Oil Catch Can are useless
Discussion in 'Gen 3 Prius Main Forum' started by abubin, Jan 30, 2023.
  1. Eddie25
    Eddie25 Active Member
    387
    143
    IL
    Generic amazon 350ml located under the engine. I take out the air filter box to dump it between oil changes, takes about 10 min. It wouldn't bother me if it filled up faster in the summer and not the winter. I suppose I could have located it up top and that would pretty much solve my issue.
  2. Mendel Leisk
    38,866
    Maybe that can just isn’t very effective; does it have internal baffling?
    mikey_t likes this.
  3. ColoradoCrow
    ColoradoCrow Active Member
    977
    396
    Leawood, KS
    I
    OMG. I just spit out my drink! ROFLMAO!.. My wife and I HAVE HEATED ARGUEMENTS OVER MY DIRTY SHOP TOWELS. after 13 years of marriage............we now have rules...
    LOL. I now have my own stash that are MINE. We have a drawer full for the FAMILY to use..and SHE has HERS in a super secret stash somewhere in the woman cave. NO JOKE.
    TGrracie, bisco and mikey_t like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,322
    6,001
    Columbia, SC
    The wife and I came to a compromise a couple years ago, actually. I keep a cardboard box in the garage near the door that goes into the house/kitchen area. When she has any household towels that she deems no longer worthy of keeping (regardless of size or where used), she washes them one last time and then places them in that box, where they officially become shop rags. I have quite an abundant supply. Anywhere from beach towels to facecloths. I still like to grab one from the kitchen every now and then just to keep her guessing..
    Sub4Medic likes this.
  5. donzoh1
    donzoh1 Active Member
    441
    151
    Lenexa, KS
    Correct. The Gen 3 intake manifold does a great job at catching oil, sludge, carbon, water, etc. In fact, it's so effective, it can completely defeat the EGR process, causing broken head gaskets and piston rods, etc.
  6. ChapmanF
    15,851
    It's hard to keep track of all the "x causes broken head gaskets and rods etc." stories floating around PriusChat. Some are less persuasive than others, but we might just have set a new record.
  7. rjparker
    8,091
    4,799
    You are right. As noted above, more recent engine designs drain the condensate back to the sump. The condensate volume is much less in engines without low tension rings and a low PCV valve location.
  8. DPri
    DPri Junior Member
    40
    Earth
    xliderider and PriusCamper like this.
  9. gboss
    gboss Member
    107
    35
    Mountain Town in CA
    This is a decent point. Why don't people just siphon out the oil from the intake every oil change instead of using an OCC. It's easy to do and easy to access.
  10. Mendel Leisk
    38,866
    What percent of the oil/gas/water delivered via the PCV is waylaid by the intake manifold? And how much passes right through?
    I prefer opening the drain tap on an oil catch can to pulling the intake manifold. To be fair every few years I’ve been pulling them (dual Moroso 85474 cans in series) for cleaning their interiors.
    #30 Mendel Leisk, Aug 21, 2024 at 8:33 AM
  11. PriusCamper
    PriusCamper Senior Member
    11,185
    4,558
    Pacific Northwest, USA
    I think this is not done because there's more than enough room and it getting too full has never been documented... Suspect all that air getting sucked thru their helps to keep it from getting that way.
  12. Danno5060
    Danno5060 Member
    210
    93
    Wyoming
    That clickbait title and picture shows what's going on when there's a serious problem, like a blown head gasket.
    I seem to be the odd guy here, in that I don't think of it as much of a problem. Yeah, it's nasty-looking, gunky, and messy. It also works to some degree like an oil bath air intake filter too. (This is what some cars, tractors, and other engines used to trap particulates in the engine intake pre 1950's).
    With a Gen 3, I pull off the intake manifold when servicing the EGR - cleaning the throttle body and intake manifold along the way. Unless there's a serious problem with the engine, the intake manifold build up less than 1/8" of oil and crap. I just don't think that's enough to crawl up the inside of the intake manifold and work its way into the engine intake. I also change the PCV valve, just because I'm there too.
    If it makes you feel better, yeah run a catch can. I just don't see where it's really that much of an improvement. Like I said, I seem to be in the minority here.
  13. Mendel Leisk
    38,866
    What's feeding into the intake manifold via the PCV hose is a fine mist. Short-sighted to think it all liquifies and condenses neatly at the bottom of the intake manifold? Maybe that portion is 50%? Less?
    The gunk you clean out of the intake ports is oily; that's not from the EGR.
  14. Danno5060
    Danno5060 Member
    210
    93
    Wyoming
    I may need glasses, but I'm not short-sighted in that way.
    The oil and gunk I'm talking about pools in the bottom of the intake manifold underneath the throttle body. To me, this is the result of how the PCV system works. Yeah, it starts off in the crankcase as oil and water vapors, as well as piston ring blowby. I believe it can act as an oil bath air cleaner, trapping particulates as well as other things that make it through the air filter.
    It is not from the EGR system. I never said that. it's from the PCV system. I only suggested that the oil and stuff doesn't build up that much if you clean it out when you regularly service the EGR, and that there may actually be a positive benefit from having a little oil at the bottom of the intake manifold.
  15. xliderider
    xliderider Senior Member
    7,890
    3,125
    Honolulu, HI
    And what Mendel was saying was that there's still oil in the actual intakes on the head, so the intake manifold isn't catching as much as it could. Therefore, the reason some of us add an OCC to the path between the PCV valve and the IM.
    SM-G781V ?
  16. ASRDogman
    ASRDogman Senior Member
    6,150
    3,304
    :eek::eek::eek:
    That's like the so called "water saver" low flow for faucets and showers....
    You NEVER "save" any water. If you need 1 qt of water, you don't save anything
    by taking 1 minutes to get a qt verus 15 seconds.
    So if you change your oil every 1000 miles, you'll never have to add any, thus it's not burning oil. :whistle:(y)(n)
