Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. PriusCamper
    PriusCamper Senior Member
    13,402
    5,412
    Pacific Northwest, USA
    Or maybe the knock is from coolant steam blowing in through the spot where headgasket fails between cylinder 1 & 2 when engine is hot just after its turned off and then the next day once the engine is cold you got pistons pushing water when tries to start?
    As in fastest way to check for headgasket failure on Gen3 Prius is a sucking sound when you open the lid on the coolant reservoir.
  2. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Let's not hijack the thread with a discussion of a Gen 3 issue that is not really relevant in a Gen 2 forum.
  3. PriusCamper
    13,402
    5,412
    You just made the 242nd comment on this thread... A thread that big can't be hijacked, just momentarily distracted.
  4. dolj
    dolj Senior Member
    8,633
    4,386
    Well, let's not be distracted then.
    Fatmatt86 and PriusCamper like this.
  5. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Made it 1/3 of a million miles. 333,333 Tried uploading but keep getting failed error messages. Still running strong, but may need a new alignment soon as the car pulls to the left when driving
  6. PriusCamper
    13,402
    5,412
    You can DIY an alignment job with tire pressure... :)
    jerrymildred likes this.
  7. qmanqman
    qmanqman Active Member
    442
    153
    CO
    how?
  8. PriusCamper
    13,402
    5,412
    If it pulls to the right, you boost tire pressure in right wheel and lower tire pressure in left wheel. If it pulls to the left you do the opposite of that...
    #248 PriusCamper, Jan 25, 2024
    don K otay likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    We really need a ROFLOL button in addition to the "Like button. :ROFLMAO:
    PriusCamper likes this.
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,995
    6,892
    Texas Hill Country
    There are diy alignment methods with strings and measuring tapes. But not as good as a $60 alignment at the cheapest place in town. Plus the only good reasons to need an alignment on these cars is you took things apart or some suspension components need replacing.
  11. PriusCamper
    13,402
    5,412
    Also when I was in High school I had a friend who was older than us who we depended on to buy us beer and when he noticed the alignment got bad he'd park the trouble wheel against a curb and then forced the steering wheel to bend the tie rods to get it to drive straight... As time went by he had to do it more and more often until the car couldn't be driven anymore.
    vvillovv likes this.
  12. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Hope the tie rod didn't brake when he was racing or on a long trip.
  13. PriusCamper
    13,402
    5,412
    It was a beat up early 70's Toyota Corina and it was the late 80's and he was hella poor so it was a junk car for the most part... But I'll always remember how we got on the freeway to go somewhere and he took an exit saying he had to find a curb to fix his alignment again. At the time I worked at an auto repair & body shop and was impressed by his resourcefulness.
    But in High school I did have some other friends who were brothers who's family was the Pereras, a well known name in the racing world. Those kids always drove Mustang Shelby that they were constantly working on and he did have one if his tie rods fail while burning rubber on a circular freeway on ramp and crashed off the road pretty bad. I was always grateful to have survived our lunch time drives and make it back to school on time. I stopped riding with them once they told me that story.
    #253 PriusCamper, Jan 25, 2024
  14. vvillovv
    4,336
    1,518
    NY
    Nice story dude. I had my 72 charger 318 stock, tie rod break in a parking lot in the late 80's early 90's. I was about 15 miles from home after a job interview iirc, and all I could think of as I was standing staring at the front wheel was holy moly if that had broken on my way home instead of in the parking lot I'd probably not be typing this now.,
    I also have similar jr high and high school stories .... ;) I worked in a neighbors body shop 30 miles from home summers and after the 2 brother owners sold it and moved to FL the new owners kept me on. I'll never forget all the good and bad things I learned and or heard while working there.
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    Years ago a friend had one literally "brake." Instantly. When it broke (past tense of "break" :D), the left front wheel went full lock left and the right one went full lock right. The little pickup stopped like it hit something.
  16. rjparker
    10,995
    6,892
    Texas Hill Country
    Brake vs Break is only surpassed by Advice vs Advise around here.
  17. Leadfoot J. McCoalroller
    8,269
    7,773
    Pennsylvania
    2018 Prius c
    I thought Pruis/Prius was in the lead?
  18. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Although not related you can buy toe plates of amazon for a diy alignment. Much easier than you think. Then just use a digital cube level and strap it to the steering wheel somehow so you know the steering wheel is perfectly straight. $80 in materials.
    Shit an alignment here is $100 at cheapest. The big name chains want $140
  19. vvillovv
    4,336
    1,518
    NY
    The 72 charger had cam bolts for the lower control arms. It's always nice to know which bolts and connectors adjust all the various alignments like thrust angle, toe, caster, camber, Are there others now?
    Getting them all within spec isn't easy.
    I had an alignment done on our 02 civic and the tech told me he couldn't get the right front to spec. And also said I'd need a cam kit to fix it. I had recently asked the dealer to replace the right front sway bar link ./ stabilizer link. After the alignment I took a look at that right front and noticed the lower control arm was squished like an accordian about 1/2 inch. After replacing that control arm the 4 wheel alignment was than easy to get within spec.
  20. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Well, this will be last Prius update and a final close to this 6 year old thread. Final resting odometer reading on my Prius is 337,713. On the drive home from work I heard a loud bang under the hood, saw gray smoke and I quickly exited into a parking lot and the car began leaking oil like crazy. Looks like I blew a rod. Just wanted to update this post and say that the Prius has treated me very well and I am happy it lasted way longer than I thought it would. Bought the vehicle nearly 9 years ago back when it had 172,000ish miles on it and racked up roughly 165,000 miles on various road trips, vacations and commuting. It was bound to happen eventually and I just kept going to see how far it would last. Planning on selling it to the scrap yard sometime soon and replacing with a Kia Optima hybrid. So long fellas, it’s been fun.
    maleko, kutcht1 and oschn like this.
