A C compressor causing P0AA6 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seymour1, Jul 19, 2024.
  1. Seymour1
    Seymour1 Member
    272
    36
    My newly purchased 2010 Prius with 229,000 miles has a blown 40 amp fuse for the A C compressor. And, I was getting P0AA6 codes, yellow triangle and "Check Hybrid System". I bought a Vici 500 volt megohmmeter. The battery is O K. The motor/generaters are O K. I disconnected the cable going to the A C compressor. The fused side of the cable acted like charging a capacitor to > 20 megohms. The unfused side read 0 ohms with the Vici tester. The inverter reads 1.9 megohms.
    I cleared the codes and did not reconnect the compressor cable. When I drove the car, there was no triangle or "Check Hybrid System".
    For the time being, I want to drive the car without buying a new compressor. The inverter has an empty hole where the cable was plugged in. I worry about dirt entering the inverter. If I plug in the compressor cable at the inverter, will the triangle or the "Check Hybrid System" cause a problem? Would it be safe to unplug the high voltage cable at the compressor? I do not plan on turning on the A C controls on the dash.
  2. ChapmanF
    19,060
    Wow! You mean this one, right?
    I would never have guessed that one would be 40 amps. That would be over 8 kilowatts at 201.6 volts, and I've never seen the A/C exceed 3 kW. I might have guessed the fuse was 15 or 20 amps. But it sure does say 40A in that picture, doesn't it?
    You could disconnect that cable at the compressor, and put a bunch of turns of self-fusing silicone tape (e.g. Rescue Tape) around the disconnected end to insulate it, and find a way to secure it from banging about, and then reattach the inverter end to keep that opening closed.
    This will either give you another P0AA6 or it will not. If it doesn't, you can go on driving until you feel like replacing the compressor. If it does, you'll know the fault is in the cable and maybe not the compressor, and that might be welcome news.
  3. Seymour1
    Seymour1 Member
    272
    36
    Yes, I also did the math. That is a lot of power. Fuses are over-sized to eliminate nuisance fuse-blowing. They are mainly there to protect wiring or a stalled motor. And, the inrush surge current when the compressor starts is higher than when running.
    I am wondering if I also need to replace the dryer and condenser at the same time as the compressor. Some recommend doing that because of air entering the system when the hoses are unscrewed. But, even if I have a new dryer, condenser and compressor, at some point I must open the end of the hoses, compressor, dryer and condenser before attaching the parts together. And air will enter!
    If I can unscrew the hoses on the old compressor, mount the new compressor and re-attach the hoses very quickly, maybe I will only need to replace the compressor?
    I am confused by some youtubes. I saw where some oil remains in the hoses. And, if I add the proper amount of oil to the compressor, then, there will be too much oil. But, nobody knows how much oil is in the hoses.
  4. Seymour1
    Seymour1 Member
    272
    36
    And the fuses cost $35 each.
  5. ChapmanF
    19,060
    As far as I know, that's always been part of the art-vs.-science aspect of this whole business. Sometimes, too, the new compressor comes with oil in it. I remember seeing references (not from Toyota that I've seen, just more general) that gave rules of thumb for how much of the new oil to pour out, based on which old parts of the system are being reused and assumed to have oil in them.
    Yeah, that always used to be the rationale when you had a big old utility motor that would just have a big contactor close at line voltage to start it. But this compressor is a motor with its very own variable-frequency drive built in that has control of voltage, frequency, phase, and current. I really doubt its startup behavior looks much like that at all.
  6. Seymour1
    Seymour1 Member
    272
    36
    I did not know that the electronics (other than the motor) were in the compressor. Interesting.
    I did unplug the power cable from the compressor. The fault remained. The fault is on the low side (unfused). I tested the cable with my Vici 500 volt tester. It failed with the compressor unplugged. I am surprised. The cable is double insulated and insulation is cheap. And, why did my fuse blow? The fused side of the cable is O K. I might need to replace both the cable and the compressor.
    I just retested with the 500 v Vici tester. I found that if I pull the connector fully away from the inverter, it checks good. Then, I found that the metal cover on the cable end is shorted to the power connector low side. see attached. Now I am trying to figure out if this short damaged the compressor or caused the fuse to blow. IMG_2849.JPG
  7. Seymour1
    Seymour1 Member
    272
    36
    The cable is defective. Poor design or poor quality control. It should have been hi-pot tested at the factory. IMG_2850.JPG IMG_2852.JPG IMG_2852.JPG
    Replacing the cable appears to be another lengthy frustrating job. I might wrap the metal sleeve with electrical tape for now. See image of the metal shell and the metal sleeve that should be insulated from the wire.
  8. ChapmanF
    19,060
    Probably just blew the fuse. A short upstream of the compressor itself might not have harmed it, but of course you'll know soon enough.
    The Prius high-voltage cables are shielded. Those connector shells are continuous with the cable shield, so there could be cable damage anywhere along its length; have you checked? One of the reasons for the shield is to make sure that any such damage will produce an immediately-noticed problem.
  9. Seymour1
    Seymour1 Member
    272
    36
    I did wrap the sleeves with electrical tape. The electrical tape repair did not last, so I removed the metal shell for now. I ended up breaking the low voltage control connector at the compressor. I broke it when trying to remove it. What a terrible design! Is there a special tool to help remove the plug?
