Replaced hybrid battery - No power, won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bzbee, Jul 20, 2024.
  1. bzbee
    bzbee Junior Member
    37
    24
    2007 Prius with 160K miles. Last month it threw the red triangle of death with code "P0A80 Replace Hybrid Battery Pack". Techstream showed that Battery Block 11 had very low voltage (13.6v) compared to others (15v+). Car was running fine till then, but getting poor mpg (about 36-38). I stopped driving it immediately after the red triangle came up.
    Pulled the hybrid battery, tested each cell and sure enough one cell was dead (6.51v). I tested all other cells with a hobby charger. Most tested at about 7.8v and 4500mAH or higher capacity after 3-5 discharge-charge cycles. Only two cells were below 4000 mAh. I planned to buy three reconditioned cells and replace the dead & failing cells.
    While looking for reconditioned cells on Facebook, I came across someone selling a whole battery pack from a wrecked 2013 Prius for $200. Took a chance and bought the battery, and it turned out to be in great shape. All cells tested 8.0v or higher, and I randomly tested a few cells with 3 discharge-charge cycles and they all showed 5500-6000 mAh capacity. So I took that cell pack and put in in my 2007 battery and installed it in the car today.
    Was all excited, but when I pressed the power button nothing happened - no dash lights, no engine start, nothing. But the interior lights work, car locks and unlocks properly with the key fob.
    - I checked the orange service plug half-a-dozen times, and it is installed properly.
    - I removed the three connectors to the battery and reconnected them ensuring they are seated properly.
    - I checked that the small connector under the service plug is properly seated.
    - I disconnected the 12V battery (reads 13.2V with a multi-meter), waited a minute and re-connected it.
    No luck, car remains dead.
    What am I missing? What could've gone wrong? Is there a fuse or relay that could cause this?
    I want to test the voltage at the battery main connectors with the service plug installed, is that safe?
    Any suggestions on how to debug would be welcome. I am trying to avoid having to dis-assemble the whole battery again, but will do it if all else fails.
    Thanks.
    Meg&Bear likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,345
    5,396
    Pacific Northwest, USA
    I went through something very similar back when I worked on my first pack in 2018... In my case it was the positive voltage cable dropping down behind the voltage sensing harness and me not seeing it, so the circuit was never complete.
    But in general, there's over a hundred different connections that have to happen when putting a pack back together and its easy to overlook something.
    One thing you can try is very carefully measuring the voltage on the pack side of the relays with Orange safety plug in. That will let you know if the problem is on the battery pack side or on the car side...
    Another thing you can try is load testing each module for two minutes with a halogen headlight bulb (12V / 55W) and document how much voltage is lost. A healthy module will only lose .2 to .4 volts at the 2 minute mark. As in sometimes a bad cell will give a normal voltage reading, but soon as you put a load on it, the cell fails.
    landspeed and Meg&Bear like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Sounds like the 12v is good. The Gen 2 usually dies with similar symptoms when the AM2 fuse blows in the underhood fuse box. If this happened, it's normally due to the inverter cooling water pump failing.
    Any chance you reversed your 12v battery polarities during your repairs?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    I do not see a reason to look at the HV pack at all (yet). Whatever problem you have it's on the low voltage side. Do ANY lights on the dash work at all? Door ajar? Red security (key)?
    I would scan the car with Techstream and see what responds. I would check all fuses underhood and underdash. The basic symptom matches a blown AM2 fuse or possibly a failed capacitor in the Combination Meter.
    I might not expect a fault with the battery ecu to affect the Power Source Control ecu, but... You can check basic integrity of the CAN network by disconnecting the 12V battery. Then use a digital multimeter to check resistance across the OBD port pins 6 & 14. (Be careful to not distort the terminals). You should read about 60 ohms.
  5. bzbee
    bzbee Junior Member
    37
    24
    With the battery in the car and with the Orange Safety plug in, I measured the voltage at the two main (frame) connectors - it is ZERO. I read in another thread, that the voltage at the main connectors only shows when the car is in READY and the relays are closed.
