Sodium-ion 12v battery
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Sep 15, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,214
    927
    Here is a prototype of the sodium-ion 12v version for our Prius by Nexcell.
    I need to get terminal adapters to make it work as my cables were changed to normal terminals when I bought it.
    I may also just use it as a backup power source and charge it from my solar roof panel mod. 20240914_200525.jpeg 20240914_200536.jpeg 20240914_203700.jpeg
  2. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    I can't wait. My Ohhmu is great, but I worry about temps long term
  3. T1 Terry
    T1 Terry Active Member
    929
    491
    I question the size, 4 x 200Ah Sodium ion cells will fit in the same spot the original lead acid 12v battery fitted. Just requires a good active cell balancer as the Prius max 12v recharge is well below the 16v the 4 x 200Ah cells can handle, and not much hope of drawing more current than the 200Ah cells can deliver, or charging faster than they can accept it ..... It would certainly be enough capacity to run an inverter from for camping or emergency house power during a grid outage ......
    T1 Terry
  4. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    It is unlikely that 4x200Ah will fit into the auxiliary battery compartment of the Prius.
    The dimensions of the 200Ah are quite large. Weight 35 -+1.5 kg.
  5. T1 Terry
    929
    491
    Ummmm...... I guess it depends on the brand cells/battery you buy. There is no value in buying a battery in a battery case that is built out of prismatic cells, and the last thing you would want to buy is a battery built out of pouch cells unless it is a factory build and has cooling plates between the pouches. They are by far the most prone to heat destruction by bursting the pouch on the centre pouches if they are all squeezed in together in a single case, the inner pouches have no way of dissipating their heat. The only other type of battery built in a case are made out of cylindrical cells, fine for high output use, but no good for cyclic use ..... too many variables between the cell parameters with such low capacity per cell, all connected in parallel to make capacity.
    The last lot of sodium ion cells I was testing, before my house burnt down (not related) were shorter than the Winston 100Ah cells and the same physical sizes otherwise. I have been using ex house battery pack 100Ah cells in a compressed pack of 4 as a 12v battery in all my vehicles once the lead acid one passes on, they seem to be fine for such a low load job, even less load in either on my two Prius, they fit in the battery spot just fine.
    The next lot should arrive within the mth, they are for the new house batteries in our "new to us" motorhome.
    They are only ex house battery cells because the user dragged the battery down till no cell had a 1v reading, the ones that recover have lost capacity so not generally suitable for reuse, ones that have been dragged into negative voltage (the current pulled backwards through them) simply won't recover, that destroys lithium cells
    T1 Terry
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Any battery has an Energy unit per unit volume or Energy unit per unit weight rating.
    What were the ratings on your battery?
  7. AzusaPrius
    2,214
    927
    So here are the specs of the current battery I have a Duralast.
    Remember this battery is not for a prius so the specs are better than a standard Prius battery, even an Optima Yellowtop. Screenshot_2024-09-29-11-55-50-1.jpeg
  8. AzusaPrius
    2,214
    927
    Here is what is recommended for my Prius. Screenshot_2024-09-29-12-06-58-1.jpeg
  9. AzusaPrius
    2,214
    927
    Here is a Duralast meant for my Prius. Screenshot_2024-09-29-12-09-29-1.jpeg Screenshot_2024-09-29-12-10-00-1.jpeg
  10. AzusaPrius
    2,214
    927
    Here are the specs for an Optima Yellowtop meant for my Prius. Screenshot_2024-09-29-12-11-34-1.jpeg Screenshot_2024-09-29-12-11-44-1.jpeg
  11. AzusaPrius
    2,214
    927
    Here is the weight of the Sodium-ion battery meant for my Prius.
    As you can see the Sodium-ion battery weighs 22.79 lbs less than my current battery.
    The Sodium-ion battery also weighs 19.3 lbs less than the Duralast meant for my Prius.
    The Sodium-ion is also 16 lbs less than the Optima Yellowtop which weighs less than the other two batteries.
    At only 10 lbs this Sodium-ion can handle the Prius no problem and even in extreme cold weather conditions. 20240929_113138-1.jpeg
