AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 20, 2024.
  1. Jotunn
    Jotunn New Member
    17
    High Point, NC
    2024 Prius Prime
    XSE Premium
    Just curious, when you do the charging with the Noco are you simply putting it on the AGM setting, or doing the repair charge?
    I ask because the constant current and 14.8V set point you referred to is the repair setting.
    Gokhan likes this.
  2. ChapmanF
    18,560
    In gen 3, there is a self-test of the evaporative emission controls for the fuel tank that begins several hours after parking and turning off the car (in gen 3, I thought the schedule was 5 hours after turning off, but that could be extended based on temperatures). I'd guess this is the same thing. The power is going mostly to the leak-test pump, which runs in stages B through E of the test:
    The pump can run anywhere from about 7 minutes to about 22, depending on how long stage C takes.
    I think we usually use 'parasitic' to mean drains that don't happen on purpose, so it wouldn't be quite fair to call this one 'parasitic'.
    I don't think the evap test will run repeatedly if the car is just left alone for a few weeks. I think it'll run the one time, several hours after the car is left there.
    Gokhan likes this.
  3. Gokhan
    Gokhan Senior Member
    6,548
    2,613
    Paramount CA
    Ah, I see. But this isn't the only source of parasitic drain. There are also small parasitic drains coming from elsewhere.
  4. Gokhan
    6,548
    2,613
    Paramount CA
    No, regular charging in the AGM mode. I wouldn't use the repair mode for a brand-new battery. The voltage goes up to 14.8 V in the AGM mode and 14.5 V in the flooded-cell mode.
    The voltage in the repair mode goes up to 16.5 V. The current must be much higher in that mode.
    #24 Gokhan, Oct 3, 2024
  5. Gokhan
    6,548
    2,613
    Paramount CA
    This is the rested-battery open-circuit voltage so far:
    day voltage
    18 13.05 V
    19 12.98 V
    20 12.95 V
    21 12.92 V
    22 12.90 V
    23 12.87 V
    24 12.87 V
    25 12.87 V
    26 12.87 V
    27 12.87 V
    28 12.87 V
    29 12.87 V
    30 12.86 V
    01 12.85 V
    02 12.84 V
    03 12.87 V
    A fully charged AGM battery is about 12.89 V; so, 12.87% is perhaps about 98%, but it also includes the daily parasitic drain. Therefore, the charging system seems to be doing a good job keeping the battery fully charged, except for the three days (30, 01, and 02), in which it didn't charge the battery for some reason, but then, it has started charging again for the last two days.
    Chances are that it is helping that I have an AGM battery instead of a flooded-cell battery, as an AGM battery charges five times faster than a flooded-cell battery.
    Here is the last two day’s data:
  6. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    Posted the below in wrong thread.....
    Gokhan said:
    Ha, what is the 12-V-battery current when the DC–DC converter pulls back to 12.86–12.92 V? And how about at 14.10 V? It has about four voltage settings: 12.89 V, 13.05 V, 13.53 V, and 14.10 V.
    OK, here's some data to digest. I hooked up my Topdon Phoenix Lite 2 scan tool this morning. The data streams I recorded were AUXILIARY BATTERY VOLTAGE (ABV) and AUXILIARY BATTERY CURRENT (ABC). The car had not been driven since yesterday morning. Starting battery voltage before READY per my BM read 12.41 volts.
    READY mode enabled, scan tool (ST) ABV 14.219 volts and ABC 7.160 amps. ABV stayed constant at @14.2 volts but ABC started to slowly decrease with time to @3 amps at which point the ABV decreased from 14.2 volts to 12.8 volts As the ABV decreased, the ABC decreased and went negative -4.345 amps when the ABV read 12.795 volts. The ABV held steady at @12.8 volts and the negative ABC started to decrease (lower negative current). The negative ABC held at negative 0.5 amps for a time period. Then the negative ABC dropped off and would pulsate from plus/minus current of about 0.1 amps. With time, the ABC stabilized positive @ 0.2 amps with ABV holding steady at 12.8 volts.
    I was recording while driving the car. Came to a stop and noted ABV increased to 13.599 volts and ABC now 3.803 amps. ABC would slowly decrease but ABV stayed stable at 13.6 volts. ABV deceased to 12.8 volts and ABC now negative 2.041 amps. With time and ABV stable 12.8 volts, the ABC negative current slowly became less and went slightly positive before I shut the car down.
    NOTE: I am unable to correlate times with the data stream frame shots unfortunately. I don't use this ST often enough to be that knowledgeable on how or if it can be done.
    OBSERVATIONS:
    The ABV as read on the scan tool data stream was in exact correlation with the voltage meter I have plugged into the 12 volt outlet on the center console.
    The scan tool shows a stabilized 12.8 volts but a pulsating ABC. See snapshot below.
    One other observation. On the upper right corner on the scan tool is a voltage display. This voltage would constantly fluctuate typically plus/minus 0.3 volts or possibly more. Hard to capture. I did note seeing @14.5 volts as the highest on occasion. This voltage reading is from pin 16 on the OBD2 connector which I confirmed with Topdon.