    Removed all the brackets and pulled the bracket out again (what a chore!), and tested each cell. All tested between 7.5v and 8.0v. Then with the orange plug in, I tested voltage across the pack - 219.6v. So, I think the battery is good, might be the fuse as the @TMR-JWAP suggested.
    I will check the fuse.
    And yes, I was getting the P1121 code intermittently for the past year, was planning to replace the coolant valve but never got around to it. Will do it once I get the car started.
    Battery polarities - both 12V and the Hybrid are correct. Rechecked this morning.
    Yes, the door ajar light and the key light show up. It is not the combination meter failure, I am sure of that.
    I will check the fuses and test the CAN network as suggested. Will report back in the afternoon with my findings.
    Thanks for all the advice.
  6. PriusCamper
    13,345
    5,396
    I've never seen a relay go bad and have always doubted people who had that suspicion, but maybe that's worth checking?
  7. bzbee
    bzbee Junior Member
    37
    24
    This post talks about a "sticky" relay when car has been sitting unused for long. I am going to check that.
    Its been raining off an on and I couldn't work on the car this morning, but a quick check showed that the AM2 fuse is fine. Battery voltage is also good and showing 219.6V across the pack.
    PriusCamper and Meg&Bear like this.
  8. bzbee
    bzbee Junior Member
    37
    24
    Welp, I am out of options.
    I took the traction battery out, tested all cells, charged a couple of cells that were showing lower voltage compared to the others, then tested battery across the pack (221.6v) and at the points under the white caps before the main connection with the orange plug in - reading 221.6V.
    Charged and tested the 12V battery - 12.8V at the battery, and 12.7V at the fuse box. Tested the AM2 fuse and other fuses around it. All good.
    All functions of the 12V battery works - lock & unlock with key fob, interior lights, door ajar indicator in the dash, key missing (red key symbol) in the dash etc. Pumped the brake a couple of time and I could hear the whirring noise.
    Checked all three connections to the hybrid battery, and other connections within the battery. Didn't find anything disconnected or loose.
    It seems like the hybrid battery is not closing the relays and sending the current when I press the start button. What could cause this? Other posts I have read mentioned that the 12V battery has to read 10.8V or higher for the hybrid battery to allow power. Mine reads 12.7V, so should be good there. But going to try a jump start, just in case.
    Any other ideas about what might be causing this?
    Edit: Tried jump starting, no luck with the either :(
    #8 bzbee, Jul 26, 2024
  9. bzbee
    bzbee Junior Member
    37
    24
    Ok, I think the issue is not with the Prius traction battery or 12V battery at all. The car had a Hymotion battery pack in it that I removed before removing the Hybrid battery :oops:. I don't plan on putting the Hymotion pack back in, but I think the wiring and interconnects for the Hymotion might be causing the issue. I am an idiot for not considering it till now :D
    Read somewhere that there is a bypass under the dash that would close the loop and remove the Hymotion circuit from the flow. Will look for it before I start taking apart the dash.
    #9 bzbee, Jul 26, 2024
    Brian1954 likes this.
  10. Brian1954
    Brian1954 Senior Member
    2,597
    1,030
    South Central PA, USA
  11. bzbee
    bzbee Junior Member
    37
    24
    Final Update: Car started and is working normally. Yay :D
    The problem was with the Hymotion wiring and harness, and the Hymotion circuit needed to be bypassed.
    Many thanks to Forum Member @ericbecky from EVPowers.com. He took my call, gave me great advice and pointed me in the right direction. I was able to rig up a DIY bypass and with it in place the car started right up. I will post details about the fix in my other thread about the Hymotion kit removal.
    The Red Triangle is gone and there are no other codes, though I believe the P1121 coolant valve will pop up again once I start driving. So I am gonna replace that valve along with the front bearings before putting the car back in service.
    Thanks everyone for your help & advice. This forum is a great resource for DIY Prius owners.
