C1214 Hydraulic System malfunction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bisprius, May 4, 2021.
  1. Bisprius
    Bisprius New Member
    Centreville VA
    Hi everyone, I have a Prius 2010 base model and it has three lights on the dashboard recently (Abs, traction control and brake). The brake seems working but occasionally goes all the way down to the floor and needs manual pumping at the stop.
    The code stored is C1214 Hydraulic System malfunction. What could
    diagnosed with a nearby mechanics and was suggested that one of his previous customer changed ABS module and Accurator though he doesn’t do it (a expensive fix) .
    What might be the cause / common fixes.
    Please suggest me the effective way to fix if anybody has had the similar problem before.
    Thanks
    49,844
    welcome!
    i think he's right, you need a new brake actuator. check with toyota to see if it is under extended warranty
    Bisprius likes this.
  3. Elektroingenieur
    2,515
    3,266
    Three Touring
    That’s one possible cause. The Repair Manual (more info) suggests some others, too, such as a brake fluid leak or excessive wear of a brake rotor, which might be much less costly to repair.
    The first steps in the diagnostic procedure for DTC C1214 are to check for leaks, bleed air out of the brake system (which requires a Toyota Techstream diagnostic system or equivalent), and check the electrical connections at the brake booster with master cylinder assembly.
  4. Bisprius
    Bisprius New Member
    Centreville VA
    Thank you and sorry for the late reply. The problem was the brake leak and the rear brake caliper.
    Elektroingenieur likes this.
  5. Adam O
    Adam O Junior Member
    FL
    Four Touring
    Thanks so much for coming back to update.
    I know it has been awhile since this happened to you.
    Do you remember where the leak was?
  6. Ben G
    Ben G Junior Member
    New York
    2012 Toyota Prius 4, 187,200 miles. Leather, Nav system, Bose system.
    I'd like to tell you about my recent experience with this. I was on a 2.5-hour drive home and at some point my ABS, BRAKE, & TRACTION CONTROL lights went on. My brake pedal felt like a manual pedal, a little harder to push down and a longer throw to get braking power. Thank god my brakes were still working. Obviously, I had no traction control or anti-lock brakes. I knew this was a serious situation. I had an OBDLINK LX scanner so I plugged it in. I had to buy the enhanced codes for my car @ 15.00 but I thought it was worth it. It returned c1214, and c1391 codes. C1214 Hydraulic System malfunction & C1391: Abnormal Leak of ACC PRESS. I started doing my research about these.
    I got quotes from 3 local Toyota dealers. I got quotes from a low of 2350.00 to a high of 3350.00. Needless to say I was kind of freaking out, that's just too much of an expense for me right now. There are 2 parts associated with this repair. I had read of one guy who had the same situation, and he took It into a local repair shop and the right rear rotor was leaking. He replaced that and the lights disappeared. I thought I would try that. I took the car to a local Mavis tire repair shop where I had done work before. I explained the situation. I told them my front brakes were done in 202 and I had 115k miles at the time. I thought maybe those front brakes were causing the issue since now I have almost 183k miles on the car, that's 68k on the front pads. The mechanic hooked it up to his OBD scanner and got the same codes as I did. Meanwhile, I told him to replace the front pads and rotors and then clear the codes in the system. Lo and behold, no more lights on the dash and the problem seems to have been fixed. It cost me 430.00 for the repair, a big difference from the numbers I was looking at. There is one thing that still bothers me. The Brake Booster Pump Assembly (Accumulator) still cycles on and off every 8 seconds for 3 seconds at a time. I don't think this is what it's supposed to be doing. So I don't think I am completely out of the woods yet. To be continued...
  7. Brian1954
    Brian1954 Active Member
    996
    357
    South Central PA, USA
    Ben G created a new thread here: https://priuschat.com/index.php?posts/3484053
    Please do not respond to his post in this thread. If you want to respond, please use the thread that I linked to.
  8. ASRDogman
    ASRDogman Senior Member
    6,317
    3,366
    P A R A G R A P H ' S!!!!!!
