Odd behaviour
Discussion in 'Gen 2 Prius Main Forum' started by Has Raf, Oct 3, 2024 at 3:44 PM.
  1. Has Raf
    Has Raf Junior Member
    44
    Stoke-on-Trent, England
    I was having an issue with my car. As I would come to a stop, just before, as I was slowing down, the car would jerk and jolt forwards. It’d be worse the faster I was going, and the harsher I’d be braking. (I try to brake slowly and gradually of course, not harshly). It would feel like I was being hit from behind the car. Thankfully, this has now subsided, but I now have the yellow VSC, ABS and (!) on my dash… I’ve ordered a Autel, but hasn’t arrived yet, so can’t read error codes at the moment. Help please!
  2. ChapmanF
    16,064
  3. Has Raf
    44
    Thank you. This seems awfully complex and time consuming for me. I’ll wait for my Autel. I wasn’t really asking about the error codes. In more curious about the odd behaviour.
  4. pasadena_commut
    pasadena_commut Senior Member
    1,633
    489
    Southern California
    Looks like the car is doing its best to tell you: problem with the braking system.
  5. ChapmanF
    16,064
    It even wants to tell you what problem with the braking system, but you have to ask it.
  6. Has Raf
    44
    Again, this post wasn’t so much about the error codes. What about the physical issue, which has now resolved, but error codes instead?
  7. rjparker
    8,264
    4,902
    Your car is brake by wire meaning a computer is opening and closing valves in the master cylinder to allow a hydraulic pump and accumulator to pressurize the brake calipers. In most cases regenerative braking where the wheels are driving a generator do most of the braking. So your system was failing at the time.
