Cloudy instrument panel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by coyote2, Nov 12, 2023.
  1. coyote2
    coyote2 Member
    147
    36
    Prius-Instrument-Panel-Cloudy.jpg At night, inside the instrument panel, outside of a circle around the glowing green instruments, there is a splotchy cloudy haze. It doesn't interfere with viewing (and it's not visible during daytime), it's just cosmetically unappealing.
    I assume that dealing with this would cost far more money than I care to spend.
    I don't know why the instruments appear blurry, and the cloudy splotchiness appears everywhere, on this photo.
  2. PriusCamper
    PriusCamper Senior Member
    13,049
    5,303
    Pacific Northwest, USA
    You haven't tried to clean it? I've never had a problem ever with a little glass cleaner on a towel fixing this problem. You'd have to have a really beat up Prius and always drive with the windows down on a dusty road to have it get underneath the dash, and even then its only a hour or two to take apart and clean.
  3. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    Be sure to clean both the instrument panel glass that faces you and the plastic cover that you can see by looking down through the windshield from the outside of the car.
    I'm always amazed at how much clearer the readouts are with a quick clean.
  4. ChapmanF
    18,535
    Don't overlook that the speedometer is a projection; the lens it projects up from is in the bottom surface of the cluster area.
    Have you checked that there isn't just some gunk on that? It's not hard for stuff to end up there.
  5. coyote2
    coyote2 Member
    147
    36
    Ooops! Thank you very much ChapmanF, I knew that it was a projection but I assumed that the projection all occurred inside the glass. Now I'm sure that once I get home this will clean off easily. I think it happened when some dumb carwash ArmourAll-ed my dash.
    #5 coyote2, Nov 18, 2023
  6. coyote2
    coyote2 Member
    147
    36
    I was wrong. Vigorous prolonged cleaning with glass cleaner and paper towels barely did anything.
    Any advice please on more powerful cleaning measures? As mentioned, I think it might be they got Armour All-ed.
    What exactly are the surfaces? The bottom flat section is a mirror, so I know to find out how best to clean that. What material is it facing the driver?
  7. ChapmanF
    18,535
    It's labeled as a smoke(d) acrylic plate.
    Maybe that is where some of the Armor All ended up, as the warning lights look sort of blurry too, and they shine through it, instead of reflecting on it.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,828
    843
    Southern California
    Discussion of a similar issue here:
    Armor all cleaner product stained the clear plastic covering of gauge cluster..... - NASIOC
    In summary, it might polish off, but more likely the plate will need to be replaced.
    I would suggest getting a mirror and flashlight and closely examining the plate that the light first passes through. It might be contaminated too. If this first plate is OK then putting a small mirror flush up against the second plate should give a clear image. Or at least I think so, never having done the experiment.
  9. coyote2
    coyote2 Member
    147
    36
    Now I've done that. The first plate (the one that faces up and one needs a mirror--or to look down through the windshield--to see) is the bad one; the second plate (the one the driver looks at) is clear.
    I tried cleaning the first plate again. Simple Green and paper towel did nothing. I then tried Simple Green with a non-scratch pad; it both cleaned the plate somewhat and scratched the plate a bit. I think it's a wash; cleaned the image is a good deal less splotchy, but scratched it's a bit blurred.
    I know I won't be removing the dash myself; maybe next time I take it in to Berkeley's Art's Automotive I'll mention it to them. I doubt I want to spend more than $100 on any work on it; it was OK before and it's OK now. (Couldn't even see the spotchiness except at night...but the slight blurriness does seem noticable during the day.)
  10. pasadena_commut
    2,828
    843
    Southern California
    If the only problem now is slightly scratched plastic it may improve if you wax that piece of plastic. Most of the optical problem caused by a scratch in plastic is from the difference in the index of refraction at the air/plastic interface. Wax has an index of refraction much closer to plastic than air, so filling the scratch with plastic reduces light scatter. (This is also mostly what the windshield chip repair kits do, but there they use another plastic, like a methacrylate, and some system to make a flat surface over the much larger pit.) I suppose one could also go through the whole wet sanding then polish sequence, like on a headlight, but it would probably drip into the dash (which would be bad). If the scratches were exceedingly fine skipping the sanding and just polishing might work. Probably all of the preceding would only work as a band aid, the real fix is to replace that piece of plastic.
    If it is any consolation I once damaged two headlights trying to clean them with PlastX. The bottle had sat too long and the solids fell out and clumped up. Even though I shook it hard the contents didn't actually mix well, so when the "polish" was applied to the headlight it was mostly solvent - and it proceeded to eat the anti-UV coating.
  11. Seymour1
    Seymour1 Member
    266
    33
    I cleaned the horizontal glass and now my speedometer is clear. However, the cartoon that shows battery vs engine vs wheels is still hazy. With a flashlight and small mirrow, I could see that the fuzz was on the cartoon and not the glass. It looks like condensation, but my A C does not work. To check, shine the flashlight at a steep angle to the glass. A mirror will show how far back the fuzz is.
