"EGR DELETE" Instructions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Jun 17, 2023.
  1. Bill Norton
    Bill Norton Senior Member
    2,145
    734
    MONW, Ks.
    It's the EGR Valve. [edit] No other sensor, but there is a MAP sensor that could tell the system if there is a problem with calculated EGR flow.
    edit: I think my Gen 1 Insight had a feedback linear pot as part of the EGR Valve that went bad sometimes..
    sorry for the confusion.
    #41 Bill Norton, Sep 30, 2024
  2. Bill Norton
    2,145
    734
    MONW, Ks.
    I'm on my 3rd Gen3 also!
    I have never done the dreaded EGR system cleaning. I know I should at 153k miles.
    But instead, for the meantime, I'm joining the club of EGR Unplugged.
    I have the Torque app so I can clear the code when I want to.
    My driving and FE changes all the time so it will be hard to put a number on before / after.
    I'll eventually clean the system and reconnect the EGR Valve, so I'll have 3 sets of MPG data to try to see if there is a difference.
    johnHRP and MPGS-LOL like this.
  3. ChapmanF
    18,134
    There is no feedback sensor in the EGR valve. The valve actuator is a six-terminal stepper motor, and that accounts for all six of the pins in its electrical connector.
    The only feedback the system has is from the MAP sensor, which gets used in the self-test that can set the P0401 code, which runs every now and then when the car is decelerating with the engine turning and the fuel cut off.
    johnHRP, MPGS-LOL and Bill Norton like this.
  4. Bill Norton
    2,145
    734
    MONW, Ks.
    EGR Delete follow up:
    My '10 has ~2k miles with the EGR valve disconnected.
    1400 miles on a +80 mph blast to the Rockies and back.
    Fuel economy seems the same.
    I swear I feel a new smoothness to the engine now. When very slowly adding power, I used to feel the engine 'not respond/stumble a bit before it started to accelerate. Now it just accelerates with slight throttle inputs.
    It was easy to disconnect the valve and cover both sides with tape to keep them clean.
    The P0403 code comes up as soon as I start the car. "EGR Control Circuit". That's the safe code to have. The ECM knows the EGR is not playing along and adjusts things accordingly.
  5. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    (The copper & steel wire mesh is to keep rodents away / )
  6. Bill Norton
    2,145
    734
    MONW, Ks.
    Lovely job.
    I have a cat. He's on a mission to rid the neighborhood of rodents, lizards, cicadas, and unfortunately birds. I wish cats were trainable...:unsure:
    mjoo likes this.
  7. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    Glad to hear from a Brazilian backing it up. You guys and gasket masters are the original inspiration for the unplug. lol
    Bill Norton likes this.
  8. johnHRP
    johnHRP Active Member
    644
    186
    KA, DE
    Excel
    My friend has trained cat but only playing. it still kills whatever it likes. Rodent is not too much big deal as long as we kept it clean and check the car under the hood quarterly. The intake for the air duct can be covered with stainless mesh to prevent rodent nesting.
    What annoys me more is Weasle or Martin. It chews anything in no time. Even just for 1 night park at the wrong spot
    The EGR unplugged is an interesting idea. It is useful if we have clogged EGR and has not time to fix it.
  9. iSmithy
    iSmithy New Member
    Portugal
    +1 member to join the NOEGR club. My Pirus3 had this issue for years, my wife was always complaining that the car is vibrating and shaking. I cleaned EGR several times, but the issue continued to came back every time. After one of the mechanics told me that its a serious issue and wanted to charge 530 euro to change the EGR, i desperatelly started to search for solutions, and thanks god i found this thread. It saved me money, and mental health.
    So far after 1 month of EGR disabled, no issues at all, i can finally enjoy the rides that a real hybrid should offer, smooth and silent transitions from EV to Engine, smooth acceleration and engine sound on highway, the car is finally breathing fresh air, without that stinky muddy useless EGR system. Thanks Paladin, amazing tip.
    johnHRP, Paladain55 and Bill Norton like this.
  10. Mendel Leisk
    41,392
    What’s the miles?
  11. frodoz737
    frodoz737 Top Wrench
    4,694
    2,494
    33
    Dumping raw exhaust into a clean fuel/air mixture before combustion is like a person who smokes. It won't kill you right away, but it's going to shorten your life. The egr system is not healthy for engines.
    johnHRP likes this.
