Is Brake Bleeding Procedure Same for Gen3 & Gen 4 (non-Techstream)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by WilliamP, Aug 8, 2024 at 11:03 PM.
  1. WilliamP
    WilliamP Junior Member
    34
    MN
    I find a lot of info about how to bleed Gen3 but not Gen4. For example, is getting into "Invalid Mode" the same?
    I just want to change fluid, and have no need to bleed to get rid of air. Thanks.
    I'm thinking of using this Nutz & Bolts video.
    #1 WilliamP, Aug 8, 2024 at 11:03 PM
  2. ChapmanF
    15,798
    You should perhaps edit your thread title to say "fluid replacement" instead of "brake bleeding" (or, if the time to edit your own title has passed, use the Report button and ask the mod to do it).
    Your title as it currently stands is a trick question, given that there is no non-Techstream "brake bleeding" procedure for gen 3, so there's no way gen 4 can have "the same" procedure.
    There is a gen 3 non-Techstream fluid replacement procedure, and as long as fluid replacement is all you need to do, that ought to be enough.
    I do not know if there is such a procedure in the gen 4 repair manual, or if it is the same as for gen 3. There might be differences, as the gen 4 brake system differs from gen 3's in some significant ways that got discussed in this thread over here.
  3. Mendel Leisk
    38,795
    I believe it’s the same, but not sure. There’s a third Gen brake fluid change instruction in my signature, I think. FWIW.
    Hopefully 3rd gen Invalid Mode still works. Hitting the *$%! wall trying to find it in gen four manual.
    Attached:
    #3 Mendel Leisk, Aug 9, 2024 at 4:27 PM
