Car wont Start after Changing Battery Cells
Discussion in 'Gen 2 Prius Main Forum' started by Fedx2525, Sep 25, 2016.
  1. Fedx2525
    Fedx2525 New Member
    I recently tried open my hybrid batter to change the cells and when i did i replaced 4 cells. One of the treads of the cells broke as i was tightening it. I used steel puddy to put it together and the rest of the tread was still making contact with the brass connector so i figured it would still work soon after i put all back together and put the orange switch and made sure it was pressed down after the 90 degree angle and i tried to turn on my car. Would not start just get to the turning part and say problem then transmission failure message saying to park my car in a flat surface
    52,817
    welcome! if you're positive the orange connector is in correctly, i would go back and test the new silly putty connection. that seems like the most likely culprit. all the best!(y)
  3. Fedx2525
    Fedx2525 New Member
    Yea, I am guessing thats it, I purchased a new cell, sux since that one still had a good charge but the tread broke so its prob got connecting the way it should i tried testing it and it wasnt reading anything. So am guessing that is why its not working idk if anyting had a similar problem to. Also got any idea if i can us a Gen 3 Cell in the mix with my Gen 2 Cells?
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Before you strip down the pack again, did you try pressing the power button twice when you had the brake pedal depressed? This is required to get the Prius into the READY condition.
    Let us know if/when you get it corrected and what it was. Always helpful for the next person who attempts this DIY repair.
  5. Fedx2525
    Fedx2525 New Member
    I tried multiple attempts to turn it on by pressing down the brake and pressing the start a few times didnt work.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Having 30+ years experience in electronics/electrical work, all I can say is: Are you kidding me? You broke the threaded stud on a module and used steel putty to put it together? Did you break any wires and put them back together with gorilla glue? Maybe a hole in a radiator hose that you fixed with duct tape? I don't want to be disrespectful, but THIS IS THE EXACT REASON SOME DIYers SHOULD NOT TOUCH SOME JOBS. If you don't comprehend the possible consequences of a solution like this, you shouldn't be touching this job. This is no joke, to even think this could be satisfactory blows my mind. Even if you were able to get a good enough electrical connection that the sensors didn't pick it up, it has to be a fire waiting to happen due to a high resistance connection. This is a job that has to be done RIGHT, otherwise you put yourself and others at risk of breaking down, causing an accident, or causing an electrical fire in your car. Good GOD, this made my blood pressure spike!!! I'm not one to call someone out, but this is crazy.
  7. Fedx2525
    Fedx2525 New Member
    Well you sound rude a simple, Its not a good idea would do i am not a electrical pro, just some guy trying save some money and i thought this forum would help if i msg i didnt sign up to get criticized just get help and now i dont want want be using this forum anymore. All i wanted was help -.-
    vegan and bisco like this.
  8. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    You got some help and teaching on how to avoid frying yourself. The modules can be had on Ebay for pretty cheap. 200 Volts DC is nothing to sneeze at can put you in a grave or a hospital pretty quick it's nothing like 110V AC.
  9. Fedx2525
    Fedx2525 New Member
    Yea i got a meter tested each cell about 7.5 one was about 7.9. After replacing the broken one I started the car and after a bit of driving the triangle vsc and the circle with exclamation. Could it be because one the cells is higher then the rest? Not really sure also my hatchback handle stoped working but not sure if thats another issue or if its related
  10. jadziasman
    1,355
    488
    District 6
    There's more to a successful repair of a failed HV battery than just checking the open circuit voltage of each module and replacing known bad modules. Much more.
    Did you get the diagnostic trouble codes from the OBDII port underneath the dash by the steering wheel after the latest incidence of warning lights? This is the first thing you need to do to determine what's wrong with the HV battery this time around.
    It seems that you are either in a big rush to complete this repair because you don't have another vehicle to drive in the mean time or because you haven't learned enough from the best thread on this issue - Gen II Prius Individual Battery Module Replacement | Page 85 | PriusChat by ryousideways. This thread provides most of what you will need to know and do. There are other related threads that are also helpful.