    And, I found that the compressor is also shorted. I will need a new compressor and a new power cable. And, now, a new control signal connector at the compressor. 2024-07-25_17-44-12.jpg ebay has them with a better design where I can push the catch and pull the plug at the same time.
  10. Seymour1
    Seymour1 Member
    272
    36
    The fuse was not installed. In the image, the metal shell (strain relief) is removed. The ohmmeter reads (almost) zero ohms. I was measuring the low (unfused) side. There is a metal sleeve (for strain relief) on each of the 2 power leads. Sorry that I did not get a better image. They should be insulated from the internal copper conductor wire. One is and one is not. Vibration and strain must have caused the partial short. The metal sleeves are sandwiched between the metal shell, which is bolted to the inverter cover. Thus, a leakage path exists to frame ground.
    I was surprised and disappointed that the compessor is also bad. But, I double checked it.
  11. ChapmanF
    19,060
    Notice that if you cut into the power cable, you find that it is coaxial, with a conductive shield inside the outermost insulation layer, surrounding the inner high-voltage conductor (examples), and the metal shells and strain-relief at the ends are electrically continuous with the shield, on purpose.
    Besides reducing electrical noise from the switching of those currents, which could interfere with other systems in the car, that also helps with damage detection: any kind of penetrating damage to the high-voltage cable, anywhere along its length, is likely to create a detectable ground fault, instead of going unnoticed.
    For releasing stubborn connectors, there are various tools on offer. I don't own any of those, but I might cuss less if I did.
    #11 ChapmanF, Jul 25, 2024
  12. Seymour1
    Seymour1 Member
    272
    36
    Interesting! Shielded wires. The braid is attached to the metal sleeve. I can see that a center conductor short anywhere to the shield will cause my problem.
    I have ordered a used compressor with a 6-month warrenty. And a manifold set and a high voltage cable.
    I have watched hours of youtubes. Some take drastic shortcuts. I will replace the compressor, condenser, receiver/dryer and flush the hoses. If there is dirty conductive oil in the evaporator and expansion valve, I will flush those. I think that if I must take the dash apart, that will be the worst part.
    O'Reilley has a rental pump that will pump down to 75 microns. Is this good enough? Typically they will go to 40 microns for a single stage pump.
    Toyota recommends their oil at over $200 while I can buy Denso ND Oil 8 brand for $25 or Honda hybrid oil for $40. Must I really use the $200 oil?
    Thank you for educating me.
  13. Seymour1
    Seymour1 Member
    272
    36
    I bought a can of Honda POE oil. I think that it will be fine.
    I watched a youtube showing a Ford system being fixed. The factory manual said to add a filter to compressor input and liquid line to prevent damage unless all components are replaced. That seems like good insurance to me. Are these available for a Prius? Removing the evaporator is a lot of work. I can flush it, but that is no guarentee.
    And, does the Prius use anexpansion valve or an orfice tube? And, will a vacuum pump that will only go to 75 microns be good enough? IMG_2857.JPG
    Thank you for your patience with my many questions.
  14. Mendel Leisk
    42,380
    I fought with that. The trick I used is to take a pen knife tip (even a flat blade screw driver is too thick), bring it in JUST above the base on the front side, get the tip in slightly and pry outwards. There's a lever arm right there, and the end is barely a mm above the compressor top.
    It comes off easy as butter, then...
    Was there corrosion on the 12 volt connector pins atop the compressor? It's a bit of a design fail: the connector could double as a rain gauge, a little upright cup. If anyone's ever blasted the engine bay with a hose or pressure washer, it fills with water and corrodes nicely. And bricks the compressor, there appears to be no easy way to repair.
  15. ChapmanF
    19,060
    Yay, there's one answer I know! It's an expansion valve.
  16. Seymour1
    Seymour1 Member
    272
    36
    My pins have not corroded yet. I have been trying to think of a preventive measure to save the connector. I wonder if filling the compressor side connector (male pins) with plumber's grease. (silicone grease) It is not conductive and will not harm plastic or rubber parts. The contacts should make contact, I think. Or, how about a plastic bag wrapped tight with zip ties securing it?
    I searched ebay for a Prius add-on in-line after-market freon filter without any luck.
  17. ChapmanF
    19,060
    There are greases made for protecting contacts. Some of them are a bit like other silicone greases—Ford famously had one that did double duty as disc brake caliper grease. (I've used their later, XG-12 grease also as a light damping grease, to make threads on optics have that smooth feel, for example.) If I were going to try one at all, I'd probably try one that was at least labeled for protecting electrical contacts.
    Maybe just unplug it and dry both ends out with a hair dryer after pressure-washing the engine compartment....
  18. Mendel Leisk
    42,380
    The connection should stay dry, as long as you don't hit it with a hose. I'm totally averse to spraying water in there; only use brushes and a leaf blower, once in a blue moon.
  19. Seymour1
    Seymour1 Member
    272
    36
    Bingo! I want to clean my engine without worrying about ruining the connector. see attached 2024-07-28_20-24-46.jpg
  20. Seymour1
    Seymour1 Member
    272
    36
    Thank you, Chap. This is what this grease is made for. I will use it on several connectors.
