My c v joint split near the tire.
Discussion in 'Gen 4 Prius Technical Discussion' started by Wraiththe, Aug 16, 2024 at 8:01 PM.
  1. Wraiththe
    Wraiththe Member
    261
    49
    Charlotte NC
    My 2017 previous for as C V joint boot split close to the tire. Looks like it is around it in one of the creases. The standard is just to replace the whole c v joint but I was wondering if there's any way to fix or replace the boot. It is not cheap. They say you cannot replace the grease either. It works fine with no noise.
    Isnthere anyway to fix the boot only with out disassembly of the whole wheel suspension?
