timing Chain
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Oct 15, 2022.
  1. Tombukt2
    9,784
    1,708
    Yes I pulled the dipstick and I blot it on some like filter paper that's white then I can see the blackness a little bit of particulate matter smell how bad it smells how quick it lights with a lighter or flame and so on and in the morning I'll unscrew the 3600 large oil filter drain the mess out for a half a quart of pour through oil and let it run through and pick up what's on the bottom of the pan and let it sit open for about 30-40 minutes then drop fresh 5 30 and a new 3600 filter and off to the races if you will.
  2. 16 yrs & counting
    16 yrs & counting Junior Member
    76
    24
    Oakton, VA
    I see, so you waste a half a quart to clean it out?
    I was told that because the Prius runs on electric battery about half the time, you can go twice as long before changing the oil.
    Tombukt2 likes this.
  3. Tombukt2
    9,784
    1,708
    Husband tales.. yes I waste 3/4 of a quart at change to pour thru.. the 1 NZ our engines are more like reg ice car more so than mewer model's. So this model we can treat more like a Corolla than a hybrid when dealing with the engine part of it.
  4. 16 yrs & counting
    76
    24
    Oakton, VA
    NZ? Sorry, I don't understand your 2nd sentence
  5. Tombukt2
    9,784
    1,708
    1NZ that is the engine in mine and yours car that we're driving that you just had worked on.
  6. ChapmanF
    15,955
    Toyota has these funny engine designations. So the engine in a gen 1 or gen 2 Prius, or in a Prius c, is a 1NZ, the engine in a gen 3 or 4 Prius is a 2ZR, in a gen 5 it's M20A, and sometimes we throw those terms around on PriusChat to keep things interesting.
    Then there's Tom using speech-to-text a lot of the time, so stuff comes out 1 NZ instead of 1NZ, just to be a little extra mysterious.
