2nd gen headlight upgrade in 2024
Discussion in 'Gen 2 Prius Main Forum' started by lex, Aug 16, 2024.
  1. dolj
    dolj Senior Member
    7,767
    3,933
    Wellington, New Zealand
    Maybe the bulb is not seated correctly. Off-axis maybe?
    Brian1954 likes this.
  2. Tombukt2
    9,761
    1,706
    Receipt your bulb in the wire clips make sure it's in their proper it's H4 tab goes up to the top and the other two at what four and 5:00 or something like that and then after you get all that done you need to crank down righty tighty on your adjuster about eight half turns That's what you do with the screwdriver when you turn it once you make a half turn because that's what your hand does then you'll see the cutoff line magically appear on your garage wall now you set that line at whatever height you've been reading about sheets running done.
  3. lex
    lex 2005 Prius, always garaged
    117
    Fresno
    The tab position seems correct – two at bottom and one at top I believe. It was the only way the bulbs fit in. Here's the beam pattern below. Another Prius group on Facebook suggested they're designed this way to mitigate the beams shining into drivers on the opposite side.
    I can adjust the passenger side height fine, but how to get to the driver's side adjuster? It's blocked by a top cover piece and seems necessary to remove. Those plastic screw fasteners are damaged easily.
    Noticing the high beams aren't substantially brighter but, otherwise, the overall light appears improved. Of course the light's color temp is modern.
    458086886_10161569726627232_4935235006418777759_n.jpg 458467469_10161569726472232_4876125029130212188_n.jpg 458491911_10161569726747232_3489089117178279499_n.jpg
    #43 lex, Sep 4, 2024 at 9:48 AM
  4. lex
    117
    Fresno
    And, interestingly, bizarrely, the car just sounded an alarm - for the first time ever. We don't have an added alarm package that I'm at all aware of (after 19 years). Driver parked in garage, came inside house, then suddenly – blaring honking, a siren, and all lights flashing. Again, this is a first. And the only thing that's changed is the bulbs. Possibly related. Or what could have started this? Thoughts please...
  5. pasadena_commut
    pasadena_commut Senior Member
    1,578
    473
    Southern California
    Regarding the alarm.
    There is a built in alarm, but it isn't normally enabled. It can be configured with Techstream. To see if that is enabled, roll down the passenger side window, park the car, close all the doors, lock it. Wait several minutes (I don't recall how long it takes to arm, 5 minutes maybe?), then reach in and open the door. If it goes off, then the alarm is enabled. Turn it off with key fob, I think lock and then unlock the door, maybe the other way around.
    There is some talk of a hood tamper sensor in one of the manuals, but I could never trigger it in my car. Possibly your car has a working one and it broke or unplugged, and now your car thinks the hood is open so sets off the alarm when it arms? It should be wired to at/near the hood latch release. A flaky sensor switch on any of the doors and maybe the hatch would also set off the alarm. I think it would have to short a wire to ground when it wasn't supposed to to trigger the alarm. That doesn't sound like a very common form of failure.
    lex likes this.
  6. lex
    117
    Fresno
    I am not particularly pleased with the quality of the light from the LEDs, specifically, how the light scatters in the reflector housing designed for halogen, not just the cutoff. And the lens plastic is still reasonably good. The lights do look strange, as though a lot of general light is thrown out in an unfocused direction. I suspect a halogen replacement that, as mentioned, is still brighter and whiter, may have been best in the housing designed for halogen..
    This has been time consuming. No replies bereft of punctuation, essential for readability and clarity, please.
    #46 lex, Sep 6, 2024 at 10:31 AM
  7. Has Raf
    Has Raf Junior Member
    35
    Stoke-on-Trent, England
    I agree. I’m gonna go for a halogen bulb as close to stock when I need to replace mine. No point faffing about with LEDs in my opinion. Maybe a whiter brighter Osram bulb perhaps!
    lex likes this.
  8. lex
    117
    Fresno
    I've done my best to query this issue, only belatedly coming across another discussion of this here:
    headlights: halogen to LED? | PriusChat
  9. dolj
    dolj Senior Member
    7,767
    3,933
    Ha ha, good luck with that!
  10. ChapmanF
    15,939
    I'm not sure there have been any of those ... bereft, a tense of bereave, makes one imagine a reply that at one time was happily and fulfillingly punctuated, only to live to see its punctuation cruelly and devastatingly stripped away.
    We do have a member here who often posts replies devoid of punctuation, but the thing is, I'm doubtful those replies ever had punctuation, so they can't be bereft.
  11. lex
    117
    Fresno
    A quick check may prove worthwhile.
    Bereft Definition & Meaning - Merriam-Webster
    Sense 1b aligns with the usage as intended, which is comparative to a general norm. Devoid certainly also applies.
  12. Has Raf
    35
    Best halogen bulbs then to put in a Prius gen 2? Any specific brands that are particularly good, and last a while?
  13. pasadena_commut
    1,578
    473
    Southern California
    The headlight photo near the start of the thread looks pretty clear, but the image wasn't sharp enough to tell for sure how clear. The little scratches and pits which accumulate can scatter a lot of light, never mind the horrible losses once the headlight yellows, fogs, or seriously degrades in some other way. If the headlights are generally OK, sometimes a light polishing to remove some of these tiny defects, but not go through the factory clear coat, followed by a coating of wax to fill what is left and reduce scattering (lately I have been using Nu Finish, as it seems to attract less dirt than carnauba wax) can go a long way to brighten the projected light.
    I would only use bulbs rated like the stock ones, probably from Philips or Sylvania. Bulbs with higher wattage will inevitably burn out faster, and they could even deform the headlights. Personally I hate having to stare into blue or very white headlights (color distribution at or above 5000K).
    This site has a lot of data in one place:
    BulbFacts | Halogen Bulb Chart - Comparing Halogen Bulbs in Reflector Headlights
    I ignore their recommendations though, it seems to follow from a philosophy of "brighter is better and nothing else matters". Not sure where the star ratings in the table come from, but note that things like rally lights, totally inappropriate for normal use, are usually rated higher than mundane road bulbs.
