2009 Toy Prius Gen 2 Windows
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RandyPete, Oct 7, 2024 at 5:15 PM.
  1. RandyPete
    RandyPete Member
    223
    75
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    My 2009 Toy Prius Gen 2 Windows stopped working as expected. I can roll up down the drivers door window. The other 3 windows will not roll up after placing them in the down position . Any common fixes for this ?
    [update] Sure enough, I had pressed the window lockout on the drivers side window control panel !!
    #1 RandyPete, Oct 7, 2024 at 5:15 PM
  2. RandyPete
    RandyPete Member
    223
    75
    2024 Prius Prime
    XSE
    From a Gen2 Prius group post "Before anything else, what's the position of the window lockout switch on the driver's door switch panel?"
    Sure enough, I had turned on the lockout switch on the drivers door switch panel.
    Problem solved !