    My takeaway is that the charging system (BMS) for the aux battery seeks out and stabilizes at 12.8 volts. The pulsating ABC is most likely from the pulsating voltage that the ST sees on pin 16. I don't have a WD to see how pin 16 taps into and where. I haven't been able to find a data stream that monitors pin 16 voltage. Pin 16 is typically described as battery voltage. So why the difference between ABV and pin 16 voltage ???
    From what i saw and recorded today, short trips will definitely drain the battery over time.
    I'm charging the traction battery and plan to leave cable plugged in to see how my aux battery reacts. After that, plan to install the AGM battery and do a similar data stream recording.
    Cheers
    Gokhan likes this.
  7. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    Puzzled why the pin 16 battery voltage as seen on the scan tool behaved the way I saw it. The scan tool showed AUXILIARY BATTERY VOLTAGE (ABV) stable at 12.8 volts like my voltmeter device plugged into the 12 volt outlet. Now thinking back, the pin 16 voltage would rapidly flux about 0.2 volts above and below the 12.8 value. So my theory is the ABV is smoothed out on the data stream but the AUXILIARY BATTERY CURRENT (ABC) reflects the fluctuations. The time is did recall seeing about 14.5 volts on the pin 16 voltage display was when the ABV was 14.2 volts. Just my thoughts.
    A few additional snapshots. Unfortunately, the scan tool data file can only be played back on the tool. No option to create PDF so I just tool camera shots of several time frames
    Cheers
    Gokhan likes this.
  8. Gokhan
    6,548
    2,613
    Paramount CA
    Yep, this is exactly what I have been observing in my Gen 4 Prius Prime. I didn't have the current values, but my educated guesses for the current values were exactly what you were measuring as well.
    You are right that the voltage value seems to be averaged out. The actual voltage value by the BM2 battery monitor in my Gen 4 fluctuates between 12.86–12.92 V when the battery is not charging, though not rapidly.
    Your Uplus EN LN1 AGM battery is in, right?
    #28 Gokhan, Oct 4, 2024
  9. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    Yesterday data was with OEM battery. Hope to get the UPlus AGM installed today and do similar scan tool data record.
    Charged the car yesterday and decided to leave the charging cable installed to learn how car battery depletes with time.
    3:00 PM. Car finished charging. BM voltage 12.43 volts
    3:13 PM BM voltage stabilized at 12.60 volts
    9:19 PM BM voltage 12.47 volts
    6:15 AM. BM voltage 12.40 volts
    So it appears my car is not a candidate for the TSB as I once suspected.
    Cheers
    Gokhan likes this.
  10. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    Installed the UPlus AGM this morning to replace the OEM Yuasa battery. The AGM had been on charge for a week with a Noco Genius 5 charger. Green light steady indicating full charge. Did not measure voltage after charger disconnect. Installed in car and waited 1 hour to ensure car asleep. BM reading 13.01 volts.
    Made a 31 minute trip HV mode majority highway driving. Scan tool monitoring AUXILIARY BATTERY VOLTAGE and CURRENT. Stop watch to record time to get approximation of frame recording interval.
    INITIAL DATA - READY MODE
    5 MINUTE ELAPSED TIME DATA
    5 MINUTE 15 SECONDS ELAPSED TIME DATA
    MOMENTARY HARD ACCELERATION 17 MINUTE DATA
    28 MINUTES 45 SECONDS ELAPSED TIME DATA
    30 MINUTE ELAPSED TIME DATA
    END OF TRIP DATA
    SUMMARY
    BM voltage 1 hour after car shutdown measures 12.99 volts.
    The transition from 14.2 volts charging to 12.8 volts at the @5:15 mark showed a high battery discharge of around 30 amps. As time progressed, the current discharge decreased to less than 1 amp with 12.8 volts. At about 17 minute mark, I needed to pass a truck on an uphill slope. Hard acceleration and noted that the ABV went up to 13.1 and ABC @ 8 amps for a short period then back to 12.8 volts and current discharge. For about 26 minutes, the ABV was 12.8 volts and the battery ABC showing discharge. This was for the AGM battery. The data I recorded yesterday for the OEM indicated the ABC did eventually go positive, i.e., charge current, with time. That said, the AGM voltage post 1 hour car shutdown was 12.99 volts which is 0.02 volts less than at trip start.
    It appears to my thinking that with the AGM battery, the BMS sees the battery at a certain capacity to where it can allow a small discharge current and thus reduce load on the DC-DC converter resulting in better fuel economy. My initial takeaway is that the AGM should perform better for my driving scenarios. Time will tell.
    Cheers
    GcinFl and Gokhan like this.
  11. Gokhan
    6,548
    2,613
    Paramount CA
    My AGM-battery open-circuit voltage has eventually settled around 12.87 V after rest, which includes about a 2% SOC drop of nightly parasitic drain. Yours should come down to that in about five days as well, at which point you won't see a current drain when the DC–DC converter voltage is 12.89 V.
