Is there a legitimate use for charge mode in the Prime?
Discussion in 'Gen 5 Prime Charging' started by Will B, Oct 27, 2023.
  1. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I'll ask again... What are the GPS co-ordinates of that stretch of hill where the car continues to pick up speed forever without any braking" ? Again, I remind Paul G that the car in question is a 2024 Prius Prime, not some other car. It's being driven in the normal D mode. And the phrase used by Paul G was "pick up speed" forever.
  2. ChapmanF
    18,030
    There are grades where you will pick up speed forever, even with all the engine braking the car can do—depending on your speed at the start.
    For any downgrade, there will be a speed where your energy gain from gravity just equals what the engine can twirl off (somewhere around 13 kW in a gen 3, anyway), and engine braking can just manage to hold that speed steady. Start off below that speed, and there's plenty of engine braking to hold it or slow you. Right at that speed, holding steady is possible, and above it, you'll be picking up speed.
    On a tame grade, not much to think about because whatever speed you're likely to drive will be below that critical speed.
    On a very steep grade, you may have to choose a speed a lot slower than you'd like to drive, if you want the engine braking to be able to maintain it.
    fuzzy1 likes this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,121
    555
    Alberta
    2024 Prius Prime
    XSE
    Maybe it never happened because someone was actually paying attention while driving. It happens. They likely applied the friction brakes, or is they were smarter, they engaged the engine brake. No one wants to overspeed down a hill.
    It is there for a reason.
  4. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    The first time I saw the Energy Monitor graph after going down a steep drop starting at different speeds I called it dynamic regen. That was a long time before I understood anything about how Prius decides which way and how much to use its breaking and / or regen. A lot of owners most likely ever notice those differences.
    One difference I think most all of us could agree on regarding B mode is that it doesn't ever use friction brakes. At least not that I've ever noticed B using friction brakes.
    #124 vvillovv, Jul 6, 2024
  5. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    This is quite sad. Paul Gregory (or his bot) typed 5 sentences without ever addressing the point that I made and that he quoted. I've traveled over 400,000 miles in 4 Toyota hybrid models throughout the west and have never experienced the "pick up speed" forever that he's complaining about.
    One thing that I found disconcerting about the 2010 Camry hybrid's cruise control was that it would go into free-wheeling mode when cruise was set and the car was driving down hill. This is in direct contrast to the 2002 Prius cruise that would keep the speed steady even when going down a long, steep (6%) downhill stretch.
  6. ChapmanF
    18,030
    In my experience, gen 1's behavior was different. I drove a 2001, but I've never heard '02 or '03 were different.
    In my 2001, cruise control worked just the way it used to work in conventional cars, where it was only a servo that pulled on the throttle cable. It could give you more go as needed when heading uphill, but didn't have any way to give you less go when heading down. Of course it wasn't a servo pulling on anything, just some logic in the HV ECU, but it was as if they had just copied the cruise control logic from their other cars and pasted it into the new ECU.
    So in my gen 1, I did combine cruise with B mode, so it would do a better job of holding my speed on the downhills. In D mode in gen 1, it would tend to pick up speed.
    So when I replaced my gen 1 with gen 3, when I first discovered the gen 3 cancels cruise if shifted to B so you can't use them together, my reaction was unprintable.
    But as soon as I had observed the gen 3 cruise control using engine braking on its own in D mode to keep my speed on downhills, I stopped cussing and realized they'd made it more convenient. I no longer had to shift to B to get downhill speed holding with cruise, because they had just made it how the cruise control now normally behaves.
    MAX2 and fuzzy1 like this.
  7. Trollbait
    12,496
    I believe that the general evolution of cruise control in general. Now they might apply the brakes if need be.
  8. red00tl
    red00tl New Member
    Seoul
    2024 Prius Prime
    XSE
    I don't know what had happened to this thread asking for a legit use of Charge mode, but I'll throw my 2c in.
    The Charge mode is mainly for an emergency use of V2L in case of loss of power grid in natural disasters like an earthquake, which is a real concern in Japan. It can also be used for all the other good reasons that people have come up in this thread like having little bit of battery available for EV driving, at a camping site, etc. In all, it is an inefficient use of gas in any way you cut it, but now you know why it is in the car.
    Pardon my intrusion if the above was already public knowledge. You can resume your fights over B mode now. ;)
  9. Maxwell61
    Maxwell61 Active Member
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    Coming back to the topic: have anyone some OBD App to ascertain how many kWhs are produced by a given amount of fuel, and charging speed, when the car is standing still in Charge Mode?
    I want to make that test for two reasons:
    - This condition is totally equivalent to an EREV, i'm having a discussion about it with friends.
    - Not living in US or country where gas and electricity are cheap as hell (relative to EU), but in EU where the price of electricity for pay per use public chargers is 0,77$/kWh, i do suspect that could be even be cheaper using gas to generate electricity when you're not at home.
  10. sylvaing
    sylvaing Senior Member
    1,210
    514
    I guess Hybrid Assistant could be useful here. I'm assuming the car will just be parked. Get the data with and without Charge mode and see how much more Charge mode added to the fuel used.
