How to make the HV battery fan to run all the time?
Discussion in 'Prime Main Forum (2017-2022)' started by ESh, May 23, 2023.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,268
    5,965
    Columbia, SC
    The controller for the fan is located in the black plastic outlet duct mounted to the passenger side of the HV battery.
  2. Mendel Leisk
    38,785
    Also, there should be a related code.
  3. Frankusa94
    Frankusa94 New Member
    Ny
    No codes… unless the battery is allowed to reach over 125f… in which a code for high battery temp is set…
    Thanks
  4. Frankusa94
    Ny
    I believe that is the fan rectifier, and seems to work correctly as the app is able to vary the fan speed. Issue is … the battery temp sensors are reporting the temperature… but something is failing to turn on the fan. App will do all this…thus implying all parts are working. Appears the ecu may have incorrect or no temperature kick on setting in place. I will however take a closer look at that outlet duct component you are referring to.
    Thank You
    Frank
    #24 Frankusa94, Aug 4, 2024 at 7:30 AM
    vvillovv likes this.
  5. ChapmanF
    15,771
    There's nothing to rectify: the power source is already DC and the fan motor runs on DC.
    The controller in the duct is not much more than a nice heat-sinked transistor, able to take the pulse-width-modulated SI speed signal from the ECU and drive the fan motor with it. Indeed, your ability to alter the fan
    speed manually confirms it is fine.
    What does the Data List show as the selected fan speed, at various battery temperatures?
    That would imply your ECU is running different firmware than everybody else's ECU. Seems a stretch.
    douglasjre likes this.
  6. sylvaing
    sylvaing Senior Member
    1,078
    443
    Unfortunately, there are no fan icon in hybrid assistant on the Prime so you can't adjust its speed.
  7. Frankusa94
    Ny
    My hybrid assistant app shows fan speed, and "A" in the fan symbol which designates the app auto control the fan...
    Try rotating your phone to display in wide screen... I believe the fan control will show then...
    Thanks
  8. Frankusa94
    Ny
    Thanks for the schematic! This is helpful...
    Today I attempted a ecu reset by removing the ground cable from the 12v battery for 5 minutes. This seemed to clear the ecu as removing the 5amp 12v battery fuse did not clear anything.
    Now I noticed that toyota ecu will control the fan ...speeds 1-3 ... around 100f fan is at speed 1, at 106f fan speed is at speed 2, at 116f fan went up to speed 3. This is better...but not good enough as the center hv battery bank was red at 121f ...the 3 banks were as follows. 117f, 121f, 116f.
    Once I launch and enable Auto fan control on hybrid assist app... fan speed goes to speed 6 (Maximum) and battery temps begin to drop toward 102f over a 20 min period... this is ideally were the battery accepts the maximum 25 amps regenerative or engine charging rate.
    I wish I could see what the toyota fan controller speed set points are... suspect only toyota service center can do such...
    Gonna may a youtune video soon discussing this issue...
    Thanks
    Frank
  9. TMR-JWAP
    6,268
    5,965
    Columbia, SC
    Now I see the problem. Because your APP shows it as being RED, you feel it's too high?
    These cars, sitting in the summer sun, get higher than 125 inside. I don't think 125 on the HV battery is a crisis. The battery does have its own Toyota low and high temp values that will cut back on current to protect the battery. Why not let it do its thing?
  10. AzusaPrius
    AzusaPrius Senior Member
    1,925
    830
    When the HV battery is that hot you lose HP from it and the ICE is used more, wasting gas, so if you lower the temp of HV battery then you will get more assistance from it and use less gas.
    Make sense?
  11. TMR-JWAP
    6,268
    5,965
    Columbia, SC
    Azusa, as proven by the majority of your posts, you wouldn't know sense if it bit you in the face.
  12. AzusaPrius
    1,925
    830
    Yea thats what an old person would say when they get offended.
    Not my problem you didnt know any better.
  13. vvillovv
    vvillovv Senior Member
    3,722
    1,313
    NY
    Not fur nothing - I'm just guessin.
    Have you tried either
    disconnecting hybrid assiant or the adapter? The extra app control might be monkeyin with the cars normal fan controller.
    I've had pretty good results using my old mini Elm and the newer version of hybrid assistant, dr prius and car scanner, but each gen has different PIDs controlling diff sensors. And a lot of time what works in one Prius doesn't always work in another Prius or while using a different adapter.
  14. ChapmanF
    15,771
    The same repair manuals that the Toyota Service Centers look in to see what settings they are able to change with Techstream, we are also able to look in, and "fan controller speed setpoints" aren't there.
    Lots and lots of setpoints in the car are just hardcoded in the firmware. You can change the auto headlight turnoff timer in Techstream, but not the intake valve timing setpoints, for example.
    It appears to be the same with the battery fan speeds. You can override the ECU's choices with something like Hybrid Assistant (for as long as Hybrid Assistant is plugged in and actively doing that), but changing the ECU's setpoints does not seem to be a thing.
    Without reflashing the firmware, I mean. Of course in the tuner community people do all kinds of things by modifying the firmware and reflashing it.
    Awells80 likes this.