  12. Bill Norton
    2,145
    734
    MONW, Ks.
    Well Gang, , I'm at 167k mi. after 5 month and ~11k miles of running with the EGR disconnected.
    About a week ago on a 500 mile drive, twice I noticed a stumble/misfire while lightly accelerating coming from a stop. It lasted maybe 3 seconds each time.
    "Spark plugs, finally!" I said to myself. :unsure:
    But when I checked the next morning my coolant was down 3/4". Uh Oh..... HEAD GASKET failure has begun.
    Topped it up and drove it the next day with the coolant cap loosened to avoid pressurizing the coolant system and had to do another 500 mi. day. Coolant was low 3/4" again.
    I have an appointment with Gasket Masters next week. Hopefully FelPro makes a long life version compared to stock.
    Let the skeptics begin! I was told I'd "Blow up my engine" if I disconnected the EGR.
    Is this the same chronic head gasket failure that all Gen3's experience count as a blow up?:whistle:
    johnHRP likes this.
  13. frodoz737
    4,694
    2,494
    33
    Recorded history suggests your head gasket failure has nothing to do with egr disconnect...and more to do with 167,000 miles on a 2010 GEN III.
  14. Bill Norton
    2,145
    734
    MONW, Ks.
    Yeah, I agree. It seems to be a chronic issue.
    I changed the coolant , a half gallon at each Mobil1 oil change at ~5-6k mile intervals.
    After the EGR disconnect I could not tell a mpg change, just a new smoothness in light throttle accel.
    I've been driving 81 mph true (+6) into 20 mph headwinds in single digit temps, some negative, and getting 37-39mpg. I'm fine with that.
    When I get it back with a functional and clean EGR system the temps will be much higher. It will be hard to claim an increase in mpg due to the EGR.
    Looking forward to driving this Level 5 with the Advanced Tech Package to the limit. The LKA tries to 'assist'. The ACC is awesome!
    I was tempted at first to just sell it, buyer beware, and get a Gen5 and use the Comma3, but dang, they're so expensive.... And it sounds like they haven't figure out everything with the Prime....12V batter failures....
  15. Paladain55
    404
    164
    The South
    Yeah knocking over time leads to head gasket failure. I probably knocked for 10,000 miles before i unplugged mine. 60k miles later though im still running great. I recommend it to all. EGR delete makes them legendary cheap to run.
  16. Bill Norton
    2,145
    734
    MONW, Ks.
    Well, gang, I'm still waiting for my local Gasket Masters guy to call me and tell me to bring it down to his remote shop 220 miles away. I've been driving it a bit locally at low-ish power and it doesn't seem to be using coolant as much, but then I have the coolant cap loose so the system is not pressurized at shut down. I'm supposed to get that call today.
    Anyways,,,, I found this on Wally's. (I normally avoided that place but this site creates links with words in posts and that took me there.
    Is this correct about the years of Prii that use this gasket? I was told here that the Gen4 was a totally different Block and Head design.
    Just curious what Wally's is showing here.
  17. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Brilliant!!! Thank you op
    I have to wonder if Bill was too late for the EGR delete and already had a weeping gasket before he performed the delete..
    This is genuinely exciting news for anyone that likes their gen3
    #57 ozmatt, Mar 15, 2025
  18. Paladain55
    404
    164
    The South
    I think thats what is ozmatt. Thats why i take any knock serious now lol.
  19. Bill Norton
    2,145
    734
    MONW, Ks.
    All I know is it was running better than ever after unplugging the EGR Valve and not using any coolant.
    Then many miles later, twice, on one 500 mile trip it had a 'misfire' feel for a few seconds after a start up and adding power to pull out into the street. The next morning I saw that ~3/4" of coolant was used. Saw that again after a second long trip but didn't feel any misfire.
    I am now running with the coolant cap loose and haven't driven it on long trips. But it's fine locally and doesn't seem to consume coolant,
    BUT, I know.....:unsure:
    One last 250 mile trip to Gasket Masters ! (y)
    Paladain55 likes this.
  20. Danny13pruisc3
    175
    27
    maryland
    Any updates? Did you investigate other possible coolant loss possibilities?
