I should work on my Prius.
Discussion in 'Gen 2 Prius Main Forum' started by hurricos, Aug 9, 2024 at 1:27 PM.
  1. hurricos
    hurricos New Member
    Burlington, Vermont
    Bought my Southern US '08 in Aug '22 at 201K with P0420. Replaced my cat. Replaced sparks. Edit: now 207K. No major issues, but ...
    I keep thinking I should start reviewing small things:
    - that nobody usually looks at as a normal consumer,
    - that I have noticed and done nothing (0 things) about
    So, chuck me some first-step advice so I can start checklisting before winter.
    In order of priority crossed with ease-of-answering:
    1) I eat oil, something like 1qt every 2000 miles. (Just kidding, that's my engine eating it.) This is normal. (Right?)
    2) I found the enable wire for the inverter coolant pump partially chewed through by $VERMIN. It's the one with the 2-pin connector at the top right of the engine bay (driver's side). I should re-splice that, right? I'll overheat the inverter if that wire breaks on the highway far from home, right?
    3) I haven't looked at installing a catch-can. Snake-oil or reasonable? Where does this go -- I seem to remember as part of the intake or PCV system?
    4) TPMS. I'm remembering that the right way to reprogram them is to record the IDs using an RF tool that can pick them up, then re-add them to the TPMS ECM using a TechStream. Is that right?
    5) Maybe I should send oil in to Blackstone, just to get a baseline? Do PriusChat people do this (links appreciated, I'm bad at using the search bar correctly so I don't get Gen!=2 stuff), or are Gen2 engines so easy to come by that you don't worry?
    6) Brakes: I haven't touched the pads or shoes myself. They sometimes squeak. What is the TechStream UI path for bleeding brakes, or rather, do I even need to open up the fluid system to replace pads / shoes / do I even need to do any replacement there?
    7) Rough start when cold. In one instance, EXTREMELY rough (thought car died) at 15*F outdoors with nothing in the CHSS (sitting for a week). That was last winter. No issues since. I hear this is normal.
    8) Undercoat. This isn't a question, it's a checklist item so nobody tells me that I should. It's minty under there, even my mechanic was aghast to see no undercoat on it yet.
    9) Is there anything below I'm obviously forgetting? I live in Vermont.
    #1 hurricos, Aug 9, 2024 at 1:27 PM
  2. hurricos
    hurricos New Member
    Burlington, Vermont
    Edit: fixed the numbering because it was bothering me. :^)
    #2 hurricos, Aug 9, 2024 at 1:28 PM
  3. PriusCamper
    PriusCamper Senior Member
    11,151
    4,538
    Pacific Northwest, USA
    -- I'd put cleaning, inspecting and undercoat paint service at the top of the list before the cold weather returns... It may well be that there's too much rust to go further,
    -- I'd use a preflush engine cleaner a few minutes before the next oil change and a slightly thicker full synthetic oil and change it more often to see if the oil burning is not as severe as you think. 1 quart per 3K miles is what you need to get to ensure its not a concern, but it's also about how many miles you have on it and you don't have enough yet to be concerned.
    -- As for oil catch can, that's an essential maintenance addition for Gen3, but not needed as much for Gen2.
    -- Rough starts are common with Atkinson engines. Nothing to worry about if it's rare / intermittent.
    -- People on here sometimes get 300K miles on original brake pads on these cars. Of course rural mail carrier can barely get 50K miles on them, so it's a vehicle history thing. As for maintenance, periodically put car in neutral when doing hard breaking from freeways speeds which gives you all mechanical brakes and will clean the rust off the rotors.
    -- No worries on Inverter, it has thermal protection shutdown. People who get a bad inverter pump can do short drives with no issues until they have time to do the pump. When I do pumps for people I'll schedule them a ways out because its not urgent, at least to me.
    #3 PriusCamper, Aug 9, 2024 at 2:15 PM
  4. hurricos
    hurricos New Member
    Burlington, Vermont
    What is that product -- are Motul and what the layman knows as SeaFoam examples?
    > thicker
    Will less burn if it's thicker? I'll plan to start measuring 5W30 burn rate precisely for a baseline. Correct me, but you measure level at warm, 60-90s after the engine stops, yes?