    #31 Gokhan, Oct 4, 2024
  12. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    This is all nice and everything, but have you tried the tests with everything running? AC full blast. Radio on. Charging a phone. Headlights on. I only ask because everything runs off the 12v battery even as its being charged by the inverter.
  13. Gokhan
    6,548
    2,613
    Paramount CA
    Of course. They don't affect it much, in fact typically not at all. In the Gen 5 new-car features, it is mentioned that if the 12-V-system load is high, it goes into constant-voltage mode, meaning the DC–DC-converter voltage rises to 14.10 V.
  14. Gokhan
    6,548
    2,613
    Paramount CA
    It turns out that Toyota TrueStart is made by Interstate Batteries.
    Interstate Batteries label hidden under Toyota TrueStart label—TikTok
    Kevin Kellogg and RandyPete like this.
  15. CooCooCaChoo
    961
    542
    Cow-lee-fornia
    2023 Prius
    Car batteries are only manufactured by like three companies, according to this video.
    It may say Interstate Batteries underneath, but Johnson Controls manufactures them.
    RandyPete and Gokhan like this.
  16. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    My EverStart AGM battery from Walmart was made in South Korea by Clarios Delkor. That Project Farm video is several years old. I don’t know if Interstate currently makes some EverStart batteries for Walmart. If so, interesting that Walmart battery warranty better than Costco warranty.
  17. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    The 12 volt aux battery is charged by the DC-DC converter not the inverter which is AC
    Gokhan likes this.
  18. Gokhan
    6,548
    2,613
    Paramount CA
    The Project Farm video was correct.
    Johnson Controls was later bought by Brookfield Business Partners and renamed to Clarios, which owns the brands Varta, Heliar, LTH, Optima, Delkor and MAC.
    Another major company is Exide. Of course, there is also the Toyota OEM GS Yuasa.
    It turns out that Interstate Batteries do not manufacture batteries at all. They only market batteries they buy from Brookfield Business Partners/Clarios and Exide.
    And finally, the other major lead–acid battery manufacturer is the Singapore-based Leoch, which also makes the state-of-the-art-technology Uplus brand under which we purchased our AGM batteries on Amazon. They are a very good company:
    Brand introduction—Welcome to LEOCH lead–acid battery, VRLA battery, UPS battery, motorcycle battery, car battery, golf-cart battery, gel battery
    Automotive archives—LEOCH® Americas
    #38 Gokhan, Oct 5, 2024
    Kevin Kellogg and Roy Peterson like this.
  19. Gokhan
    6,548
    2,613
    Paramount CA
  20. Roy Peterson
    Roy Peterson Member
    99
    129
    Richland WA
    2024 Prius Prime
    The UPLUS AGM battery has been installed in my 2024 Prime XSE Premium for about a week. Here are some observations to date:
    The OEM battery resting voltage after a day or so typically would be 12.3X to 12.4X volts if not charging the traction battery. The AUXILIARY BATTERY STATE OF CHARGE as read from the scan tool data stream was 31 AH. The OEM battery is rated at 45 AH. Typical drive charging scenario would be 14.2 volts at start then dropping to 12.8 volts. Per the scan tool, at 12.8 volts, the current into the battery would pulse between a low plus/negative value so this appears to be the maintaining charge value.
    The AGM battery resting voltage has been 12.7X to 12.8X volts. The AUXILIARY BATTERY STATE OF CHARGE reads 46 AH. The UPLUS battery is rated at 50 AH. I don't know if the ECU can calculate up to 50 AH since the OEM is only rated at 45 AH.
    Charging scenario differs slightly from the OEM per my observations. When charging the traction battery, the initial aux battery voltage is 14.2 volts for about 5 minutes then decreasing to 13.08 volts for the remainder of the 3-4 hours charging time. I use a level 2 charger. The OEM battery voltage during traction battery charge would also start at 14.2 volts but drop off to 12.8 volts with time.
    With the AGM battery, if I drive the car after traction battery charge, the aux battery voltage starts at 14.2 volts but within a short time drops to 12.8 volts. If I drive the car after it has sat overnight and not recently had the traction battery charged, the aux battery voltage starts at 14.2 volts, drops to 13.5 volts with time and then drops to 13.1 volts and stays at that voltage for the remainder of my 20 minute trip. With the aux battery voltage at 13.1 volts, the aux battery current pulses plus/negative low current value similar behavior as the OEM battery at 12.8 volts.
    Since the AGM battery has a higher SOC voltage compared to the OEM flooded battery, the slightly higher charging voltage noted seems reasonable.
    In summary, the AGM battery is working better for me than the OEM based on the typical trips I drive which are 20 minutes or less. Will continue to monitor. With this experience of the AGM, I have confidence to move my jump starter from the glove box to the rear hatch area :)
    Cheers
    Gokhan likes this.
