Oil Catch Can are useless
Discussion in 'Gen 3 Prius Main Forum' started by abubin, Jan 30, 2023.
  1. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Generic amazon 350ml located under the engine. I take out the air filter box to dump it between oil changes, takes about 10 min. It wouldn't bother me if it filled up faster in the summer and not the winter. I suppose I could have located it up top and that would pretty much solve my issue.
  2. Mendel Leisk
    42,382
    Maybe that can just isn’t very effective; does it have internal baffling?
    mikey_t likes this.
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    OMG. I just spit out my drink! ROFLMAO!.. My wife and I HAVE HEATED ARGUEMENTS OVER MY DIRTY SHOP TOWELS. after 13 years of marriage............we now have rules...
    LOL. I now have my own stash that are MINE. We have a drawer full for the FAMILY to use..and SHE has HERS in a super secret stash somewhere in the woman cave. NO JOKE.
    TGrracie, bisco and mikey_t like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    The wife and I came to a compromise a couple years ago, actually. I keep a cardboard box in the garage near the door that goes into the house/kitchen area. When she has any household towels that she deems no longer worthy of keeping (regardless of size or where used), she washes them one last time and then places them in that box, where they officially become shop rags. I have quite an abundant supply. Anywhere from beach towels to facecloths. I still like to grab one from the kitchen every now and then just to keep her guessing..
  5. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Correct. The Gen 3 intake manifold does a great job at catching oil, sludge, carbon, water, etc. In fact, it's so effective, it can completely defeat the EGR process, causing broken head gaskets and piston rods, etc.
    Sub4Medic likes this.
  6. ChapmanF
    19,061
    It's hard to keep track of all the "x causes broken head gaskets and rods etc." stories floating around PriusChat. Some are less persuasive than others, but we might just have set a new record.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,150
    6,989
    Texas Hill Country
    You are right. As noted above, more recent engine designs drain the condensate back to the sump. The condensate volume is much less in engines without low tension rings and a low PCV valve location.
  8. DPri
    DPri Junior Member
    40
    Earth
  9. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    This is a decent point. Why don't people just siphon out the oil from the intake every oil change instead of using an OCC. It's easy to do and easy to access.
  10. Mendel Leisk
    42,382
    What percent of the oil/gas/water delivered via the PCV is waylaid by the intake manifold? And how much passes right through?
    I prefer opening the drain tap on an oil catch can to pulling the intake manifold. To be fair every few years I’ve been pulling them (dual Moroso 85474 cans in series) for cleaning their interiors.
    #30 Mendel Leisk, Aug 21, 2024
  11. PriusCamper
    PriusCamper Senior Member
    13,476
    5,443
    Pacific Northwest, USA
    I think this is not done because there's more than enough room and it getting too full has never been documented... Suspect all that air getting sucked thru their helps to keep it from getting that way.
  12. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    That clickbait title and picture shows what's going on when there's a serious problem, like a blown head gasket.
    I seem to be the odd guy here, in that I don't think of it as much of a problem. Yeah, it's nasty-looking, gunky, and messy. It also works to some degree like an oil bath air intake filter too. (This is what some cars, tractors, and other engines used to trap particulates in the engine intake pre 1950's).
    With a Gen 3, I pull off the intake manifold when servicing the EGR - cleaning the throttle body and intake manifold along the way. Unless there's a serious problem with the engine, the intake manifold build up less than 1/8" of oil and crap. I just don't think that's enough to crawl up the inside of the intake manifold and work its way into the engine intake. I also change the PCV valve, just because I'm there too.
    If it makes you feel better, yeah run a catch can. I just don't see where it's really that much of an improvement. Like I said, I seem to be in the minority here.
  13. Mendel Leisk
    42,382
    What's feeding into the intake manifold via the PCV hose is a fine mist. Short-sighted to think it all liquifies and condenses neatly at the bottom of the intake manifold? Maybe that portion is 50%? Less?
    The gunk you clean out of the intake ports is oily; that's not from the EGR.
    avachell likes this.
  14. Danno5060
    405
    209
    Wyoming
    I may need glasses, but I'm not short-sighted in that way.
