Airbag warning light/Cruise control issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kevin Boulange, Sep 2, 2024 at 9:12 PM.
  1. Kevin Boulange
    Kevin Boulange Junior Member
    Ocean View Hi 96737
    aloha ... so the other day my cruise control light decided to stay lit up and then the next day when I tried to turn on my cruise control it wouldn't turn on. I have visually checked both front seat electrical plug ins under the seats and they look good....tried to disconnect battery to reset...also didn't work....when I looked at the fuse box under the hood I did not see one that referenced the airbag nor the CC. Anybody have any suggestions on how I can fix this problem? Mahalo Kevin
  2. ASRDogman
    ASRDogman Senior Member
    6,200
    3,317
    I would suggest a code reader for a Prius and see if there are any codes....
    Then post them here.
  3. Tombukt2
    9,707
    1,697
    Isn't there a fuse box behind the little door in the console or in the dash under the dash like where your left knee is when driving or something along those lines I think that's where your SRS and all of that fuses are
  4. Kevin Boulange
    Ocean View Hi 96737
    I only have a TORQUE OB2 reader....$15.00 and no codes...bought the autelAP2500E but it wouldn't work with my phone or laptop so returned it. I,ve got an old motorola phone and an ACER that's about ten yrs old for laptop.... as you can tell I'm not a tech guy but seem to struggle along ok! What would you suggest for a simple code reader that would work for me?
  5. Kevin Boulange
    Ocean View Hi 96737
    Looked there and didn't see it....but it looks like in the owner's book that there is another fuse panel ..... i did see a plastic nut type thing forward from the hood latch but when i unscrewed it I couldn't get that cover? to budge and didn't want to break it ...is that it you think?
