A C compressor causing P0AA6 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seymour1, Jul 19, 2024 at 4:03 PM.
  1. Seymour1
    Seymour1 Junior Member
    160
    17
    My newly purchased 2010 Prius with 229,000 miles has a blown 40 amp fuse for the A C compressor. And, I was getting P0AA6 codes, yellow triangle and "Check Hybrid System". I bought a Vici 500 volt megohmmeter. The battery is O K. The motor/generaters are O K. I disconnected the cable going to the A C compressor. The fused side of the cable acted like charging a capacitor to > 20 megohms. The unfused side read 0 ohms with the Vici tester. The inverter reads 1.9 megohms.
    I cleared the codes and did not reconnect the compressor cable. When I drove the car, there was no triangle or "Check Hybrid System".
    For the time being, I want to drive the car without buying a new compressor. The inverter has an empty hole where the cable was plugged in. I worry about dirt entering the inverter. If I plug in the compressor cable at the inverter, will the triangle or the "Check Hybrid System" cause a problem? Would it be safe to unplug the high voltage cable at the compressor? I do not plan on turning on the A C controls on the dash.
  2. ChapmanF
    15,682
    Wow! You mean this one, right?
    I would never have guessed that one would be 40 amps. That would be over 8 kilowatts at 201.6 volts, and I've never seen the A/C exceed 3 kW. I might have guessed the fuse was 15 or 20 amps. But it sure does say 40A in that picture, doesn't it?
    You could disconnect that cable at the compressor, and put a bunch of turns of self-fusing silicone tape (e.g. Rescue Tape) around the disconnected end to insulate it, and find a way to secure it from banging about, and then reattach the inverter end to keep that opening closed.
    This will either give you another P0AA6 or it will not. If it doesn't, you can go on driving until you feel like replacing the compressor. If it does, you'll know the fault is in the cable and maybe not the compressor, and that might be welcome news.
  3. Seymour1
    160
    17
    Yes, I also did the math. That is a lot of power. Fuses are over-sized to eliminate nuisance fuse-blowing. They are mainly there to protect wiring or a stalled motor. And, the inrush surge current when the compressor starts is higher than when running.
    I am wondering if I also need to replace the dryer and condenser at the same time as the compressor. Some recommend doing that because of air entering the system when the hoses are unscrewed. But, even if I have a new dryer, condenser and compressor, at some point I must open the end of the hoses, compressor, dryer and condenser before attaching the parts together. And air will enter!
    If I can unscrew the hoses on the old compressor, mount the new compressor and re-attach the hoses very quickly, maybe I will only need to replace the compressor?
    I am confused by some youtubes. I saw where some oil remains in the hoses. And, if I add the proper amount of oil to the compressor, then, there will be too much oil. But, nobody knows how much oil is in the hoses.
  4. Seymour1
    160
    17
    And the fuses cost $35 each.
  5. ChapmanF
    15,682
    As far as I know, that's always been part of the art-vs.-science aspect of this whole business. Sometimes, too, the new compressor comes with oil in it. I remember seeing references (not from Toyota that I've seen, just more general) that gave rules of thumb for how much of the new oil to pour out, based on which old parts of the system are being reused and assumed to have oil in them.
    Yeah, that always used to be the rationale when you had a big old utility motor that would just have a big contactor close at line voltage to start it. But this compressor is a motor with its very own variable-frequency drive built in that has control of voltage, frequency, phase, and current. I really doubt its startup behavior looks much like that at all.
  6. Seymour1
    160
    17
    I did not know that the electronics (other than the motor) were in the compressor. Interesting.
    I did unplug the power cable from the compressor. The fault remained. The fault is on the low side (unfused). I tested the cable with my Vici 500 volt tester. It failed with the compressor unplugged. I am surprised. The cable is double insulated and insulation is cheap. And, why did my fuse blow? The fused side of the cable is O K. I might need to replace both the cable and the compressor.
    I just retested with the 500 v Vici tester. I found that if I pull the connector fully away from the inverter, it checks good. Then, I found that the metal cover on the cable end is shorted to the power connector low side. see attached. Now I am trying to figure out if this short damaged the compressor or caused the fuse to blow. IMG_2849.JPG
  7. Seymour1
    160
    17
    The cable is defective. Poor design or poor quality control. It should have been hi-pot tested at the factory. IMG_2850.JPG IMG_2852.JPG IMG_2852.JPG
    Replacing the cable appears to be another lengthy frustrating job. I might wrap the metal sleeve with electrical tape for now. See image of the metal shell and the metal sleeve that should be insulated from the wire.
  8. ChapmanF
    15,682
    Probably just blew the fuse. A short upstream of the compressor itself might not have harmed it, but of course you'll know soon enough.
    The Prius high-voltage cables are shielded. Those connector shells are continuous with the cable shield, so there could be cable damage anywhere along its length; have you checked? One of the reasons for the shield is to make sure that any such damage will produce an immediately-noticed problem.
  9. Seymour1
    160
    17
    I did wrap the sleeves with electrical tape. The electrical tape repair did not last, so I removed the metal shell for now. I ended up breaking the low voltage control connector at the compressor. I broke it when trying to remove it. What a terrible design! Is there a special tool to help remove the plug?
    And, I found that the compressor is also shorted. I will need a new compressor and a new power cable. And, now, a new control signal connector at the compressor. 2024-07-25_17-44-12.jpg ebay has them with a better design where I can push the catch and pull the plug at the same time.
  10. Seymour1
    160
    17
    The fuse was not installed. In the image, the metal shell (strain relief) is removed. The ohmmeter reads (almost) zero ohms. I was measuring the low (unfused) side. There is a metal sleeve (for strain relief) on each of the 2 power leads. Sorry that I did not get a better image. They should be insulated from the internal copper conductor wire. One is and one is not. Vibration and strain must have caused the partial short. The metal sleeves are sandwiched between the metal shell, which is bolted to the inverter cover. Thus, a leakage path exists to frame ground.
    I was surprised and disappointed that the compessor is also bad. But, I double checked it.
  11. ChapmanF
    15,682
    Notice that if you cut into the power cable, you find that it is coaxial, with a conductive shield inside the outermost insulation layer, surrounding the inner high-voltage conductor (examples), and the metal shells and strain-relief at the ends are electrically continuous with the shield, on purpose.
    Besides reducing electrical noise from the switching of those currents, which could interfere with other systems in the car, that also helps with damage detection: any kind of penetrating damage to the high-voltage cable, anywhere along its length, is likely to create a detectable ground fault, instead of going unnoticed.
    For releasing stubborn connectors, there are various tools on offer. I don't own any of those, but I might cuss less if I did.
    #11 ChapmanF, Jul 25, 2024 at 6:31 PM
