Has anyone else experienced this noise in their Prius?
Discussion in 'Generation 1 Prius Discussion' started by Victor Siles, Sep 5, 2024.
  1. Victor Siles
    Victor Siles Junior Member
    Garden City
    2001 Prius
    I
  2. ChapmanF
    15,992
    Sure have. It's not a matter of lubricating the linkage though.
    The linkage is 'hunting' back and forth because of flaky signal from a position sensor that tells the controller where it is. So the controller keeps thinking it is off target position, and trying to correct. This thread explains it;
    No, that wasn't a mouse in the heater | PriusChat
    The gen 1 used potentiometer position sensors for a lot of purposes, not just the HVAC dampers, and they all produced famous gen 1 symptoms when they produced flaky signals. When it happened in the accelerator pedal sensor, you got Big Hand Syndrome (like a Big Hand reached down from the sky and slowed the car down). When it happened in the steering torque sensor, you got the Steering Gear Jitters. And when it happened in the HVAC servos, you got this.
    Most of those sensors were changed to non-potentiometer types by gen 2, though the HVAC servos didn't get changed until gen 3. So the symptoms described above can also happen in gen 2.
    The different style of servo they went to in gen 3 are not without their own problems, but they're different problems.
    ammdb likes this.
  3. ammdb
    ammdb Active Member
    270
    110
    Indianapolis
    Yup, eventually the jittering back and forth broke the motor shaft during a cold snap, so no heat in the cab w/o reaching down and flipping the linkage by hand while the fan was on. The jittering went away after I replaced the motor.
  4. Victor Siles
    Garden City
    2001 Prius
    I
    Is this the motor Duct Blower Servo Motor?
    #4 Victor Siles, Sep 15, 2024 at 1:38 PM
  5. ChapmanF
    15,992
    There are three servo motors: one that selects the air source (fresh/recirc), one that selects the air outlets, and one controlling the temperature blend. Whichever one happens to be jittering can usually have the potentiometer traces and contacts cleaned, but if it's too far gone for that, it can be replaced.
  6. ammdb
    ammdb Active Member
    270
    110
    Indianapolis
    This is the part I ended up replacing:
    01-03 Toyota Prius A/C Heater Temp Control Damper Motor 063700-7440
