Odd behaviour
Discussion in 'Gen 2 Prius Main Forum' started by Has Raf, Oct 3, 2024.
  1. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    I was having an issue with my car. As I would come to a stop, just before, as I was slowing down, the car would jerk and jolt forwards. It’d be worse the faster I was going, and the harsher I’d be braking. (I try to brake slowly and gradually of course, not harshly). It would feel like I was being hit from behind the car. Thankfully, this has now subsided, but I now have the yellow VSC, ABS and (!) on my dash… I’ve ordered a Autel, but hasn’t arrived yet, so can’t read error codes at the moment. Help please!
  2. ChapmanF
    19,002
    rogerdpack likes this.
  3. Has Raf
    Has Raf Member
    180
    43
    Thank you. This seems awfully complex and time consuming for me. I’ll wait for my Autel. I wasn’t really asking about the error codes. In more curious about the odd behaviour.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,039
    943
    Southern California
    Looks like the car is doing its best to tell you: problem with the braking system.
    rogerdpack and Danno5060 like this.
  5. ChapmanF
    19,002
    It even wants to tell you what problem with the braking system, but you have to ask it.
  6. Has Raf
    Has Raf Member
    180
    43
    Again, this post wasn’t so much about the error codes. What about the physical issue, which has now resolved, but error codes instead?
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,067
    6,936
    Texas Hill Country
    Your car is brake by wire meaning a computer is opening and closing valves in the master cylinder to allow a hydraulic pump and accumulator to pressurize the brake calipers. In most cases regenerative braking where the wheels are driving a generator do most of the braking. So your system was failing at the time.
  8. Has Raf
    Has Raf Member
    180
    43
    But, at the time the car was malfunctioning, there were no warnings on the dash. Now, the car is not malfunctioning when braking, but error cars are displayed as above. Odd?
  9. rjparker
    11,067
    6,936
    Texas Hill Country
    Many failures require multiple trips to code.
  10. Has Raf
    Has Raf Member
    180
    43
    I just ran a diagnostic using mini Autel MaxiAP AP200, and no fault codes. But the VSC, ABS and (!) lights are on…
  11. Brian1954
    Brian1954 Senior Member
    2,670
    1,068
    South Central PA, USA
    Did you do a "full scan" or the "regular scan"?
  12. Has Raf
    Has Raf Member
    180
    43
    Full I’m assuming. This was the result:
  13. Brian1954
    2,670
    1,068
    What app are you using and the version of the app?
    Take a look at this linked thread with screenshots of the correct app:https://priuschat.com/index.php?posts/3248209 Read post #1.
    It looks like you did not register or link the Autel AP200 to your Toyota Prius. You can not run a full scan until you have done this, and the Toyota data file is downloaded to your phone.
    Maybe @mr_guy_mann can help with the app.
    #13 Brian1954, Oct 6, 2024
  14. Has Raf
    Has Raf Member
    180
    43
    Yes, I did download the data file I believe. My app looks like those screenshots. I’m using MaxiAP200, version 1.47 on iOS. It just said 0 errors…
  15. Brian1954
    2,670
    1,068
    I think that you do not have something set up correctly in the app. All the vehicle information for your Prius is not showing in the screenshot that you uploaded. Something is not right.
    I do not own or use the Autel AP200, so I am not able to help you any further.
    Edit: Take a look at the attached Autel AP200 Quick Reference Guide for North America
    #15 Brian1954, Oct 6, 2024
  16. Has Raf
    Has Raf Member
    180
    43
    Ah, yes. I fear I have not set-up the app correctly. Thanks for your help.
  17. Has Raf
    Has Raf Member
    180
    43
    IMG_2753.png IMG_2750.png IMG_2751.png IMG_2752.png These are the codes:
    Brian1954 likes this.
  18. pasadena_commut
    3,039
    943
    Southern California
    There are a few threads on C1235 which the OP should probably read. Unfortunately the ones I read faded out without a "this fixed it" at the end. Anyway, definitely go have a look to see what is stuck to the RH front speed sensor.
  19. Has Raf
    Has Raf Member
    180
    43
    Codes cleared. warning lights off now, and the cars back to doing the jerking on slow braking before coming to a stop, weird! I need change a drop link, ball joint and lower engine mount, so I’ll check the speed sensor while I’m at it. PS speed sensor and ABS sensor same thing?
  20. Mendel Leisk
    42,323
    Get a dealership to diagnose and propose a course of action, or is that just crazy talk in this day'n age?
