C1241 Code with Freeze Frames - Seeking Diagnosis Assistance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikk, Aug 6, 2024 at 7:21 PM.
  1. mikk
    mikk New Member
    Yesterday
    Germany
    Hello everyone,
    I've been experiencing an issue with my Prius, and I'm hoping to get some advice. Approximately once a month, all the brake warning lights (both red and yellow) illuminate on my dashboard. This happens in two scenarios:
    1. Parking Scenario: Most often, when I start the car while parked, the warning lights appear. However, if I turn the car off and then back on, the warnings disappear, and I can drive without any issues.
    2. Driving Scenario: Occasionally, the warning lights come on while I'm driving. In this case, I stop the car, turn it off, then back on, and the warnings vanish, allowing me to continue driving.
    The error code I consistently receive is C1241, which indicates either low battery positive voltage or abnormally high battery positive voltage.
    I've collected three freeze frames related to this issue, which I've attached as PDF files to this post. While analyzing these freeze frames, I've observed the following:
    1. The front right (Fr) wheel cylinder consistently shows an extremely low voltage (around 0.01 V) compared to the other wheels (which read around 0.45 V).
    2. The Fr wheel consistently displays a different speed.
    3. Strangely, the vehicle speed always matches the Fr wheel speed. How can this be?
    In the most recent freeze frame, the vehicle speed and Fr wheel speed were both 1 km/h, while the other wheels showed 23 km/h.
    4. Additionally, the voltage of the "Master cylinder sensor2" and the Fr wheel cylinder is equal (around 0.01 V or 0.03 V). Is this normal? It seems unusual to me, similar to the previous observation (see item 3).
    As a layman, this is what I've been able to identify. Perhaps there are other anomalies I haven't noticed.
    I plan to take my Prius to a reliable car repair shop where they're cooperative and willing to investigate the issue together. Unfortunately, the nearby Toyota shops haven't been very competent.
    I'm seeking advice on what might be wrong with my Prius and which parts should be checked or replaced.
    Any insights or recommendations would be greatly appreciated!
    Thank you in advance for your help!
  2. dolj
    dolj Senior Member
    7,702
    3,900
    Wellington, New Zealand
    This is somewhat similar to a comment ChapmanF made in this post in another thread for the same DTC.
    Your numbers are slightly different in that you have the XX2 data points (for 3 out of 4) showing reasonable values and the XX1 data points showing suspicious values. That is :
    IG1 voltage 0.00 V vs IG2 voltage 10.37 V
    BS1 0.07 V vs BS2 10.76 V
    +B1 0.07 V vs +B2 10.50 V
    BS1 relates the ABS No. 1 relay and BS2 relates to the ABS No. 2 relay. You might want to check you have voltage at the ABS No 1 relay and that this relay functions correctly.
    The other notable anomaly mentioned in Chap's post is the value of the detailed freeze DTC. As a programmer 256 (2^8) and 512 (2^9) stand out as possible translation error defaults. As Chap mentions, the FFD detail code should be 81, 82, 83, or 84. While this is unhelpful and may be a needless distraction, I believe that looking into what is causing the voltage discrepancy on those voltage input lines might be productive.
    Before starting any diagnostic effort, ensure the 12 V battery is fully charged and tested that it holds voltage under load.
    You might find the attached troubleshooting inspection procedure that contains the wiring diagram excerpt for this DTC.
    #2 dolj, Aug 7, 2024 at 4:19 AM
  3. Tombukt2
    9,347
    1,635
    Seems like the 10 volts up there that's repeated in the testing seems to come back to some sort of battery or ABS power issue seems uncanny how that works out or it seems it does
  4. mikk
    mikk New Member
    Yesterday
    Germany
    The 12V battery is fine, which is, of course, the first thing that should be checked.
    My problem is that the malfunction is not constant; it occurs infrequently, about once every two months on average. There was even a six-month gap between occurrences at one point.
    This inconsistency makes live diagnostics ineffective because the Prius generally works fine.
    It seems like there might be a loose contact that only manifests under certain conditions, or perhaps a faulty sensor.
    I read on a forum that replacing a wheel speed sensor might help.
    However, I don't think the front right wheel sensor is necessarily affected. The suspect value in the freeze frames for the Fr wheel could be due to a general current flow issue in the entire system. But who knows.
    So, my options are to wait until the error becomes constant, which is quite dangerous to drive with, or to preventively replace parts (but which parts?) and see if the error reoccurs. Alternatively, I could replug or clean some contacts (but which ones and where?).
    What would be the best way to proceed?
  5. ChapmanF
    15,790
    If you find yourself looking at a number like 10.37 and thinking that seems low, try looking at the 0.00 or 0.07.
    A reading has to be lower than 9 something, IIRC, to set a C1241, so 10.37 wouldn't have done it, but zero sure would.
  6. mikk
    mikk New Member
    Yesterday
    Germany
    Hopefully, you have read my post above. As a new user, my posts are moderated before they appear in the forum, which can cause a delay.
    Could you please check my post above to see if you have already responded to it
    Thank you!
  7. ChapmanF
    15,790
    dolj already called it. Your brake electronics include two redundant systems: system 1 and system 2. (The guys naming the systems were not feeling super creative that day.)
    Your freeze frames show system 1 getting pretty much no power, whether looking at IG1, +B1, or BS1.
    As the diagram shows, BS1 and BS2 are supplied by the brake backup power supply (the capacitor box in the rear of the car), through ABS No. 1 and ABS No. 2 relays, respectively. IG1 and IG2 are supplied through the IG1 and IG2 relays, via the ECU-IG and IGN fuses, respectively. +BI1 and +BI2 come from the ABS MAIN 1 and ABS MAIN 2 fuses. (The ABS MAIN 3 fuse it what supplies power to the brake backup power supply.)
    Finding out why zero, or close to zero, voltages are seen on multiple system 1 inputs might call for a neat bit of troubleshooting. The troubleshooting steps here might help.
  8. mikk
    mikk New Member
    Yesterday
    Germany
    Thank you very much! Your explanation is very clear and understandable.
    However, I'm still unsure about how to proceed with the issue.
    Should I continue driving and reset the error each time it appears until it becomes constant and shows up every time I start my Prius?
  9. ChapmanF
    15,790
    The more proactive approach would be to use electronic troubleshooting techniques (starting with the troubleshooting steps in the repair manual excerpt linked above, supplemented if need be by general electronics knowledge that there are various ways to obtain) to find out why the system 1 supply voltage readings keep showing up zero or close to zero as seen in your freeze frames, and once found out, fix it.
