Gen 3 vs Gen 4 water pump replacement
Discussion in 'Prius v Technical Discussion' started by Kpeeling, Aug 21, 2024.
  1. ChapmanF
    18,966
    Enough to make one wonder if some of those aftermarket labor rate figures also haven't been updated since the repair manual instructions were improved.
  2. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    No they haven't. I look at them daily.
  3. ChapmanF
    18,966
    Good to know, for people who rely on those sources to make labor estimates.
  4. V Sport Wagon
    375
    131
    Southern California
    I don't condone the use of them, they SHOULD be taking Toyota manual numbers. I think 11 is ridiculous and price gouging.
  5. Mendel Leisk
    42,288
    Anything you can share, regarding the revised instruction?
    Tim Jones likes this.
  6. ChapmanF
    18,966
    Follow links in #8.
  7. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    The water pump should be replaced at 150,000 miles............... unless you want to possibly ruin the engine or cause more head gasket problems..... mine went out at 167,000
  8. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    You can easily replace the pump in under two hours.....
  9. V Sport Wagon
    375
    131
    Southern California
    Not on a Gen 4 you can't. Please provide a detailed video of such repair for us to see you or anyone do it with a timer on a laptop or clock in the video so it can be proven.
  10. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I didn't say gen 4
    Gen 3
    Please supply a video of you taking a large dose of fentanyl
    #30 Tim Jones, Sep 11, 2024
  11. ChapmanF
    18,966
    In fairness, this was a thread started to compare the gen 4 vs. gen 3 water pump labor complexity.
    On the other hand, the person who started it seemed to be thinking a 2017 v is a gen 4, when it isn't.
    On the third hand, even for gen 4, the Toyota Flat Rate Manual time for the job did go from 7 hours down to 1.3 hours (which I would think qualifies as "under two hours"), once they improved the Repair Manual procedure to no longer have step 1 be "remove engine assembly with transaxle".
  12. V Sport Wagon
    375
    131
    Southern California
    This thread was always about the Gen 4 water pump labor hours. Stay with the conversation Boomer.
  13. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Who is doing the repair?
  14. whitrzac
    whitrzac Junior Member
    46
    madison
    All the Vs were gen 3. The OP has a V.
    The OP thinks it somehow has a 4th gen chassis.
  15. ChapmanF
    18,966
    Right, the OP made a simple mistake and thought "it's a 2017, must be gen 4", not realizing the v wagon was still gen 3.
    All that was covered in the very first reply three weeks ago.
  16. Air_Boss
    Air_Boss Senior Member
    4,247
    1,195
    New Yawk
    Seems appropriate...
    #36 Air_Boss, Sep 12, 2024
    Tim Jones and Mendel Leisk like this.
  17. V Sport Wagon
    375
    131
    Southern California
    Of course, but then the conversation moved to discussing the ACTUAL Gen 4 waterpump IN A Gen 4 vehicle and the labor hours involved in such a job. How hard is this to follow?
  18. Mr.Vanvandenburg
    1,359
    649
    2020 Prius Prime
    The g4 sounds ok now with the revision steps, compared to a water pump under the timing cover, requiring the crankshaft pulley to be removed.
  19. V Sport Wagon
    375
    131
    Southern California
    What car would that be?
  20. Mr.Vanvandenburg
    1,359
    649
    2020 Prius Prime
    A bunch of cars that have water pumps inside the timing cover. I only did two, a 1992 Honda Accord and a 2002 Camry v6. Both have belts. I suppose dozens of models have had or have it this way. I did this for a family member in driveways and when younger. No power tools all manual. I made my own crankshaft stop turning devices. The one I made for Honda they sell them now, a big hex that fits in the pulley.
    V Sport Wagon likes this.
