Sodium-ion 12v battery
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Sep 15, 2024 at 12:35 AM.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,012
    853
    Here is a prototype of the sodium-ion 12v version for our Prius by Nexcell.
    I need to get terminal adapters to make it work as my cables were changed to normal terminals when I bought it.
    I may also just use it as a backup power source and charge it from my solar roof panel mod. 20240914_200525.jpeg 20240914_200536.jpeg 20240914_203700.jpeg
  2. V Sport Wagon
    V Sport Wagon Member
    294
    99
    Southern California
    I can't wait. My Ohhmu is great, but I worry about temps long term
  3. T1 Terry
    T1 Terry Active Member
    618
    323
    I question the size, 4 x 200Ah Sodium ion cells will fit in the same spot the original lead acid 12v battery fitted. Just requires a good active cell balancer as the Prius max 12v recharge is well below the 16v the 4 x 200Ah cells can handle, and not much hope of drawing more current than the 200Ah cells can deliver, or charging faster than they can accept it ..... It would certainly be enough capacity to run an inverter from for camping or emergency house power during a grid outage ......
    T1 Terry
