Considering a used 2020 Prius Prime - is this amount of rust OK?
Discussion in 'Newbie Forum' started by sidk, Jul 18, 2024.
Tags:
  1. sidk
    sidk New Member
    Montreal
    2020 Prius Prime
    Hi all,
    I'm considering buying this 2020 Prius Prime in Montreal. It has an average amount of mileage on it (75000 km, 47000 miles). It is a Toyota certified vehicle, but it shows signs of rust underneath. I haven't viewed it from under a lift, but here are some pictures I was able to take from the back of the car. Looking for advice/opinions on if the level of rust is acceptable and if you would go ahead with the purchase if everything else checked out.
    Thanks.
    PS. This is my first post here. Please let me know if this is the wrong place to post this.
  2. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    Pretty sure every four year old car in the entire province looks like that.
    vvillovv likes this.
  3. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    Cars in Florida don't look like that
  4. Mendel Leisk
    41,843
    Depends on your tolerance. I’m on the west coast, relatively mild winters, but still zealous applications of road salt. Slushy salt might actually be worse?
    anyway, about 4 years of ownership in, I saw the rust-bloom starting, didn’t like it. Opted to raise one end at a time, remove plastic panels, brush off loose rust and brush on boiled linseed oil. That’s worked well, with ongoing vigilance and a few touch ups.
    But yeah it’s a little over the top. I don’t think today’s cars are protected as well? Never saw this level of rust with our string of Hondas, in previous decades.
    nowadays, my wife and I both retired, when we do get snow and/or sub-zero centigrade temps, we’ve got the luxury to wait it out, and its garage stored.
    But street or parkade parked in Montreal, with a 5 day a week driving commute, that’s tough on a car.
  5. sidk
    sidk New Member
    Montreal
    2020 Prius Prime
    Thanks @Mendel Leisk . We will park it in a garage and don't drive much (5000 miles a year roughly) so I'm hoping that that will slow down the progression of the rust.
    Re: your process to deal with the rust, is there a reason you use boiled linseed oil, as opposed to something like Krown or the POR product? I also assume that when you say "brush off loose rust", you're not removing any rust that is "bonded" to the metal - is that right?
  6. Mendel Leisk
    41,843
    Yeah I didn’t get zealous on rust removal. Someone here recommended boiled linseed oil; I gave it a try, and it found seals well, lasts too.
    Last pic here gives some idea:
    Do you need underbody rust protection on new Prime? | Page 3 | PriusChat
  7. ETC(SS)
    7,326
    Look into the "certification" programme that Toyota uses and make sure that it's a real OEM Certified Used Car, rather than some 'coverage' that merely certifies that it's a used car.
    What kind of warranty and what is covered?
    Frankly, I live in a more or less habitable part of the globe.
    More, because cars only rust if they are imported from frozen wastelands above I-20 here in the US.
    Less, because our humidity and temperatures are usually tied in a race for triple digits.
    Our cars mildew rather than rust - but I am a little curious about a 'certification' process that fails to take note of what I consider to be a lot of rust. I would ask the dealership some frank questions about this and get detailed info about coverages for things like exhaust components and other underpinnings.
    Then?
    Take a look at some numbers and decide.
    Rust is like the cancer that it is often compared with.
    Just parking your car in a garage isn't going to mitigate this, and unless you invent a time machine(*) you are unlikely to make it go away completely.
    Consider the time and effort required to treat the rust that's already eating away at your car against its cost. You will need to also need to estimate how long you need the car to remain economical to operate and compare this with a mechanic's estimation of it's life expectancy.
    A mechanic that doesn't work for the dealership.
    Oh - and if you DO invent a time machine, I'd shove a few cats through it FIRST.....just to make sure it works, and if you go back, buy some Bitcoin.
    This way you will be able to afford a new car - ;)
  8. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    I'm a big fan of Phosphoric Acid, it turns rust into a black substance that arrests further rusting. The POR products combine Phosphoric Acid and Epoxy paint to seal and protect the metal: this works great for ambient temperature parts....not so good for exhaust and other hot metals.