    The oil and gunk I'm talking about pools in the bottom of the intake manifold underneath the throttle body. To me, this is the result of how the PCV system works. Yeah, it starts off in the crankcase as oil and water vapors, as well as piston ring blowby. I believe it can act as an oil bath air cleaner, trapping particulates as well as other things that make it through the air filter.
    It is not from the EGR system. I never said that. it's from the PCV system. I only suggested that the oil and stuff doesn't build up that much if you clean it out when you regularly service the EGR, and that there may actually be a positive benefit from having a little oil at the bottom of the intake manifold.
  15. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    And what Mendel was saying was that there's still oil in the actual intakes on the head, so the intake manifold isn't catching as much as it could. Therefore, the reason some of us add an OCC to the path between the PCV valve and the IM.
    SM-G781V ?
  16. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    :eek::eek::eek:
    That's like the so called "water saver" low flow for faucets and showers....
    You NEVER "save" any water. If you need 1 qt of water, you don't save anything
    by taking 1 minutes to get a qt verus 15 seconds.
    So if you change your oil every 1000 miles, you'll never have to add any, thus it's not burning oil. :whistle:(y)(n)
    mhdriver likes this.
  17. mhdriver
    mhdriver Member
    162
    61
    florida
    Where can I buy the best oil catch can setup?
  18. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    I've heard of OCCs in forced induction / turbo engines, but on a Prius...idk. Removing oil where it doesn't belong is always good, but even if these Gen 3 PCV valves are located on the lower part of the engine...I don't see it being a huge issue vs. not running one. We still have clean the EGR anyway. I'll do without for another 60k and install an OCC if the EGR is super clogged again.
    If you're in CA, high chance of failing the SMOG test with a catch can installed. If you're in colder climates, I'd be careful of letting oil/sludge clog the extra tubing that you're installing with the OCC during sub freezing temps.
    Sometimes I question the need for minor preventives. I just cleaned the hybrid battery fan after 111k and sure, it was dirty....but the mass of the removed dust was so marginal that I highly doubt whether it was affecting the efficiency or drag of the fan. It was good to check and make sure it wasn't clogged, but in my case it was definite overkill.
    bettergolf and Danno5060 like this.
  19. avachell
    avachell New Member
    TN
    My suspicion is it's the oil in the intake manifold that's the reason for the carbon deposits on intake ports, valves, injectors, and EGR system.
    I would love to talk with someone that's managed to eliminate the oil in the IM to find out how they did it, and if they are still getting the usual carbon deposits.
    After becoming aware of this problem on my Gen 3 at 150k miles, I cleaned all the carbon from the IM and EGR system. I installed a catch can, relocated the PCV valve to just before the catch can (the oil has to travel vertically up 1' of hose just to enter the PCV and the OCC), added an additional PCV on the outlet of the OCC to protect the OCC from backfire, then 18" of hose back to the IM, and I'm STILL accumulating oil under the throttle body in the IM. The only way I can explain this is if the oil is traveling as a vapor all the way through the PCV system. If it's a vapor when it enters the IM, it must be being pulled into the cylinders and turned into carbon on all the hot surfaces.
    I'm not a mechanic or any kind of expert, just my speculations. I am still searching for ways to keep the oil out of the IM to test my hypothesis. But as others have already stated, it's not all that hard to clean these components every 100k miles or so, but does seem like there is room for improvement in the design.
  20. Mendel Leisk
    42,382
    Hello :)
    I've got a couple of Moroso 85474 in series, between the PCV valve and the intake manifold. That's getting "close" I think, though some does still get through. Also, the dipstick on ours never budges, between oil changes.
    EGR system still accumulates carbon. My take: carbon particles in the exhaust is a natural consequence of a combustion engine, any engine, regardless of condition.
    This is somewhat telling I think: for gen 4 Toyota more-or-less doubled the cross-sectional area of the EGR components, and rerouted the intake, to be downstream of the catalytic converter. Perhaps they've revised the performance of the valve too. Seems to have done the trick: gen 4 owner with over 300k miles requested his EGR system to be cleaned at Tampa Hybrids; there was very minor deposits.
    Cold comfort for gen 3 owners.
    #40 Mendel Leisk, Nov 20, 2024
