Information on EGR system and intake Manifold Cleaning
Discussion in 'Gen 3 Prius Main Forum' started by aperry1971, Jan 11, 2023.
  1. bbrages
    bbrages Member
    113
    26
    St. Louis
    There are a lot of different cap sizes, so you have to find one that fits
  2. Mendel Leisk
    38,990
    Fits the reservoir cap I suppose, since there is no cap on the radiator.
  3. Joe Dahmen
    Joe Dahmen New Member
    East Vancouver
    Technology
    Update: Prius back on the road with all systems functional and more power than recent memory. Endoscope investigation of cylinders didn't reveal any obvious leakage but seemed fairly inconclusive. Tracked misfire down to bad coil in cylinder 4. Moved to cylinder 2 and misfires followed coil. Replaced coils in #3 and #4 with two new coils ordered online here via Amazon.ca for CAD $91 each (vs CAD$191 at Toyota). Immediately took care of the problem.
    Many thanks for your advice throughout the process., Mendel and Mr. Dogman... would have been lost without you. I received the card below from my 11yo daughter in the evening, along with various gifts from my wife in appreciation. They really know me too well.
    Mendel Leisk, burebista and ASRDogman like this.
  4. ASRDogman
    ASRDogman Senior Member
    6,291
    3,353
    Nifty! I hope that resolves your issues.
    Keep an eye on the coolant level. And be alert to cold start engine rattle. Also after driving and
    the car sits for 30 minutes or so, it may rattle. That was my first rattle. Coolant seemed to be where
    it should be. But the next day, same thing, this time the coolant was slightly lower. The mark is
    right on the seem. I now keep it slighty higher.
    I had planed on changing the head gasket in the next few weeks, but it decided it was time,
    at 301,xxx miles.....
  5. Joe Dahmen
    East Vancouver
    Technology
    I'll keep an eye on the coolant over the next few weeks and months for sure. What causes the rattles due to gasket failure? Is it misfires due to incursion of coolant? Or?
    I'll attach the endoscope images taken inside the cylinders but I can't seem to download them at present.
  6. Mendel Leisk
    38,990
    Coolant in the combustion chamber is hard to compress, and maybe fouls the spark plug as well. I think the sound is mostly at the damper between engine and transaxle, but not sure. The engine's not happy, that's for sure.
  7. rjparker
    8,233
    4,885
    It’s coolant fouling of the plug causing misfires for 5-10 seconds. The engine loses sync with the transaxles motors causing a friction damper between them to severely rattle. It also causes the engine to shake. Left too long and you bend rods and blow holes in the block.
    Brian1954 likes this.
  8. ASRDogman
    6,291
    3,353
    When the engine is hot, the gasket seems to seal. But when it cools down,
    coolant will leak into the cylinder(s) overnight, (usually 1 and 2 for some reason).
    And depending on how long it's been leaking, either a lot or little will sit on the top of
    the cylinder(s). When the engine starts up, coolant doesn't compress so it gets
    pushed to the top and covers the spark plug so it's can't spark, thus no thrust downward.
    So no power, then what Parker said post #67.
    If there is only a little coolant, it clears in a second or two and the engine starts. If there
    is more coolant, it will take longer to clear it out, and then the new air/fuel being sucked in
    can start to clean off the plug and then it sparks and off you go.
    If it's really back, it can bend a rod, or two, and maybe explode the piston and throw it and
    maybe the rod out the side of the engine....
    That's why it's BEST to replace that head gasket at the first sign of leaking...
    Also, condensation can form in the pistons when it's cold outside and a hot engine is cooling
    down. This happens occasionaly and is not big deal as it's normal...