  11. Maxwell61
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    I'm in contact with the 2 creators of Hybrid Assistant: one doesn't want work anymore on it for new cars, the other wants a car for few hours to cut short the development time. The latter is in France and i'm in Italy and the french users didn't answered the call... hence for the time being forget HA for Prius gen. 5...
    About your comment: if the car is parked, without Charge mode the engine will not start, impossible comparison. If the car is moving, it's very tricky making the comparison, the charging power varies wildly and so the efficiency of the recharge. The static condition is a quite interesting start.
    Here someone already attempted the comparison of FE with and without Charge mode in motion, but no coherent o complete data came out.
  12. Trollbait
    12,496
    Don't need a charge mode for emergency power use. With an installed inverter(factory or not), the car runs off the battery. The charge gets low, it automatically turns on the engine to charge up the battery until nearly full, and then turns it off. That is how the hybrid has worked since before Toyota released a plug in. The plug in may only bring the battery to the high charge for hybrid mode on its own, but manually using charge mode isn't going to result in less gas burned compared to just letting the car handle things on its own.
    Furthermore, Japan already has another V2L system in place for powering a house in emergencies that works with CHAdeMO equipped plug ins and even fuel cell cars. It is a 'power station' that is a home charger that allows the electricity to flow to the house. I think it came out during the first LEAF, and was available for the PiP.
    Charge mode is one of those things users think they need and demand, but is really of limited use; like EV mode on a no plug hybrid. When coming to a destination without a charger, and knowing the next trip could be done within EV range, it might be worth burning the gas in Charge mode vs on a warm up cycle, and the drawbacks on the engine from a short trip. Though with that thinking ahead, you could just put the car in hybrid mode to save EV range instead.
  13. red00tl
    red00tl New Member
    Seoul
    2024 Prius Prime
    XSE
    Oy boy, you think you don't need a charge mode just because the engine will automatically turn on to recharge as needed? The charge mode gives you the power to choose when and where to charge the traction battery by how much, isn't it wonderful? Think of it this way, in a hot summer night in Japan after an earthquake and the power grid is toast, you need the V2L from your Prius to run your A/C unit in a makeshift camp. Wouldn't you rather have the car on the Charge Mode to charge up the battery during the day at your convenience so that you won't have to put up with the engine turning on and off intermittently during the night to jostle you out of sleep? ;)
  14. Danno5060
    Danno5060 Active Member
    386
    199
    Wyoming
    Back to the original purpose of this thread (Not the use of the "B" mode), but a legitimate reason for using the CHG mode.
    If there's room to charge, it's like a pseudo-maintenance mode. When you can't remember the chicken dance to put the car in maintenance mode, and you've got room to charge the HV battery, and you want the ICE engine to run - to circulate engine coolant, or oil, or something like that.
    Will B likes this.
  15. Paul Gregory
    2,121
    555
    Alberta
    2024 Prius Prime
    XSE
    It doesn't seem like rocket science to me. Jump-starting is one of the simplest of operations. We jump-started something nearly every day when I was growing up on a farm. It doesn't take much concentration to remember to hook "-" to "-" and "+" to "+." Besides, hooking it up wrong is something you won't repeat, because it can result in a shower of sparks.
  16. Paul Gregory
    2,121
    555
    Alberta
    2024 Prius Prime
    XSE
    Happened today a bunch of times. People kept appearing suddenly in the view of the sensors, and it felt like I had hit a wall.
    Felt like being punched in the kidneys.
  17. Paul Gregory
    2,121
    555
    Alberta
    2024 Prius Prime
    XSE
    Like any battery, it has a limit for how much charge it can take. If you are descending a long slope, and the battery is full, it's possible that the energy needs to be dissipated somehow, but the options are limited to the friction brakes, which can overhead and be burned up, or through the engine drag, which would release the energy to the atmosphere as heat. It may be a rare situation, but it could happen, you may need some way to slow the vehicle to a safer speed. This is why the "B" (engine braking) mode exists.
  18. ChapmanF
    18,030
    That is a reason the engine braking mode exists, whether you apply it early by selecting B or just wait for the car to do so when the battery approaches 80% SoC.
  19. Paul Gregory
    2,121
    555
    Alberta
    2024 Prius Prime
    XSE
    What I find with my Gen 5 Prime is that when you need to reduce speed fairly quickly, such as when you adjust your cruise control down from 100km to 50, the engine revs quite loudly, while the regen gauge shows max regen. This didn't happen with my Gen 3.
    I think it would be a different story if you found yourself in the rarer situation of descending a long hill with a full battery that can't take any more regen charge. In that case you'd need more than just regular engine drag to dissipate the energy of the descent. You could either burn up the friction brake pads, or you could employ the "B" mode of engine braking. It only makes sense that "B" mode does more than rotate the gas engine. Safety demands it.
    #139 Paul Gregory, Feb 23, 2025
  20. ChapmanF
    18,030
    B mode has an influence on when engine braking is employed, but makes no difference to how engine braking is done.
    This is a spark-ignited gasoline engine with a throttle. It is used to engine brake by spinning it from the powertrain, while leaving the throttle closed, no different from the way Grandpa's gas-engine car did engine braking.
