thanks for explaining this, Is there an adapter that will pull the 220vac out of my outlet in order to speed up charging time with the oem charger? Or do I need to buy a new level 2 charger?
    I had a level 2 charger plugged into my 220v outlet in my garage but the charger broke so i was trying to see if there was a way to use my oem charger with this 220v outlet to speed up charging time and save me money on buying a new charger. I don't want to rewire anything, just looking for an adapter that might work that won't mess anything up. Any suggestions appreciated. I am not very knowledgable about this sort of electrical stuff.
  20. bisco
    52,417
