Gen 4 Prime ATF drain plug
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by BiomedO1, Sep 16, 2023.
  1. BiomedO1
    BiomedO1 Senior Member
    4,527
    2,380
    Left Coast
    I just need reassurance that I'm going after the right drain plug. It's a 10mm hex on the bottom of the tranny. My old 2012 Prius C - that would be the tranny coolant plug - so I stopped and decided to check with you guys first. I don't have any Toyota coolant on hand.
    See attach picture, down arrow is drain plug - up arrow is fill plug (next to passenger side drive shaft).
    I'll post pictures of ATF, currently @ ~32K.
    Thanks in advance...
  2. Mendel Leisk
    42,271
    Hard to judge from your pic; here's the ID from the Repair Manual (full instruction attached). Seems very close to the split-line between transaxle and engine.
    BiomedO1 likes this.
  3. BiomedO1
    4,527
    2,380
    Left Coast
    Yep, that's it - my picture is 180 degrees from your picture. and thanks for the torque specs. too.
    It looks like the coolant change will be really easy on this car too. There's two stop-cocks on the drivers side radiator. Tracing the hoses, looks like the lower is Transmission coolant, upper engine coolant.
    ColoradoBoo likes this.
  4. Mendel Leisk
    42,271
    Attached.
  5. BiomedO1
    4,527
    2,380
    Left Coast
    Here's the result of the ATF change on a 2021 Prime w/32K miles. 20231002_110431.jpg
    I had similar results with my 2012 Prius C @ 25K mile ATF change. Left is what came out, right is what was left over from the 4 quarts. I used a 3 foot hose and filled from above, so some additional lost in the hose.
    ccna101 and Mendel Leisk like this.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,338
    961
    Monument, Colorado USA
    Yep, good job....I was pleasantly surprised at Toyota engineers for making this maintenance so easy....not much harder than an oil change! (For me, the hardest part was getting those darn drain plugs to break free...someone needs to tell the factory installers the torque is 37 ft/lbs not 400!!!!)
  7. Mendel Leisk
    42,271
    And dealership charge through the roof, most recently $400 USD quote here.
  8. ColoradoBoo
    1,338
    961
    Exactly! My dealer charges the same for a much-more-difficult V-8 Tundra as a Priis...$310!!
  9. BiomedO1
    4,527
    2,380
    Left Coast
    It was about $75 USD for the 4 quarts. I probably should've gone the Amazon or Ebay route.:sick::whistle:
    Neighbor is a big Toyota fan, and was shocked at the ATF color at only 32k miles.:p
  10. Mendel Leisk
    42,271
    Last time I bought up here Toyota ATF WS was around $10~11 CDN per liter. But that was a few years back, and I know Toyota motor oil has really gone up.
  11. ColoradoBoo
    1,338
    961
    My 2008 Corolla had a dipstick so it was super easy to see the condition of the transmission fluid....bugs me how we don't have that luxury now. (Easier to fill it, too.) My co-worker has a BMW and it doesn't even have a dipstick to check the engine oil....how dumb is that???
    When I changed my wifes 2017 Prius transmission fluid at the 5-year point, it only had 29,000 miles and wasn't very dirty. I've heard of some folks changing it out every 2-years but transmission guys say that's actually not good because it does need a little bit of friction in there to help everything move around better. (I just do every 5-years or 50,000 miles, whichever comes first.)
  12. ColoradoBoo
    1,338
    961
  13. Trollbait
    12,806
    It's an ATF, and the pre-gen4 Prii don't have an auxiliary cooler. So the fluid gets 'burnt'. But it isn't an automatic transmission. The fluid doesn't have to work as an hydraulic fluid. It just lubricates. It getting burnt likely has no effect on its lubricating properties. The addition of the cooler in the gen4 seems to be more for towing that is done in other markets.
    Toyota should have used a mnaul transmission fluid for the transaxle, but the ATF was on hand and low viscosity for efficiency.
  14. BiomedO1
    4,527
    2,380
    Left Coast
    Let us know how it looks @ the 5 year or 50K mile point. After the first drain on my old 2012, AFT was significantly cleaner @ the 60K mile change. I'm pretty sure I could've pushed it out to 80K-100K miles, to get it to the current color of my 32K mile change out.
  15. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Ah, something I am due for our 20PP too ?
    I am familiar with the normal -partial flush-refill and repeat (2-3 times) : it this what we are doing here ? any DIY linky?
    TIA,
  16. Mendel Leisk
    42,271
    A single drain gets maybe 90%, no need for multiple drain/fill procedure. I wouldn't do that with a conventional automatic either; just periodically drain/fill, at a more frequent interval.The only time I'd do multiple drains and fills is in a contamination case, say you accidentally poured motor oil in (I did this one time, with a previous car...:unsure:).
    DIY linky attached.
    ccna101 likes this.
  17. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Thank you Mendel... I will gather fluid and get it going ...
    My pass Ody (312k, still going) which needs -regular- tranny flush- ... for some reason, I totally forget about the 20PP :)
    EV-
  18. Mendel Leisk
    42,271
    There's a link in my signature regarding third gen transaxle fluid change, primarily DIY tips, and it's mostly relevant for the fourth gen I'd think.
    One thing I noticed with the fourth gen Repair Manual instruction, they really go on about keeping it sealed as much as possible, comparing to third gen. Maybe a nervous engineer. One thing I glean from that, plus a Toyota document on ATF WS, is that the fluid used should be from freshly opened bottles. I wouldn't go nuts, just drain it, get the new in, recycle any left over.
