Custom Radiator Project
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Aug 8, 2024.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    You misunderstand what 2 row means. Does a coolant in a 3 row radiator get passed 3 times? Does coolant in a 4 row radiator get passed 4 times? ALL coolant gets passed through a radiator ONE time.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,180
    919
    This is a two row with a double pass feature.
    There is a baffle on the opposite side of the tank and directs the fluid accross the middle of the core. The fluid collects on the opposite side of the tank, it flows back accross the core on the bottom.
    Images will give you an idea of how it is.
  3. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    How does that work when the radiator in your picture has inlet and outlet on opposite sides of the radiator? It is 3 pass with those hose attachment points?? Is only 2/3 off the radiator used for engine coolant?
    #23 TMR-JWAP, Aug 9, 2024
  4. AzusaPrius
    2,180
    919
    This is info I got from the maker and I know that image is not like mine and I had no idea it was a double pass until he told me those details.
    I just thought it was a normal two row at first, then he told me its a double pass also
  5. AzusaPrius
    2,180
    919
    @whitrzac that is funny I just put some water wetter in last week and it has helped a little, I may just put the rest of the bottle in though as I still have some.
    vvillovv likes this.
  6. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    Science would technically be on the side of the aluminum radiator in this case, even if it cooled the engine .1 degree over the OEM one. (And I am not even interested in this honestly). My Irony alarm goes off when I hear Pro- Science people denying it because the forum goblin said it was a good thing.
  7. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    It seems there are few goblins on this forum with a significant group in Southern California.
    Of all the things to worry about in a Prius, the largely bulletproof radiator is at the bottom of my list.
    Mr. F likes this.
  8. V Sport Wagon
    375
    131
    Southern California
    Goblins because they have a differing opinion than you, or? I am also in the camp of not needing this radiator..I was actually goblining on Asuza for it and throwing shade at mudder at the same time.
  9. AzusaPrius
    2,180
    919
    You would have to have someone custom make you one if you even wanted one.
    This is not something you will find for sale.
    V Sport Wagon likes this.
  10. whitrzac
    whitrzac Junior Member
    46
    madison
    Have you tried a 70/30 mix?
    If you dont live somewhere it gets <0 its a good option as well.
  11. AzusaPrius
    2,180
    919
    I just use 50/50 it does get to the teens where I live during the winter.
  12. AzusaPrius
    2,180
    919
    So just to make sure as I was just as confused when I was shown an image by the maker, I asked if it was double pass again and they just said it is not, which makes sense, because the inlet and outlet are on opposite sides.
    So it is just a two row radiator but it is what I wanted and had made anyway, someone on their end just didnt know or mixed up order information with mine.
    Brian1954 likes this.
  13. AzusaPrius
    2,180
    919
    Here are some side by side pictures to compare it to an OEM radiator. 20240814_131544.jpeg 20240814_131811.jpeg 20240814_133051.jpeg
  14. Brian1954
    Brian1954 Senior Member
    2,176
    852
    South Central PA, USA
    Can you please provide an update?
    Did you install the custom radiator?
    Is the engine coolant staying at a lower temperature? Please provide your temperature comparison with the stock radiator. Thank you.
  15. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    Another grandiose product without a need. The thermostat sets the engine temp. The existing radiator has Sahara desert at 85 mph capability.
  16. AzusaPrius
    2,180
    919
    @Brian1954
    No this is was not something that is easy and needs planning.
    When it is warmer, I will get it done.
    @PTS
    Lol yeah I dont have a problem with overheating for normal driving...lol
    Last week I took my prius to 104 mph and left a mad car behind my wake.
    I want this upgrade for when I take on freeways like the 14 & 15 Northbound during any hot weather.
    Yes the thermostat controls the flow of coolant, like a dam.
    But my dam reservoir will be bigger than yours.
    So I will have more cool coolant at the ready for longer durations if needed.
    I will probably never see 212F again