    Unless you make the effort to learn the proper way to do a DIY HV battery repair, it's highly unlikely that you will be able to do one that will last several months.
    Do it right or don't do it at all.
  11. Fedx2525
    Fedx2525 New Member
    I did try checking for any issues but i had no check engine light so it did not let me know but i did have the other lights on
  12. Fedx2525
    Fedx2525 New Member
    I have checked all the cells and i have about 24 with 7.5 volt and 4 with about 7.8, I have also made sure the orange plug is put right, The car turned on and after a while of driving i got the Vsc and the Triangle light again. I checked the codes and it was reading nothing, After a while i turned off the car and it would not turn back on and i would hear a clicking noise in the back louder then normal when i would try to start the car. I figured if i clicked on the reset code button and tried to turn on the car i would let me. I havnt been doing that though i am trying find out what is wrong with it. Anyone had similar issues?
  13. bisco
    52,817
    what happen with the silly putty connection?
  14. jadziasman
    1,355
    488
    District 6
    Fedx2525, you are like a drowning man who is desperate for help but won't grab onto the life preserver.
    One more time (and that's it). The open circuit voltage is not all there is to this. You need to determine the
    capacity of each module under load to find the weak ones. Once you have, you can try to recondition them
    or replace them. If a module self discharges too quickly, it must be replaced.
    If you don't want to do the work correctly - hire someone who will. Before you drown. Sheesh.
  15. Fedx2525
    Fedx2525 New Member
    Already did that and replaced 2 that were discharging too quickly and 2 that where low voltage.
  16. jadziasman
    1,355
    488
    District 6
    Okay, maybe your HV pack is beyond hope. Too many Texas summers (and falls, winters, and springs).
    Since you seem adept at replacing modules, why not buy a new pack from a Toyota stealership.
    New packs can be had for as little as $2000 with tax or Texas Hybrid Batteries LLC could install it for you for $2199 tax included.
    Texas Prius Battery Replacement
    Your Prius might last many more years with one (assuming nothing else is wrong with it).
  17. Fedx2525
    Fedx2525 New Member
    So after getting passed the battery issues, i began to have catalytic converter issues so i replaced it and it came with gaskets that fited in quite snuged in there maybe a bit to snug but not sure I am getting noises louder then i should when i hit the gas and when the engine is on. Maybe i got the wrong gaskets. Anyone have a link to gaskets that will work for sure?
  18. drmingo
    drmingo New Member
    SC
    We just did a refurb on our prius battery. Taking it out, took all the cells apart and balanced them all. We then put it all back together, getting good 220V from the hybrid battery and 12.3 out of the standard 12v battery. Car would not start.
    1) As all the posts above, check the orange connector. It not only goes IN, but then has to be pressed DOWN to fully connect.
    2) Turn on your car and make sure all the codes have been cleared. If you don't know how to do this, search the internet, pretty straightforward, clear your codes.
    3) For those of you who have not done this, rebalancing the battery takes about a day per cell, and you have 28 cells to go through. So our car sat for about 6 weeks while we were doing the rebalancing. When everything was hooked back up it seems the hv relay was a little "sticky" and would not engage. There is no code that comes on, it's just the car will not start and all the warning lights are on. After troubleshooting it appears the hv relay is a key component of the hybrid system and allows the hybrid battery to connect to your car (it disconnects when you turn the car off.) It needs 10.8v to activate this relay, so make sure your 12 v battery is in good shape. You should hear some "clicks" when the relay activates when you push the power button. If you don't hear the clicks, the relay is most likely stuck. You can gently tap on these to help jiggle free the stickiness until they start clicking. Don't pound, this is an electronic device and can be damaged. Once we heard the clicking, the car came alive and all the warning lights disappeared.
    Hope this helps someone.
  19. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Thanks for the information. It might have helped when this thread was last active... In 2016 but I’m pretty sure it’s been worked out since the OP has not logged in over 2 years.
  20. George W
    George W Senior Member
    939
    520
    San Antonio
    This isn't a case of re-stripping a frayed wire going to your headlight. You broke a battery module. Then you thought it was more feasible to go it alone instead of coming here. If you learn never to do it again, the critic is justified.
