Red Triangle keeps coming on intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AnnaBiJou, Aug 21, 2024.
  1. rjparker
    8,144
    4,823
    Translated: The tech is not competent enough to find an open wire that is well documented by Toyota.
    Obtaining the drawings from the Toyota TIS system would be the first thing an experienced tech would do. He would want to understand the circuit prior attempting anything. The TIS system requires paid access ($25 for two days) and some experience to navigate and ultimately understand the drawings.
    TIS System
    Jumping 12v past a suspected open in a wire harness by an untrained person could cause even more problems. Ecus could be permanently damaged guaranteeing a junk yard exit for the car.
    P Lock C2310 Fix Fixed Solved Solution | PriusChatIt
    Right now the right tech might fix it for one or two hours labor. Unfortunately dealer mechanics are not the best resource these days.
    I would find an independent automotive diagnostician like Ivan at Pine Hollow diagnostics or a similar recommended shop near you.
    Pine Hollow Auto Diagnostics - Home
    #21 rjparker, Aug 25, 2024
    MAX2 likes this.
  2. pasadena_commut
    pasadena_commut Senior Member
    1,573
    471
    Southern California
    I don't know if this would fit under the fuse cover, but there are little fuse holders which are already tapped that can go into the slot instead of the fuse, and then the fuse is plugged into this new part. Here is a picture of one (this particular one holds two fuses, you don't need that, just one fuse slot, and in this one the fuse goes in sideways):
    https://www.napaonline.com/en/p/NW_785135
    Pull the fuse and plug this tap in. Don't install the fuse yet. Turn on the car (expect error codes/warning lights as that circuit will not be powered). Check the voltage in the crimp with respect to ground (bare metal on the car frame, usually a bolt head). If you see +12V turn the tap around. You should now see no voltage (probably 0V, but it might be wandering around because the wire is dangling in space and its voltage is more "undefined" than "zero"). Now put the fuse in, and that tap wire should read +12V. The wire is now tapped in downstream from the fuse, and anything attached to that wire will be protected by the fuse.
    The other way to do this is to get underneath the fuse box and find where the wire for that circuit comes out, and then use a tap like this (there are many varieties of taps, this is just one type):
    Posi-Tap- No Crimp Tap
    on the wire.
  3. AnnaBiJou
    AnnaBiJou Junior Member
    Willington, CT
    Apologies for going quiet for a while, it's been rather busy at home lately.
    I can't get Techstream to work, it's supposed to come with drivers according to the website, but the download link just gives me the patches to run the software with, neither of which worked when I had the Tactrix plugged into the car.
    Am I missing something? A driver download I've been overlooking maybe?​
  4. dolj
    dolj Senior Member
    7,758
    3,929
    Wellington, New Zealand
    If you are using the Tactrix OpenPort cable, you need to install the driver that came with that cable. There should be no other "Techstream" drivers needed as the Techstream installer should load everything required on the Techstream side.
    However, within Techstream, you need to ensure you have the Tactrix VIM (as they call it – Vehicle Interface Module) selected.
    Instead of showing XHorse - MVCI as illustrated above, yours should show the relevant Tactrix VIM.
    I hope that helps.
    Brian1954 likes this.
  5. AnnaBiJou
    Willington, CT
    Alright, got the driver from the taxtric website, installed it, switched to the tactrix VIM on Techstream. If I run the 64bit patch while plugged into the car, it should work, is that right? I'm getting the software registration popup whenever I try to do anything through the Techstream.​
  6. pasadena_commut
    1,573
    471
    Southern California
    If this is the legal version from Toyota you will need at least a temporary license. I imagine that what you do on a hacked version will vary from one to another. For starters though I would try turning off the network before running Techstream. It may be trying to communicate with some Toyota server and the version you are running may not be currently authorized to do so. If you can get past that step it might run.
  7. AnnaBiJou
    Willington, CT
    I will try that thank you very much for your help.​
  8. rjparker
    8,144
    4,823
    Many of the hacked versions require manual editing of the Windows Registry. Most use the “mini-vci” (mvci or just vci) hardware interface which often comes with an executable to change the registry.
    Plus these considerations are from a hacked Techstream install file set of instructions:
    Registry Hack: Run the [ VCIi-64bit.reg ] file to modify the registry for Techstream to recognize MINI-VCI under Windows x64
    Note: some antivirus program(Such as Norton/McAfee) may take the registration files to be a threat to the computers and delete them automatically which will make the software incomplete, if you meet the case, please just disable the antivirus before loading software and installation…
    Click "Software Registration" , copy and paste this code then click "OK" :
    1111111111111111111111111111111150001703161820
    (2) The software we provide is a offline standalone version, If someday you get a Update Notification from Toyota web to ask you upgrade your current TIS Techstream software , DO NOT do it , just click cancel and move on if you don't have a official Toyota TIS account . Disable internet , Uninstall program , then reinstall and use program without internet …
    With that said many get it running on an old Windows xp or 7 machine with disabled WiFi and internet.
    Toyota now has a completely new version which has not been hacked.
    #28 rjparker, Sep 3, 2024 at 3:35 PM
  9. AnnaBiJou
    Willington, CT
    #29 AnnaBiJou, Sep 3, 2024 at 3:47 PM
