Too late? Transmission Fluid Change 170k miles, New Prius Owner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Sullivan, Jun 26, 2023.
  1. Mendel Leisk
    38,902
    If you check the Toyota USA Warranty and Maintenance Booklet, I believe towing is one criteria it mentions, where Toyota concedes a transaxle fluid change should be done regularly.
    There’s a link in my signature on this maintenance. 3rd Gen Prius and Prius v should be the same. On a phone turn it landscape to see signature.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,227
    2,242
    Taylors, SC
    Toyota does not recommend towing, however, Toyota does recommend transaxle fluid changes under severe service conditions.
    Obviously, towing a trailer is severe service.
  3. gboss
    gboss Member
    126
    45
    Mountain Town in CA
    Is there any risk to changing the transaxle fluid at this mileage or even 111k miles?
    Doesn’t make sense as to why, I’m reading a lot of things that say it could cause damage to the engine, even the YouTuber Scotty Kilmer recommends against changing it.
  4. Georgina Rudkus
    3,227
    2,242
    Taylors, SC
    That's for a regular automatic transmission with bands and clutches.
    The e-CVT in a Prius change of fluid can be done at any time. Clean fluid at any mileage for a Prius is better than dirty fluid.
    gboss likes this.
  5. Mendel Leisk
    38,902
    Where's his braying horse meme when I need it. :)
    gboss likes this.
