My c v joint split near the tire.
Discussion in 'Gen 4 Prius Technical Discussion' started by Wraiththe, Aug 16, 2024.
  1. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    My 2017 previous for as C V joint boot split close to the tire. Looks like it is around it in one of the creases. The standard is just to replace the whole c v joint but I was wondering if there's any way to fix or replace the boot. It is not cheap. They say you cannot replace the grease either. It works fine with no noise.
    Isnthere anyway to fix the boot only with out disassembly of the whole wheel suspension?
  2. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    https://www.partsgeek.com/1cytkzr-toyota-prius-v-cv-boot-kit.html?gb=pp&cid=28884375&aid=4168799377&kid=1100003048855&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%28BSC%29&utm_term=1100003048855&utm_content=Toyota
    It'll require partial suspension disassembly. Lower control arm, sway bar, and steering joint needs to be disconnected. If you have an impact wrench, that'll make the job easier, when you bust the CV nut loose. Everything will swing out of the way. DO NOT touch any of the strut fasteners, otherwise you'll need an alignment. Most auto parts store will let you borrow or rent the CV nut socket and specialty tools you'll need to do this job.
    If road debris has already entered the CV joints & grease within, that half shaft may fail within the next year or two. Popping, scraping, and howling sounds. This is why most shops will only warranty a half-shaft replacement; not a boot replacement.
    Hope this helps....
    FYI: If you have issues reassembling; try rotating the half-shaft while pushing back against the transmission. Sometimes the knuckle on the other end of the shaft gets dislocated, That why it looks like it won't fit back together. Once everything gets realigned, everything should lineup and bolt back up. Reassemble in reverse order.
    #2 BiomedO1, Aug 16, 2024
    Wraiththe likes this.
