Is there a legitimate use for charge mode in the Prime?
Discussion in 'Gen 5 Prime Charging' started by Will B, Oct 27, 2023.
  1. dbstoo
    dbstoo Senior Member
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I'll ask again... What are the GPS co-ordinates of that stretch of hill where the car continues to pick up speed forever without any braking" ? Again, I remind Paul G that the car in question is a 2024 Prius Prime, not some other car. It's being driven in the normal D mode. And the phrase used by Paul G was "pick up speed" forever.
  2. ChapmanF
    15,490
    There are grades where you will pick up speed forever, even with all the engine braking the car can do—depending on your speed at the start.
    For any downgrade, there will be a speed where your energy gain from gravity just equals what the engine can twirl off (somewhere around 13 kW in a gen 3, anyway), and engine braking can just manage to hold that speed steady. Start off below that speed, and there's plenty of engine braking to hold it or slow you. Right at that speed, holding steady is possible, and above it, you'll be picking up speed.
    On a tame grade, not much to think about because whatever speed you're likely to drive will be below that critical speed.
    On a very steep grade, you may have to choose a speed a lot slower than you'd like to drive, if you want the engine braking to be able to maintain it.
    fuzzy1 likes this.
  3. Paul Gregory
    Paul Gregory Active Member
    434
    118
    Alberta
    2024 Prius Prime
    XSE
    Maybe it never happened because someone was actually paying attention while driving. It happens. They likely applied the friction brakes, or is they were smarter, they engaged the engine brake. No one wants to overspeed down a hill.
    It is there for a reason.
