2nd gen headlight upgrade in 2024
Discussion in 'Gen 2 Prius Main Forum' started by lex, Aug 16, 2024.
  1. Tombukt2
    9,725
    1,698
    Their H4 bulbs If you have fog lights that take H4 lamps you've got something going on some old Cibe or hella of many years ago. So there's always that most fog lights don't take anything near an H4 they don't have high beams generally fog lights etc so I think just the wording is wrong in the ad which I could care less about these are H4 bulbs they call them fog lights I don't care if they called them poop lights makes no difference that's the Chinese for you that's how they do things they're not fog lights there H4 bezel lamps made to go in H4 housings which generally aren't fog lights but okay this is what I have in three of my generation twos the other one is HID with the D4S to LED conversions plugged in with nothing else done oh well I don't know what to tell you those are quite bright and if you crank your adjusters down and get your cut off on the wall set right You should be in good shape if your lenses aren't completely fogged they work very well I'm quite happy without having to oven bake everything apart install merimoto mini projectors and all that nonsense but hey.
  2. lex
    lex 2005 Prius, always garaged
    105
    Fresno
    Installed new LEDs – without removing any panels –and, though difficult, requiring much dexterity and some time. managed. However, the beam pattern appears odd – slanting from top right to bottom left.
  3. dolj
    dolj Senior Member
    7,763
    3,929
    Wellington, New Zealand
    Maybe the bulb is not seated correctly. Off-axis maybe?
  4. Tombukt2
    9,725
    1,698
    Receipt your bulb in the wire clips make sure it's in their proper it's H4 tab goes up to the top and the other two at what four and 5:00 or something like that and then after you get all that done you need to crank down righty tighty on your adjuster about eight half turns That's what you do with the screwdriver when you turn it once you make a half turn because that's what your hand does then you'll see the cutoff line magically appear on your garage wall now you set that line at whatever height you've been reading about sheets running done.
