1. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,519
    Durham NC
    Yes I pulled the dipstick and I blot it on some like filter paper that's white then I can see the blackness a little bit of particulate matter smell how bad it smells how quick it lights with a lighter or flame and so on and in the morning I'll unscrew the 3600 large oil filter drain the mess out for a half a quart of pour through oil and let it run through and pick up what's on the bottom of the pan and let it sit open for about 30-40 minutes then drop fresh 5 30 and a new 3600 filter and off to the races if you will.
  2. 16 yrs & counting
    16 yrs & counting Junior Member
    77
    24
    Oakton, VA
    I see, so you waste a half a quart to clean it out?
    I was told that because the Prius runs on electric battery about half the time, you can go twice as long before changing the oil.
    Tombukt2 likes this.
  3. Tombukt2
    13,867
    2,519
    Durham NC
    Husband tales.. yes I waste 3/4 of a quart at change to pour thru.. the 1 NZ our engines are more like reg ice car more so than mewer model's. So this model we can treat more like a Corolla than a hybrid when dealing with the engine part of it.
  4. 16 yrs & counting
    77
    24
    Oakton, VA
    NZ? Sorry, I don't understand your 2nd sentence
  5. Tombukt2
    13,867
    2,519
    Durham NC
    1NZ that is the engine in mine and yours car that we're driving that you just had worked on.
  6. ChapmanF
    19,038
    Toyota has these funny engine designations. So the engine in a gen 1 or gen 2 Prius, or in a Prius c, is a 1NZ, the engine in a gen 3 or 4 Prius is a 2ZR, in a gen 5 it's M20A, and sometimes we throw those terms around on PriusChat to keep things interesting.
    Then there's Tom using speech-to-text a lot of the time, so stuff comes out 1 NZ instead of 1NZ, just to be a little extra mysterious.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Pushing the oil change intervals on any car is not a great idea. Even the manufacturer's suggested intervals are suspect - they are designed to get the car to the end of the warranty period, not to let the motor run for 400K miles. How often you need to change it will also depend on how the car is driven and it may not always be obvious. Days on the highway is not as hard on the car as tons of short trips. If you want to be analytical about it pick a good quality oil and stick with it, and send an oil sample off to be analyzed at, let's say, 5000 miles - if it tests "like new", push it to up to 7500, and so forth. Even if you find that way that you're good to 10000 miles you will still want to check the oil periodically, just in case something goes south during that long interval, and the car starts burning or leaking a significant amount of oil, or the oil is suddenly filthy or full of metal particles.
    On mine I change the oil at 5000 miles or one year. I'm more concerned with keeping the rings from sticking than the cost of extra oil changes.
    Be aware that these cars start to burn oil at 125K or 150K, not always a lot, but enough you have to keep an eye on the dipstick.
  8. 16 yrs & counting
    77
    24
    Oakton, VA
    Thanks for the tips!
  9. Jss4837
    Jss4837 New Member
    Springfield, MA
    Hey, I'm having the p0016 code myself now. Did you take it to just a regular mechanic to get this figured out, or to some hybrid specialist? Did they have to take apart the whole engine to discover that it was the ignition coil?
  10. Tombukt2
    13,867
    2,519
    Durham NC
    No generally speaking if you have that code that's telling you that the cam and crank signals are not in sync dirty oil will cause this also excessively dirty oil which I guess dirty is up the thing that controls the oil that makes the transition for your camshaft business so sometimes cleaning all that out housekeeping with carb spray what have you and then changing your oil you won't see that problem until your oil gets real dirty again 5,000 plus miles That's what happens right now in my '09 that's basically how I know I need to change the oil also I know by mileage but so now I don't make 10,000 mi oil changes anymore it's more about seven then the 0016 code will pop up I change the oil start and run the car and the code goes away I don't even have to clear it I'm pretty sure yeah I never clear it just goes away because with the clean oil and all that apparently something is more copesthetic internally and it seems to be okay I'm sure once it gets to a certain point there will be no getting it back and then you'll need a chain I probably need a chain now but this works this is a rarely driven car so such as life this car also has about 530,000 mi on it I was waiting for this to happen My '07 and my '08 with 190 and 247 respectively never do this so at 500k I'm not surprised and it's quite fine.
