2009 Toy Prius Gen 2 Windows
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RandyPete, Oct 7, 2024.
  1. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    My 2009 Toy Prius Gen 2 Windows stopped working as expected. I can roll up down the drivers door window. The other 3 windows will not roll up after placing them in the down position . Any common fixes for this ?
    [update] Sure enough, I had pressed the window lockout on the drivers side window control panel !!
    #1 RandyPete, Oct 7, 2024
  2. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    From a Gen2 Prius group post "Before anything else, what's the position of the window lockout switch on the driver's door switch panel?"
    Sure enough, I had turned on the lockout switch on the drivers door switch panel.
    Problem solved !
    Brian1954 likes this.
