Coolant pump B control malfunction (P261B)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Baasan, Aug 10, 2015.
  1. ChapmanF
    15,697
    Has nothing you've read in either of your threads about it in the last 3 days seemed to shed any light on that?
  2. Boston2008Gen2
    Boston2008Gen2 Junior Member
    59
    Houston TX
    In 3 days so far, I cleaned the heater core, tested water pump relay ,water pump plug voltage. All good.
    went to a mechanic to read / test wp but his software won't read or test. My techstream crashes when I tried to test wp.
  3. ChapmanF
    15,697
    Ok, it's good that you've done some of those things. How did you test the WP plug voltage exactly and what were the results?
    The "mechanic's software won't read or test" and "my techstream crashes" are obstacles for sure; it would be easier if one of those could be overcome.
  4. Boston2008Gen2
    59
    Houston TX
    found a bulletin, D13-2 (NWP) - Body ground 11-14v, D13-1 (+B) - Body ground 11-14v.
    I got 12 v on both. So plug is good.
  5. ChapmanF
    15,697
    That's a useful step. I assume you mean you had D13 disconnected from the pump and these measurements were with ignition on and the engine not running. That NWP to WPI circuit is the one that brings the pump speed back to the ECM, which is what P261B is about.
    The easiest way I've found to probe it while the pump is operating is where both those circuits pass through the underhood fuse box, as described in this post.
    Top trace is what the WPO - SWP circuit should show, bottom trace the NWP - WPI circuit, when the ECM is requesting about 40% pump speed.
    SFO likes this.
  6. Boston2008Gen2
    59
    Houston TX
    Yes I did read your thread. I guess I don't have a tool to check that square waves.
    I am thinking of checking w/p again. Open and check the propeller.
  7. Boston2008Gen2
    59
    Houston TX
    BTW, maintenance light is on. Tried TripA,Km + double On, but won't work. Mechanic software won't connect. I am thinking if ECU has issues?
  8. ChapmanF
    15,697
    Sometimes there can be things that just have to be seen to get to the bottom of a problem. With your Techstream crashing, your mechanic's software not working, and no oscilloscope, you've got drastically restricted visibility into what's going on. Progress on any one of those fronts could make it easier.
    Generally oscilloscopes aren't cheap enough to be casual purchases yet (unless there's, like, a university salvage outlet nearby), but an automotive shop or an electronically-inclined buddy might already have one. Also, for the signals involved here, definitely nothing fancy in the oscilloscope department is needed. We're talking tens of Hertz, not megahertz or gigahertz.
  9. Boston2008Gen2
    59
    Houston TX
    I missed to mention my other observation other day.
    At >55 mph in hwy, I got beep noise with "Hybrid system warning" symbol in display. But I pulled error code with my Torque android app that gave me P261B.
    At that point I reset error code from app and came home slowly 40mph< to home.
  10. ChapmanF
    15,697
    One reason not to drag things out too long when there is a reported water pump code is that even if you are watching the coolant temperature carefully, that's the temperature where the sensor is, and if the coolant isn't being circulated effectively, it can be other temperatures other places; sometimes that even includes localized boiling spots, which separate the coolant from the metal to be cooled. Repeated enough, that can take a toll on the engine.
  11. DriverSteveSF
    DriverSteveSF New Member
    Yesterday
    San Francisco, Ca
    I've always heard that it's best to replace the water pump with the thermostat when you have a problem with either one. They are right next to each other and usually, the thermostat isn't that much more work and doesn't cost much more. So why not change them both so you won't have to in the future, potentially?
    I found this thread by googling "Engine Coolant Pump 'B' Control Malfunction" which I am also getting on my 2016 Lexus ES 300h with 279k miles. I'm an Uber/Lyft driver and so I'm doing everything I can to learn about how I can fix this issue myself without paying a mechanic an enormous amount of money that I don't have.
    Found an $80 pump on Amazon (Gotta Love Amazon!), yes it's generic but I need something right away and don't have $400 to buy an OEM one from a reliable source at the moment.
    I too am concerned about the "B" in the code given. I mean if there is a "B" then there must the an "A" too, right? What is "A"? Is that the petrol coolant pump? Because if it is, why does it seem like my petrol water pump is out but a code of P261B is being triggered when P261B sounds like the inverter pump? And BTW, my inverter pump is a little noisy but it's always running while the car is on.
    I will be attempting changing this petrol water pump and hopefully the thermostat (if I can find one) on Saturday. I hope for the best!
    For anyone who has a 2AR-FXE (Hybrid) engine, this video should help you tremendously in seeing just how easy it is to change this on a 2AR-FXE engine...
  12. Brian1954
    Brian1954 Active Member
    848
    315
    South Central PA, USA
    Be prepared to change the generic pump again within the next year.
    Coolant pump "B" in the description (Coolant Pump "B" Control Malfunction) for trouble code P261B is for the ICE (internal combustion engine). Coolant pump "A" is for the inverter.
    #32 Brian1954, Jul 26, 2024 at 9:42 AM
  13. Mendel Leisk
    38,750
    This is for a 3rd gen Prius (model year 2010~2015)? What's the miles?
    If you're shopping for engine water pump, this should be significantly less; see what it is for you with shipping:
    Buy AISIN WPT190 Pump, Water. Prices, fast shipping, photos, weight - Amayama
    I've purchased a few items from them; never any problems.
    (For me, west coast Canada, it works out to $135~ USD, all-in, with shipping. They've yet to add any sort of sales tax, duty.)
    #33 Mendel Leisk, Jul 26, 2024 at 2:53 PM
    DriverSteveSF likes this.
  14. Brian1954
    848
    315
