Gen 3 vs Gen 4 water pump replacement
Discussion in 'Prius v Technical Discussion' started by Kpeeling, Aug 21, 2024.
  1. ChapmanF
    15,968
    Enough to make one wonder if some of those aftermarket labor rate figures also haven't been updated since the repair manual instructions were improved.
  2. V Sport Wagon
    V Sport Wagon Member
    290
    99
    Southern California
    No they haven't. I look at them daily.
  3. ChapmanF
    15,968
    Good to know, for people who rely on those sources to make labor estimates.
  4. V Sport Wagon
    290
    99
    Southern California
    I don't condone the use of them, they SHOULD be taking Toyota manual numbers. I think 11 is ridiculous and price gouging.
  5. Mendel Leisk
    38,934
    Anything you can share, regarding the revised instruction?
    Tim Jones likes this.
  6. ChapmanF
    15,968
    Follow links in #8.
  7. Tim Jones
    Tim Jones Senior Member
    1,724
    558
    SE Texas
    2011 Nissan LEAF
    The water pump should be replaced at 150,000 miles............... unless you want to possibly ruin the engine or cause more head gasket problems..... mine went out at 167,000
  8. Tim Jones
    1,724
    558
    SE Texas
    2011 Nissan LEAF
    You can easily replace the pump in under two hours.....
  9. V Sport Wagon
    290
    99
    Southern California
    Not on a Gen 4 you can't. Please provide a detailed video of such repair for us to see you or anyone do it with a timer on a laptop or clock in the video so it can be proven.
  10. Tim Jones
    1,724
    558
    SE Texas
    2011 Nissan LEAF
    I didn't say gen 4
    Gen 3
    Please supply a video of you taking a large dose of fentanyl
    #30 Tim Jones, Sep 11, 2024 at 1:20 PM
  11. ChapmanF
    15,968
    In fairness, this was a thread started to compare the gen 4 vs. gen 3 water pump labor complexity.
    On the other hand, the person who started it seemed to be thinking a 2017 v is a gen 4, when it isn't.
    On the third hand, even for gen 4, the Toyota Flat Rate Manual time for the job did go from 7 hours down to 1.3 hours (which I would think qualifies as "under two hours"), once they improved the Repair Manual procedure to no longer have step 1 be "remove engine assembly with transaxle".
