Airbag warning light/Cruise control issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kevin Boulange, Sep 2, 2024.
  1. Kevin Boulange
    Kevin Boulange Junior Member
    Ocean View Hi 96737
    aloha ... so the other day my cruise control light decided to stay lit up and then the next day when I tried to turn on my cruise control it wouldn't turn on. I have visually checked both front seat electrical plug ins under the seats and they look good....tried to disconnect battery to reset...also didn't work....when I looked at the fuse box under the hood I did not see one that referenced the airbag nor the CC. Anybody have any suggestions on how I can fix this problem? Mahalo Kevin
  2. ASRDogman
    ASRDogman Senior Member
    7,981
    4,051
    I would suggest a code reader for a Prius and see if there are any codes....
    Then post them here.
  3. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Isn't there a fuse box behind the little door in the console or in the dash under the dash like where your left knee is when driving or something along those lines I think that's where your SRS and all of that fuses are
  4. Kevin Boulange
    Ocean View Hi 96737
    I only have a TORQUE OB2 reader....$15.00 and no codes...bought the autelAP2500E but it wouldn't work with my phone or laptop so returned it. I,ve got an old motorola phone and an ACER that's about ten yrs old for laptop.... as you can tell I'm not a tech guy but seem to struggle along ok! What would you suggest for a simple code reader that would work for me?
  5. Kevin Boulange
    Ocean View Hi 96737
    Looked there and didn't see it....but it looks like in the owner's book that there is another fuse panel ..... i did see a plastic nut type thing forward from the hood latch but when i unscrewed it I couldn't get that cover? to budge and didn't want to break it ...is that it you think?
  6. ChapmanF
    18,892
    The Cruise Control is a few extra lines of code running in the power management control ECU. Those lines of code don't have their own fuse. :) That ECU gets power from the AM2, IGCT, and IGCT No. 2 fuses (and if that ECU were not getting power, cruise control would be the least of your complaints).
    Really, the way forward is to get a suitable scan tool and start asking the ECU what's up with the cruise control.
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The code is either there or it isn't.
    What's on your dashboard? Do you have a photo?
  8. ASRDogman
    7,981
    4,051
    Without a proper code reader, or scanner, you're just guessing.
    So you either have to go somewhere that has one, or purchase one.
    If you plan on working on your Prius, you're going to have to invest in some modern equipment.
    Doing a visual look at fuses and connectors is the simplest and quickest.
    But without the proper tools..........
    If one of the abs wheel sensors is damaged or defective, the cruise won't work...
  9. Kevin Boulange
    Ocean View Hi 96737
    Ok thanks ChapmanF
  10. Kevin Boulange
    Ocean View Hi 96737
    Ordering a scan tool today....thanks ASRDogman
    ASRDogman likes this.
  11. kenneth winter
    kenneth winter Junior Member
    38
    tn
    Chapman, you seem to have a good understanding of the cruise system. My air bag system has been removed (race car). This deletion obviously sends out a DTC to the car. The Cruise is in an error state due to the Air bag DTC. How can I fool the Cruise module into working? With a scan tool I see and cruise error due to the air bag.. What signal is the cruise unit seeking to turn on.. I have tested every cruise function all buttons activations are present. but the Cruse will NOT lock in the target speed.. I need to fake the signal from the AIrbag module to the Cruise module.. I dont know if its a low voltage signal, a Canbus signal... Please share your thoughts..
  12. Tombukt2
    13,765
    2,491
    Durham NC
    So Prius wiring is in this old vehicle complete? Seems like some sort of dummy yellow connectors could be rigged to make the srs system communicate to dummy bags that are disarmed maybe. Been on Toyota modifications site . Is very old site .people all over world working on similar antics . Maybe Blizilla is still on the net.could be a great resource.msybe silent after 30 years do not know.
  13. ChapmanF
    18,892
    I don't have gen 2 books handy at the moment, but I know the HV control ECU is on the CAN bus and I suspect the airbag ECU is also, and they communicate using CAN messages. If you used a CAN protocol analyzer to look at the conversations between them, maybe you could build something that would send convincing messages as if it's the airbag ECU, or respond to messages from the HV control ECU and send convincing replies.
    Is cruise control often used in race cars?