    Happy to change oil frequently. It's cheap, PO killed my Insight's ECA1 by not doing so. Still, how does more frequent changing improve measurement -- am I measuring the QTY of oil I get back? I'm sorry for the exhausting questions.
    > but it's also about how many miles you have on it and you didn't say?
    Fixed. 207202 now. I borked my draft and left only the start mileage.
    I drive like a nutbag, so my rotors are clean *and* hot enough to eat off of. Mostly reflecting on rusty car experiences ("rebuild early, rebuild often").
    p.s.: Ironic that you'd be the one to answer ... Oh, well. If the wheel keeps turning I can't complain, can I? :^)
  5. hurricos
    hurricos New Member
    Burlington, Vermont
    No rust. And thank you. Now I can really beat myself up each day I'm too lazy to call David's. "Even those I see as morally ambiguous pity my foolishness."
    I've gotta get this one done soon. It's like the tires, I can't get nice ones for my Insight, but they still sell Michelin Defenders for the Gen2 Prius, so I have no excuse not to take advantage of the availability.
    To cap it off: thank you, glad to know I'm overthinking some of these. Too many options spoil hurricos.
  6. PriusCamper
    11,151
    4,538
    Thicker oil probably won't make much difference, and engine flush product you choose doesn't matter much... But I've seen minor improvement in less oil burning if the sludge inside gets real bad and you start to address it.
    We have one guy in @Fatmatt86 who has been posting for six years in a thread where he told us he was using 4 quarts of oil per thousand miles and you'd think he'd not be able to use that engine much longer but as the years go by we've all been surprised.
    UPDATE: Looks like his experiment finally ended this past May: Burning 3.9qts every 1000 miles | Page 13 | PriusChat
    #6 PriusCamper, Aug 9, 2024 at 2:43 PM
  7. Tombukt2
    9,372
    1,638
    207 You're just getting to the well broken stage which is around 2:50 and you say you're burning a quart every 2,000 mi that doesn't seem too bad You could try cleaning the engine out real good with some chemicals and what have you Pistons half mast overnight that sort of nonsense see if it makes any difference but that's not bad at all how that used to be a week of driving for me in the same cars they're going to go 500k 600 easily unless they get hit brakes and all that stuff easy to deal with You don't need to crack anything open You can just slide in new pads offer it some new front rotors maybe if it dictates change the shoes in the back maybe a new hardware set just because springs and what have you at the drums look good close it back up.
  8. hurricos
    hurricos New Member
    Burlington, Vermont
    Wild.
    I'm not expecting miracles. I need a boring and safe car so I can work on turning my Insight into a fun, safe, comfortable, efficient project car. Good success so far, but I need time.
    > 207 You're just getting to the well broken stage which is around 2:50 and you say you're burning a quart every 2,000 mi that doesn't seem too bad ... get hit
    Sounds 'bout right
    > brakes ... close it back up.
    Good conf that I don't need to expose the fluid. I'll open things up (edit: at some point, if they get bad) just so I'm convinced.
    #8 hurricos, Aug 9, 2024 at 2:55 PM
  9. PriusCamper
    11,151
    4,538
    Only thing you're doing wrong with achieving this objective is trying to do anything at all to your Prius. Based on the info in this thread there's nothing that needs to be done.
    hurricos likes this.
  10. hurricos
    hurricos New Member
    Burlington, Vermont
    That's kind of where I'm at, thanks to the consensus here. Thanks for soothing my concerns.
    Edit: Except the undercoat. Get to work, numb-nuts!
    /hurricos immediately forgets he needs to call David's
  11. PriusCamper
    11,151
    4,538
    If rust doesn't look that bad in that part of the country, you must be parking it in a garage or something? Or maybe it has to be a daily driver to rust in the way things rust out there?
  12. hurricos
    hurricos New Member
    Burlington, Vermont
    I tried to make the original post really short so it was easy to read edit: but maybe it made it harder to read because it was so terse. I don't mean to make fun of you, but here you go:
    It's from the Southern US. edit: It is with me in Vermont, yes, and it's my every-other-daily driver.
  13. PriusCamper
    11,151
    4,538
    I drive slow... But I often read too fast and miss the details even though I think I didn't...
